Another RG250 with Colossus Motor
Re: Another RG250 with Colossus Motor
Postby SplinterOz » Wed Oct 19, 2011 4:44 am
markobetti wrote:REALLY ? well done Luke. If its open info ; what was the price for that piece of art ?
Luke has been doing a lot of his time for free as he likes this stuff and doesn't get enough. Getting the 4 plates CNC'd out of the plastic and the material will be about $780AUD. Luke has spent about 5 hours or so at normally $100AUD an hour.
So far all the work Mobile Fabrications has done (Sand Blast and powder coat the wheels, design and build motor mount, design and build sprocket carrier, design and build rear disk carrier) has been about $1700AUD. Not cheap but much better quality than I can do.
SplinterOz
In the Capital of Australia
http://rgelectric.wordpress.com
SplinterOz
Postby markobetti » Wed Oct 19, 2011 4:54 am
wow , more expensive than the motor...But i agreee quality seems great and the design also
markobetti
Postby voicecoils » Wed Oct 19, 2011 6:08 am
That motor mount is a work of art to see in person.
The headway cell holder design looks great too. Have you settled on a material to do them in?
Great progress Tony!
voicecoils
Postby Philistine » Wed Oct 19, 2011 7:05 am
I went over on the weekend and got to see it in person, also got to meet Chris and his bike. Only got to see Tony's bike in action though as Chris and Tony were de-agniing Chris's bike.
I was very impressed to see Tony's bike in action, it is going to turn heads around quiet old Canberra I dare say (amongst motorcycle enthusiasts anyway). The Colussus is an impressive motor.
I felt very emasculated by a Colussus and Twin Agni bikes with my 3kw frock Greyborg. Great stuff.
Phil.
Philistine
Postby Goped ESR750 » Wed Oct 19, 2011 6:17 pm
wow. Thats pricey. I love the motor mount though.
Do have the space for machine tools at home. You probably could a got a decent size lathe and mill and machined your own parts manually. I tried to manually make as much possible. Save so much money, I have access to huge lathes and mills though, which is a great bonus.
Goped ESR750
Postby SplinterOz » Wed Oct 19, 2011 8:15 pm
Thanks for the compliments on the work, I will pass them on to Luke.
I do have some room at home for tools, but I think buying a lathe, mill, drill press, 3d software etc to build one bike would not be economical. My machining skills are limited at best so I would probably use twice the materials and I will still have to seek help for the design work.
If my plan was to build multiple bikes or do continuous improvement on this bike then buying the gear might be worth it, however I want a nice electric bike to ride every day and other than the Zero none are on sale in Australia.
SplinterOz
SplinterOz
New front brakes - start of the final assembly
Postby SplinterOz » Sat Nov 05, 2011 1:26 am
Today I got my new front disc brakes from Metalgear up in Queensland. They take the mounts from mine and attach new rotors. They look good and make me feel a lot better about the braking setup.
New Discs by Splinter, on Flickr
I have also fitted a temp sensor into the motor that will work with the Kelly controller. Originally this prototype had a cheap thermistor that was wired incorrectly. The new sensor is amongst the coils and should detect the temperature very accurately. I have also recovered the wired coming out of the motor for all the sensor wires.
New Temp Sensor by Splinter, on Flickr
So far for this motor I have repositioned all the Hall sensors, replaced the temp sensor, rerun the sensor wires, and changed all the bearings. I will be re-assembling it for the last time over the next week (work permitting) and it will be mounted in the bike never to be removed again (unless I get a production version soon).
SplinterOz
SplinterOz
Postby Jay64 » Mon Nov 07, 2011 9:26 pm
Sorry, I must have missed it. Which Kelly controller are you using for the big colossus? I'm guessing that if it can handle that motor, it should definitely be able to handle my 7kw colossus motor.
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby SplinterOz » Mon Nov 07, 2011 10:23 pm
I am using the KBL72501B controller from Kelly, 500amp peak 72 volts nominal. Seems to be handling things well. :)
NOTE: I did get the High Speed option.
SplinterOz
SplinterOz
Postby Arlo1 » Mon Nov 07, 2011 10:25 pm
SplinterOz wrote:I am using the KBL72501B controller from Kelly, 500amp peak 72 volts nominal. Seems to be handling things well. :)
Come on crank it up all ready! :mrgreen: I want to see someone make this motor rip!
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUFF Incl. Mosfets, Current sensors and Nomex paper.
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
Arlo1
Postby Jay64 » Tue Nov 08, 2011 12:37 pm
Cool thanks for the info. I think maybe I'll try something like that and see if it will handle the smaller colossus.
Jay64
1 GW
1 GW
Postby SplinterOz » Thu Dec 08, 2011 7:38 pm
Ok after weeks of work and jury duty getting in the way I have finally got to the next step....
The battery mounting plates have arrived and I will be constructing the pack over the weekend.
Just to show how this will mount up I took some photos today...
Battery Mounts by Splinter, on Flickr
That should give you an idea on how the pack goes together and how it will mount up.
SplinterOz
SplinterOz
Postby AussieJester » Thu Dec 08, 2011 8:12 pm
Thats very slick SplinterMaN! Lookin' forward as i am sure you are, of
seeing this dropped into the frame!
KiM
AussieJester
Postby SplinterOz » Thu Dec 08, 2011 8:31 pm
Hopefully on Sunday it will be in... and then a lot of wiring up .
SplinterOz
SplinterOz
Postby jonescg » Thu Dec 08, 2011 8:46 pm
NICE! Luke is a handy fella.
Voltron the Electric RG250 - Dual Agnis, Kelly 1200A controller, 6 kWh of A123 cells from Cell_Man and a shitty old chassis from 1985 :| Top speed 180 km/h, max current 600 A @ 100 V.
VoltronII 8)
Say no to spaghetti junction LiPo! Assembled Hi-power LiPo packs of any size!
Come on Casey! If you want prototype racing, throw your leg over something with lithium in it :D
jonescg
Postby markobetti » Fri Dec 09, 2011 2:36 am
SplinterOz wrote:Ok after weeks of work and jury duty getting in the way I have finally got to the next step....
WOW, BEAUTIFULL ... Splint....Really clever
markobetti
Postby SplinterOz » Fri Dec 09, 2011 3:51 pm
Thx guys more updates today after I spend most of it in the shop.
SplinterOz
SplinterOz
Postby SplinterOz » Fri Dec 09, 2011 9:38 pm
OK I was wrong about the material. Luke first talked to the material suppliers about it and they were talking Acetyl. What they settled on however is Polyethylene (High-density polyethylene I believe). I will get the invoice from the guys next week and confirm. They were supplied the weight of the cells and the number of mounting points and this was the recommendation.
All four plates weight 3.6kg each plate is 15mm thick.
SplinterOz
SplinterOz
Postby SplinterOz » Sun Dec 11, 2011 2:17 am
Ok here is the plates in place... will be building the spacers etc early this week and wiring up the battery later this week...
Battery Mount position by Splinter, on Flickr
SplinterOz
SplinterOz
Postby jonescg » Sun Dec 11, 2011 3:01 am
As much as they sag, are heavy and low energy density, Headways sure are easy to put together. Looking good mate!
VoltronII 8)
jonescg
Postby SplinterOz » Sun Dec 11, 2011 3:13 am
jonescg wrote:As much as they sag, are heavy and low energy density, Headways sure are easy to put together. Looking good mate!
Other than all those bad things... I am looking forward to having the full pack running.
SplinterOz
SplinterOz
Postby SplinterOz » Sat Dec 17, 2011 12:01 am
Ok so I have the bike home with some threaded rod, bolt and spacers to work out the layout of all the components on the bike.
Here is a shot of the way the plates have been machined to hold the batteries in place.
Battery Mount Size Layout by Splinter, on Flickr
Note the spacers so all the pressure is not on the batteries themselves.
See they will mount straight through.
Setup with all batteries in place so I can calculate and drawup the electrical connections.
Bike still feels light easy to move and lift of the stand etc....
SplinterOz
SplinterOz
Postby jonescg » Sat Dec 17, 2011 5:33 am
Tony, she looks awesome! Very neat job :)
You still have room for an on-board charger under the tank? (Which I still haven't sent you the mould for :x after Christmas OK?)
Or is that where the controller goes? Either way, it looks very professional.
VoltronII 8)
jonescg
Postby SplinterOz » Sat Dec 17, 2011 5:37 am
Current plan has the BMS and Controller under the tank... 12v system behind the battery pack.. Charger somewhere if I can fit it.. otherwise off board.
That is the main reason it is home so I can layout all of the other components. Pieces of the jigsaw are fitting together.
SplinterOz
SplinterOz
Postby SplinterOz » Sat Dec 17, 2011 11:34 pm
Now I have the bike and the battery pack back home I am working on how I will fit all the components into the system.
Here is a shot showing the BMS, contactors and fuse. They will all fit nicely on top of the centre battery plates.
BMS and controller layout by Splinter, on Flickr
Now I have replaced the BMS etc with a plastic box of about the same size to see if the controller fits... and yep it looks good.
The tank (hollowed out) will fit well over all that. I plan to put all the 12v gear in the gap above the rear shock absorber.
Any comments? Do you think it will work that way?
SplinterOz
SplinterOz
PreviousNext
Return to E-Scooter and Motorcycle General Discussion
Who is online
Users browsing this forum: No registered users and 2 guests
