Well put around 100 miles of commuting so far.. And I really like it..
One thing I want to work on is setting the regen breaking back to give full regen when activated by the brake sensor. I can't remember which of the commands took that away. course it might be one that causes another thus might be this way for ever. But basicly now you get min regen with the brake switch but could switch it on full with the - button.
Now for the fun.
for the most part I run 3 blips of assist and only some times go to 4. If I run 4 the entire way I end up draining the batterys to much to make it back and forth (24 miles total) with out completely draining one battery or the other (I charge the bionx battery at home and the other at work so they are some times out of balance).
Now with 3 blips you still have assistance above 20mph which is the best part of this mod. or in other words the system no longer gets you to 19mph and then leaves you with no help.
I can easily average 20mph on my commute and best is 22.6 so far.
b.
