Another RG250 with Colossus Motor
Re: Another RG250 with Colossus Motor
Postby SplinterOz » Sun May 13, 2012 12:59 am
Ok so I can't measure for cr@p... but with a little work I can use this box.
BMS fitted
BMS Mounted - 00 by Splinter, on Flickr
12 volt and control plugs
BMS Mounted - 01 by Splinter, on Flickr
Bad Measurement on my part (fixable)
BMS Mounted - 03 by Splinter, on Flickr
Fan if needed
BMS Mounted - 05 by Splinter, on Flickr
Plugged In
BMS Mounted - 06 by Splinter, on Flickr
Lights On
BMS Mounted - 07 by Splinter, on Flickr
If I could get a week off work I would love to get this done and dusted.
SplinterOz
In the Capital of Australia
http://rgelectric.wordpress.com
SplinterOz
Postby jonescg » Sun May 13, 2012 1:44 am
:lol: Love the hole cutting Tony :D Looks like something I'd do, except there wouldn't be a straight line anywhere.
Must be so frustrating for you to be so close, yet have next to no time to finish it :(
Voltron the Electric RG250 - Dual Agnis, Kelly 1200A controller, 6 kWh of A123 cells from Cell_Man and a shitty old chassis from 1985 :| Top speed 180 km/h, max current 600 A @ 100 V.
VoltronII 8)
Say no to spaghetti junction LiPo! Assembled Hi-power LiPo packs of any size!
Come on Casey! If you want prototype racing, throw your leg over something with lithium in it :D
jonescg
Postby SplinterOz » Sun May 13, 2012 4:16 am
jonescg wrote:Must be so frustrating for you to be so close, yet have next to no time to finish it :(
Indeed it is... as Arlo1 would say... Hurry Up!
SplinterOz
SplinterOz
Postby Arlo1 » Sun May 13, 2012 10:06 am
lol I was thinking that before I even clicked on your thread :)
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Panels - or when is a tank not a tank.
Postby SplinterOz » Sat May 19, 2012 2:12 am
Today Luke dropped over with a few of the panels that have been painted. The rest will come next week as the guy is having problems with the fiber-glass panels and bubbling. (sorry for the photo quality I was loosing light fast)
Some Panels fitted by Splinter, on Flickr
Some panels fitted by Splinter, on Flickr
New tank by Splinter, on Flickr
With nose cone by Splinter, on Flickr
The nose cone is not yet done, this is the older one that is a little broken.
So what to you call a tank that does not hold fluid anymore?
SplinterOz
SplinterOz
Postby jonescg » Sat May 19, 2012 3:46 am
Looking good Tony! The tank cover looks very professional! I should get around to designing a better cover for Voltron one day.
Does it turn a wheel yet?
VoltronII 8)
jonescg
Postby SplinterOz » Sat May 19, 2012 4:35 am
jonescg wrote:Does it turn a wheel yet?
Not with this battery pack but prior to the pack construction yep. Next two weeks is to build the controller and contactor mounts. Then ride again.
SplinterOz
SplinterOz
Postby SplinterOz » Sat Jun 02, 2012 3:37 am
Ok so a few more panels later and a wet, dank, dark day....
IMG_20120603_162900 by Splinter, on Flickr
IMG_20120603_162600 by Splinter, on Flickr
SplinterOz
SplinterOz
Postby SplinterOz » Sat Jul 07, 2012 11:56 pm
Ok due to the fact that work is taking over my life, winter is here and in my tin shed it is normally -2 in the evenings I haven't done much.
But what I have done is looking good.
Panels fitted - Semi Naked Style by Splinter, on Flickr
SplinterOz
SplinterOz
Postby jonescg » Sun Jul 08, 2012 12:27 am
Looking good Tony! Did you get all of the panels re-made in fibreglass? Or just tidy up the ones it came with?
Sorry to hear about work taking up valuable e-moto time. I have the opposite problem, except my e-moto time isn't particularly valuable :lol:
Why is the motor still out?
VoltronII 8)
jonescg
Postby SplinterOz » Sun Jul 08, 2012 4:50 am
jonescg wrote:Looking good Tony! Did you get all of the panels re-made in fibreglass? Or just tidy up the ones it came with?
Ducktail and side panels are original. Nosecone and middle panels are fibreglass, lower ones are currently original (not on bike)
Motor is still out as I am yet to get the mounting plate for the controller, contactor etc. Once I have that on I will be able to get everything bolted up in it's final location.
SplinterOz
SplinterOz
For Arlo1 and jonescg
Postby SplinterOz » Sun Jul 15, 2012 6:16 am
Yes that is my bike, yes it goes, yes the Colossus is running fine.
Not as much getup as I would like... will be looking into that.
SplinterOz
SplinterOz
Postby jonescg » Sun Jul 15, 2012 6:21 am
I'm guessing the jacket is for the climate, not for safety reasons :D
Nice work Tony! I'm impressed the little colossus does the job, but I can understand the need for more power :)
Should be good for some on-board footage now :)
VoltronII 8)
jonescg
Postby Lebowski » Sun Jul 15, 2012 6:23 am
what kind of controller are you using ? Voltage, current, phase amps ?
Lebowski
Postby SplinterOz » Sun Jul 15, 2012 6:35 am
jonescg wrote:I'm guessing the jacket is for the climate, not for safety reasons :D
Yes a max of 9 here today. To be honest that is one of the reasons not much has been done... my shed is cold.
The little colossus is not working hard just the controller not pushing it yet.
SplinterOz
SplinterOz
Postby SplinterOz » Sun Jul 15, 2012 6:40 am
Lebowski wrote:what kind of controller are you using ? Voltage, current, phase amps ?
Kelly controller, 72 volts, 500amps max for the controller. Currently I am not pully more than 100amps from the battery.
SplinterOz
SplinterOz
Postby Arlo1 » Thu Jul 19, 2012 1:09 am
Congrats man can't wait to see you up the power to ~ 1000 amps! :)
Arlo1
Postby SplinterOz » Thu Jul 19, 2012 1:13 am
Arlo1 wrote:Congrats man can't wait to see you up the power to ~ 1000 amps! :)
Same here. I am away this weekend with the TTXGP over here, should be back at it next week.
SplinterOz
SplinterOz
Postby Ratking » Tue Aug 28, 2012 5:57 am
Oh man I want to see this motor being pushed a bit. Fantastic work so far. I hope you get what you want out of the build.
I'm interested to hear about your opinion about having a compact gearbox. Seems to me that we could get a much greater range of acceleration and speed.
Ratking
Postby Astropower » Wed Aug 29, 2012 4:24 am
Nice job you done here,
Why you dont add transmission? -for better acceleration and the ability to drive uphill, and most importantly, it saving a lot of battery energy.
Astropower
Postby SplinterOz » Wed Aug 29, 2012 4:38 am
Astropower... main reason for no transmission is no room in a little 250 frame. :)
SplinterOz
SplinterOz
Postby Arlo1 » Wed Aug 29, 2012 9:30 am
As a rule the same performance benefit you can get from a transmission can be had by just using a bigger motor. The end result would weigh the same and give you about the same increase of power. BUT a bigger motor has fewer moving parts to brake and is simpler to install and maintain!
Colossus can run 20-30HP continuous with a good cooling system and their is signs showing it should take 50kw (67HP) for ~10 sec! Because of its efficiency maybe more but it will also depend on batteries and the voltage Splinter uses. Right now Splinter is running around 10hp or less. So once he ups the power he will have a fairly quick bike and hills should not be a problem!
Arlo1
Postby Astropower » Thu Aug 30, 2012 2:48 am
You can read this article and see the test results of Gear and NON-Gear with benefits when installed gearbox.
http://www.fallbrooktech.com/sites/default/files/videos/LEV_CVT_Whitepaperrev10.pdf
This is Automatic Gear system.
I have this system on my Scooter, (see the rear wheel, that is not Hub motor)
viewtopic.php?f=35&t=38385
i can tell you, that i got huge differernt when i turn off the gear and turn on the gear. and it save me space because it is hub gear wheel.
i can drive any place and any hill, with 180KG Load of two people without problem. with 1.2KW motor only (1.9KW Peak maximum i get in my scooter screen).
Astropower
Postby SplinterOz » Sat Nov 10, 2012 3:34 am
ok so it has been weeks and weeks. Most of this time has been at work (upwards of 70 hours most weeks) or sick, laid out all last week.
However I have managed to layout all the components how I want them, now to cut and mount them up in 1mm or 2mm aluminum.
IMG_20121105_203900 by Splinter, on Flickr
I also got some time to put on the new handle bars with switch gear and the [url="http://www.jozztek.com/shop/throttles/44-billet-aluminium-throttle.html"]Jozztek throttle[/url].
It is starting to look really good, this coming week and weekend should have all the components fully mounted and my wiring loom starting.
Switch gear by Splinter, on Flickr
Right Hand Grip by Splinter, on Flickr
Overview by Splinter, on Flickr
SplinterOz
SplinterOz
Postby dr_frost_dk » Wed Nov 14, 2012 1:07 pm
looking good, did not read the whole thread, but a good tip on cooling (if you didn't do LC) is to sand (fine) down the face off the motor and maybe in between if it is made like the 80/100 + apply cooling paste, this will pull heat out of the stator and windings, this has helped tremendous on my Electro Ciao and will let the motor handle more power and run cooler
dr_frost_dk
PreviousNext
Return to E-Scooter and Motorcycle General Discussion
Who is online
Users browsing this forum: No registered users and 3 guests
