BMC 1500w Brushless motor 5/8in shaft - $75
Have extra parts that need a good home? Post it up here and see if anyone else is searching for what you are selling.
magudaman   10 kW
Post by magudaman » Jan 21 2023 12:15pm
Up for sale is my 1500w BMC brushless motor. I added two
Temp proves that show internal air temp and internal winding temp. The shaft is 5/8in bore with a keyway. It has hall sensors internally that work but have since lost the pin out. I will try to dig up the hall connector before the sell. Fan is dead on back could be easily replaced with same size. The motor was spec 48v. Priced to get it out of my garage $75. Local pick up would make the most sense but might be able to get it to fit in a flat rate box for $20 or so. Easily handles 3kw.
Electric Motoped:
10kw Mars Brushless Etek
16s1p A123 AMP20 Pack
Kelly Ebike Brushless 350a/10kw
