LED downlights
LED downlights
Postby Kurt » Wed Sep 28, 2011 6:39 pm
We have 50w halogen down lights in our house. I really like the brightness and spectrum/colour they give off. What I don't like is each one burns 50w + another 5- 10w or so for the transformer. Each one giving off a good 45w of heat is another issue I don't like bad in summer and a fire danger in general.
I have tried GU10 fittings with a CFL globe but the light output,start-up time and spectrum are all rubbish.
I was at a nice restaurant the other day and noticed in there bathroom they had a very bright down lights that also had a warm tone. On closer inspection i could see they were LED.
I did a bit of research online and came to the conclusion that a 9w led would be a 1-1 replacement for my 50w halogen. I ordered 6 9w - 3x3w GU10 style 240v LED's online and converted my down light fittings to GU10 so i could do away with the transformer losses. The leds were about $14 each. I installed the 6 leds. Two in the kitchen. Two above the dining table and one in the passage and lounge room. This covers the main lighting we use 90% in out house. I was disappointed with the light output.The light spectrum wasn't bad they had a warm colour but the brightness was only 1/2 that of a 50w halogen.
This is what I purchased. I am now using them to replace the 6 - 50w halogens in My home theatre room.They are fine for this room so are not going to wast. its a shame they don't have the balls for the main living areas I intended to use them for.
Beam Angle: 60 Degree- (Same as my halogens)
CCT: 3000K
Lumens:600-650lm
After doing some more research it seams a 50w halogen is around 900 - 1000lm.I would say the led's I have would be closer to 500lms as they only feel 1/2 as bright.
My question is are there any true LED 50w halogen replacement globes that have the balls to be a true 1-1 replacement? I am starting to think 900lm minimum perhaps 15w led. Or perhaps just better quality globe?
Kurt
Kurt
Re: LED downlights
Postby neptronix » Wed Sep 28, 2011 6:48 pm
Yeah....
Let me tell you straight up, LEDs really do struggle to create the kind of 'natural' light that halogens and plain vanilla incandescents do. LED light tends to be peaky and focused.
You'll have hunt around a lot and maybe get into the spendy stuff to get the kind of lighting you're looking for.
Sorry i don't have any recommendations, but i'll tell you this: like a lot of newer and more energy efficient tech, these tend to overpromise and underdeliver. Go for the big overpowered stuff.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Re: LED downlights
Postby boostjuice » Wed Sep 28, 2011 6:53 pm
Kurt wrote:After doing some more research it seams a 50w halogen is around 900 - 1000lm.I would say the led's I have would be closer to 500lms as they only feel 1/2 as bright.
Human sight and hearing is logorithmic in sensitivity. If the LED replacements look half as bright, its likely the output is only ~1/10th of the Halogens
boostjuice
Re: LED downlights
Postby Kurt » Wed Sep 28, 2011 7:20 pm
I feel you do get what you pay for with this kind of technology. There are some lamps selling for $10 each and others $150. Although that said with bike light's price doesn't always reflect output. I remember when I first purchased my magic shine led light for my ebike. it cost under $100 delivered and you would have played $400 for something similar local at a bike shop.
One thing I noticed is my magic shine light puts out a lot of heat. I guess its driving the led hard. The cheaper led downlights tend to not have much heat sinking and don't get more than warm.The more expensive led down lights tend to have HUGE heat sinks and I am guessing they also drive the led harder and give off more light.
The leds that claim to be 900lm or more tend to be 15w models. and usually closer to $100 each. If i was to replace the 6 main used halogens in my house that would be $600. and consume 90w instated of 330w so I would be saving 240w each hr. Roughly 1kwh a day for 5 1/2 hrs use. 1kwh is 25c in Australia. It would take 6 1/2 years to pay its self off at today s electricity rates.
For $600 I could add another 250w panel to my 1500w home pv system and that would give me about 1kwhr extra in summer :? actually more because the electricity provider pays me 50cents for every kw fed back into the grid and only charge me 25 cents a KW. Perhaps I should just invest in more PV's
Kurt
Kurt
Re: LED downlights
Postby amberwolf » Thu Sep 29, 2011 4:30 am
Ask Texaspyro what he used. He just finished redoing his whole house, including lights like yours, and I have a feeling he's not easy to satisfy when it comes to lighting. ;)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Re: LED downlights
Postby voicecoils » Mon Nov 14, 2011 6:42 am
You can trial a 10W Philips LED downlight for $1 here:
http://www.negergy.com.au/directory/philips-mr16-master-led/
They are supposed to be one of the best. I recently bought 20 halogen downlights to create a battery discharge load from someone who had just installed the Philips 10W LEDs throughout their house.
voicecoils
Re: LED downlights
Postby Ypedal » Mon Nov 14, 2011 7:48 am
I've toyed with these and no joy yet, as outlined above it's either way too expensive to justify or just not bright enough..
i got got some dimmable's from ebay a while back, however one blew up because you have to use a specific type of dimmer and mine was not on that list.
the 2nd one i am still using in my bedroom as a nigh stand light with a simple on/off and it's been reliable but 6w only does so much.
I've switched from flueo 40w's in the kitchen to halogen and like it a lot more.. warmer light is comforting.
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Re: LED downlights
Postby Spacey » Mon Nov 14, 2011 8:28 am
Surely you could put some Cree uber lights in there, my 900 Lumen Cree light chucks out a silly amount of light at 4W
Spacey
Re: LED downlights
Postby Hillhater » Mon Nov 14, 2011 3:52 pm
voicecoils wrote:You can trial a 10W Philips LED downlight for $1 here:
http://www.negergy.com.au/directory/philips-mr16-master-led/.
:shock: Im sure they are good but at $54 a pop, ... they would cost me over $1k just to replace my kitchen lamps !
F**'' that !! ...are they having a larf ?? :evil:
Hillhater
1.21 GW
1.21 GW
Re: LED downlights
Postby Miles » Mon Nov 14, 2011 4:11 pm
I'm looking into getting LED lighting for my workshop. Anybody have experience with these?
Miles
Re: LED downlights
Postby floppy2floppy » Wed Nov 16, 2011 12:17 pm
I have been looking for LED's forever and have tested almost everything on the market. The best LED lights for the price are made by Ecosmart, they sell them at home depot, they are a good color and cheap for LED's. The best one that ecosmart makes is called the ecosmart cree led downlight (http://www.homedepot.com/h_d1/N-5yc1v/R ... ogId=10053), it just dropped in price too. It puts out a color that almost identical to incandescent and it is dimmable, the downlight only fits 6" cans so it probably won't help you with your situation but look on home depots website, all the ecosmart led's are good.
floppy2floppy
Re: LED downlights
Postby JEB » Wed Nov 16, 2011 1:38 pm
For me 2 killer led lights, was to cut off the heads of d cell led mag lights, half to keep them aimed down they are blinders for on comming drivers
JEB
Re: LED downlights
Postby ohzee » Mon Jul 16, 2012 10:42 pm
I tried to replace some of the gu10's last year with LED's , but the light was 10% of the halogen's.
This year I found some that actually replaced all 10 gu10's in my house.
http://www.led-na.com/wp-content/upload ... o-GU10.pdf
This is the light. A battery's plus has them for 20$ each and I promise they are worth it.
Id say it's as much light as the halogen , but it's a bit tighter beam.
Wife was even happy with them. Nice to be able to adjust the light now and not burn my hands.
As stated I am very happy with the purchase.
Ninja Edit - lol noticed this was bumped by spam... Still I stand by my post.
ohzee
Re: LED downlights
Postby cal3thousand » Wed Jul 18, 2012 5:21 pm
Need some LEDs that will easily fit in my refrigerator. Having a glowing hot wire in there is just plain silly.
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Re: LED downlights
Postby Kin » Wed Jul 18, 2012 11:53 pm
Not only does the LED diode need to be a quality one with the right color coating, but the lens need to be proper. For that reason, I think this is an application where you want to spend some money, even if not the very top $150/bulb range. I imagine it's somewhat easier to build a bright flashlight than the delicate balance of indoor lighting.
My friend spent a few years replacing his bulbs, in part because of that cost. Just a few at a time every year, as the lights died out. I've found one place where LEDS really make sense is the laundry room, because both incandescent and even moreso CFLs seemed to have a terrible time with the increased vibration from the machines.
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Re: LED downlights
Postby Hillhater » Thu Jul 19, 2012 5:56 pm
Kin wrote:.... I've found one place where LEDS really make sense is the laundry room, because both incandescent and even moreso CFLs seemed to have a terrible time with the increased vibration from the machines.
Ahh ! OK ..best not fit them in the bedroom either then ! :mrgreen:
Hillhater
1.21 GW
1.21 GW
Re: LED downlights
Postby Kin » Thu Jul 19, 2012 6:46 pm
=D that made me chuckle.
[I guess what you mean though, then, is that the bedroom would be a good place for LEDS]
Kin
Re: LED downlights
Postby cal3thousand » Thu Jul 19, 2012 7:18 pm
I agree, that's why I have motion and light detection LEDs running the length of my bed. Side benefit: keeps the cats from being flattened in the middle of the night.
cal3thousand
Re: LED downlights
Postby Rassy » Thu Jul 19, 2012 8:39 pm
In a local museum where I am a volunteer board member we installed a dozen Phillips LEDs with standard screw in bases on a ceiling track system. We needed to improve the lighting in a 16' x 24' room without improving the base electrical system. Historic building and all.
All my documentation is filed at the museum, but I believe the lights were 15 Watt, 30 degree, 3000 or 3500 Kelvin, and somewhere around 800 luments. They cost $45 each, but have a 50,000 hour life expectancy.
The results were excellent. They have a 2 or 3 second start up delay, come on at full brightness, and run cool. I wouldn't hesitate to install similar quality LEDs anywhere, the only drawback being the initial cost.
-Rassy-
Two Tadpole Trikes, 6X10 9C mid drive, NuVinci CVT Auto Shift, 48V LiFePO4
viewtopic.php?f=28&t=18606
viewtopic.php?f=28&t=47043
Rassy
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 3 guests
