I've edited this bit (see above).Drunkskunk wrote:Technical Reference Area could be moved into Electric Vehicle Technology since a tech referance forum makes sence in a section for is part of EV tech
neptronix wrote:4) add a section specifically for controllers.
NeilP wrote:I see motor type sections, but how about a dedicated controller section. Already have a battery secton
Miles wrote:[
What is the compelling reason for having a separate forum for motor drives?
E-Bike General Discussion
General Discussion about electric bicycles, tricycles & velomobiles.
Hub motor Drives Technical
Get all your technical information about hub-motors and controllers, here.
Non-hub Motor Drives Technical
Get all your technical information about Non-hub motor drives, here.
You haven't given a reason.NeilP wrote:So what are you suggesting? Merge hub drives and non hub drives? I think they should be seperate, as should controller based subjects
John in CR wrote:Way too many categories already. It makes things harder to find or worse, interesting things harder to simply run across.
"If it ain't broke don't fix it." Combining and simplifying isn't fixing.
That's a phpbb programming issue, not easily addressed like organizational, categorical stuff. Searches can be refined procedurally (search within results), or search posts by member. Google search within the domain can be handy.John in CR wrote:If you want something to fix, then fix the friggin search function, which is all but worthless.
Sort by clicking the header - like any spreadsheet or table.John in CR wrote:Here's another...Make the members list useful, by either making it searchable, sortable, or at least alpha order. What is it now, by letter and then chronological?
Miles wrote:Any comments on this re-wording?E-Bike General Discussion
Nope. No broken links at all. Just steering things in a slightly more logical direction for people that haven't been here for years.Drunkskunk wrote: there would probably be a lot of broken links if those sections got changed.
Ok. We can change the header if that's your only argument.Drunkskunk wrote:The headder says Motor tech, so someone skimming through may not notice it covers controlelrs too.
Miles wrote:You haven't given a reason.NeilP wrote:So what are you suggesting? Merge hub drives and non hub drives? I think they should be seperate, as should controller based subjects
Ok. Thanks Neil.NeilP wrote:No reason, sorry. I did try and reply but it did not appear it would seem.
I really don't think it's that simple.Njay wrote:Controller section is all electronics talk, motor section is all mechanics talk
Except that the idea is to cut out some of the categories that are mostly there for historic reasons and are no longer needed. Polls can now be run in any forum, so we don't need a separate Poll section, etc.Kingfish wrote:[*]Forums “incorporated” should become sub-forums; I think that concept works well.![]()
Relieving the flow on E-Bike General Discussion is definitely the most urgent need.Kingfish wrote:[*]E-Bike General Discussion is too large and general. Suggest as an idea to creating subcategories, perhaps called “Frames & Forks”, and another called “Gears & Components”. This would divide the daily mucilage in half and make the forum more readable.[/list]
Users browsing this forum: mdd0127 and 3 guests
