TOTW Suggestion (Totally Off The Wall)
Postby salty9 » Thu Aug 09, 2012 12:03 pm
I have noticed that many cyclists need to move their cycles upstairs. This made me wonder whether or not a bike controller could be programmed to operate in "stair" mode. As I see it the bike would be guided and the throttle blipped for each step. Of course really good cyclists would ride up the Stairs :D
salty9
Re: TOTW Suggestion (Totally Off The Wall)
Postby Hillhater » Thu Aug 09, 2012 6:59 pm
What is the issue ?? ...I already "walk" my Ebike up stairs using a normal controller and thumb throttle. ?
Hillhater
1.21 GW
1.21 GW
Postby amberwolf » Fri Aug 10, 2012 1:56 am
Some controllers, like the latest Fusin one I'm testing/reviewing, can operate in "walk" mode to power the bike at walking speed without you having to deal with a throttle. I think on mine you just hold down the buttons for "a while" (10-20 seconds? I forget--have to retry that sometime) and then it sets the throttle automatically at a really low speed. IIRC moving the actual throttle or hitting the ebrake turns it off. Have to recheck that, too.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby Jeremy Harris » Fri Aug 10, 2012 2:06 am
If you're using a Xiechang controller ("Infineon", Keywin, E-Crazyman, Lyen, some Crystalyte etc) then this is easy. Just programme the lowest speed in the controller for something like 10% and add a switch to ground terminal X1 on the board to select this mode. When the switch is selected the controller will then only go to a maximum of about 10% of maximum speed with the throttle wide open.
Jeremy Harris
Postby Hillhater » Fri Aug 10, 2012 5:22 am
Ahh ! , I guess this is another advantage of a mid drive.
Select low gear, and simply "tickle" the throttle for stair climbing on an unmodded $20 controller 8)
Hillhater
1.21 GW
1.21 GW
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 4 guests
