Sticky SWAG
Re: Sticky SWAG
Postby fechter » Tue May 15, 2012 8:23 am
I've used that stuff at work here. Yes, you do need to pry it apart with a screwdriver if the area is large. Mated, the two layers are quite thick compared to normal velcro too.
fechter
Re: Sticky SWAG
Postby Ypedal » Tue May 15, 2012 8:31 am
there must be a surface area to weight factor that makes it hold, yet come off if desired.. :o
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Re: Sticky SWAG
Postby csm » Tue May 15, 2012 12:34 pm
melodious wrote:Got my surprise sample pack at work today. Definitely stuff in there that you won't find at your "run of the mill" hardware stores. The micro velcros are kinda cool too. Don't see a use for them, but it sure is interesting how varied the stuff can be.
post pics of what you got.
csm
Re: Sticky SWAG
Postby melodious » Tue May 15, 2012 1:45 pm
:oops: I don't have camera nor camera phone. I'm still in the dark ages here. I'll tell you this though, it took no time for them to send the samples to work. And if your unsure whether they will be soliciting my contacts, they haven't (yet). I'm sure a multi multi billion dollar company with worldwide recognition really needs to stoop to that level. I'll describe the samples as best I can:
The samples are adhesive strips similar (in size, not strength) to what they sell as those all purpose closet hooks you find at most retail stores. I have 2 batches of 3-4 different strips all 3"x 1/2". Each of those 3-4 strips have a tiny tiny velcro wrap that keep them organized. 1 batch contains "hook & loop" velcro we normally are used to seeing. The other batch have the "mushroom & mushroom" type of configuration. The mushroom configuration has the advantage of being more versatile since you don't have to worry which side gets the "hook" and other gets the "loop". Now that I think about it, I have seen these "mushroom" velcro sold in homedepot, lowe's, etc. Maybe they carry them.
http://www.shop3m.com/3m-fasteners.html
melodious
Re: Sticky SWAG
Postby melodious » Tue May 15, 2012 1:50 pm
I will add this. The industrial version of the "mushroom" dual lock fasteners seem to be the real deal. The OP saying they may be a viable solution to keep your prismatic batteries organized as a single "collective" object definitely has merit. 8)
melodious
Re: Sticky SWAG
Postby csm » Tue May 15, 2012 3:12 pm
melodious wrote:
csm wrote:
melodious wrote:The other batch have the "mushroom & mushroom" type of configuration. The mushroom configuration has the advantage of being more versatile since you don't have to worry which side gets the "hook" and other gets the "loop". Now that I think about it, I have seen these "mushroom" velcro sold in homedepot, lowe's, etc. Maybe they carry them.
thanks for the description. If the "mushroom type" are "Dual Lock", which I think they are, I have seen them for sure at Radioshack. They package them in 4 strips about 3-4 inches long. And they cost about 5 bucks. I think they have trademarked the name "Dual Lock" for this technology.
csm
Re: Sticky SWAG
Postby csm » Tue May 15, 2012 3:14 pm
I am looking for the link to the online form to fill out to order the samples to be mailed to me. The link I saw on this thread seemed to be to Google docs. ??
csm
Re: Sticky SWAG
Postby amberwolf » Tue May 15, 2012 3:23 pm
csm wrote:I am looking for the link to the online form to fill out to order the samples to be mailed to me. The link I saw on this thread seemed to be to Google docs. ??
Maybe try the first post in the thread, instead of what is in someone's signature? ;)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Re: Sticky SWAG
Postby csm » Tue May 15, 2012 4:14 pm
Found it. http://solutions.3m.com/wps/portal/3M/e ... e-Request/
It was hidden in the text. Thanks for your help.
csm
Re: Sticky SWAG
Postby amberwolf » Wed May 16, 2012 11:00 pm
UPS honked a couple times and then tossed a little box on the sidewalk, almost in the street. :( They're getting horrible about deliveries these days! I have gotten to the point where I probably wouldn't even want something if it had to be shipped UPS, even if it was free, because I don't even know if I would get it!
(I happened to be in the back around the side, and heard the truck stop and pull away just before the dogs started barking. Good thing I was there, or someone probably would've either picked it up and taken it, or run it over).
Anyway, here's what they almost didn't deliver:
There are standard velcro hook/loop types, some very thin and fine stuff on the left, to more typical coarser stuff on teh right. Some has adhesive and some is just cloth back.
The newer kind is also in several types, from finer to coarser, including one hard-backed circle that's intended to be screwed or riveted down. I don't think it's quite big enough to hold a Cycle Analyst in place, but two of them probably would be, with one at each end of an LS version, and two corresponding patches on the handlebars or wherever. Then a short-harnessed water-resistant/proof plug to connect the CA to the bike's wiring, and it would make it easy to take a CA off to "stealth" a bike while it's on a rack or wherever. Or to keep the CA out of heavy rain or hail or something.
One of the sets is a "mismatch" of types (intentional, apparently), so that it has four small grips for every large one, arranged in a grid rather than the wavy lines all the others use. Presumably it makes for better grip; I have a hard enough time with all of them and my old fingers that I can't tell if it really does or not.
Came with a card describing the options.
amberwolf
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 7 guests
