Auraslip, the display is beautiful. The possibility for dual probes monitoring both the motor temperature and controller temeprature is what I (and I guess the majoritiy of e-bikers here) really need. Yet, the temperature range is not sufficient, it goes from -10 to 60 Centigrade (I dunno how much that is in Farenheit) for one model and from -20 to 120 Centigrade ont he other. And, the X5 motor (5305) can sustain 140 degrees Centigrade with no problem if proper venting and cooling is arranged. If you could find a similar model but with a temperature range of -60 to at least +200 that would be more convenient for X5 use.
Ok guys....some one really needs to get the scalable meter I posted at the top of the thread.
It should be very simple to set it up with the proper thermocouple and scale it to the proper temp range. A whole lot simpler and easier than taking apart a motor to install a temp plug!
