Another RG250 with Colossus Motor
Re: Another RG250 with Colossus Motor
Postby SplinterOz » Sun Jul 15, 2012 6:40 am
Lebowski wrote:what kind of controller are you using ? Voltage, current, phase amps ?
Kelly controller, 72 volts, 500amps max for the controller. Currently I am not pully more than 100amps from the battery.
SplinterOz
In the Capital of Australia
http://rgelectric.wordpress.com
SplinterOz
Postby Arlo1 » Thu Jul 19, 2012 1:09 am
Congrats man can't wait to see you up the power to ~ 1000 amps! :)
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby SplinterOz » Thu Jul 19, 2012 1:13 am
Arlo1 wrote:Congrats man can't wait to see you up the power to ~ 1000 amps! :)
Same here. I am away this weekend with the TTXGP over here, should be back at it next week.
SplinterOz
SplinterOz
Postby Ratking » Tue Aug 28, 2012 5:57 am
Oh man I want to see this motor being pushed a bit. Fantastic work so far. I hope you get what you want out of the build.
I'm interested to hear about your opinion about having a compact gearbox. Seems to me that we could get a much greater range of acceleration and speed.
Ratking
Postby Astropower » Wed Aug 29, 2012 4:24 am
Nice job you done here,
Why you dont add transmission? -for better acceleration and the ability to drive uphill, and most importantly, it saving a lot of battery energy.
Astropower
Postby SplinterOz » Wed Aug 29, 2012 4:38 am
Astropower... main reason for no transmission is no room in a little 250 frame. :)
SplinterOz
SplinterOz
Postby Arlo1 » Wed Aug 29, 2012 9:30 am
As a rule the same performance benefit you can get from a transmission can be had by just using a bigger motor. The end result would weigh the same and give you about the same increase of power. BUT a bigger motor has fewer moving parts to brake and is simpler to install and maintain!
Colossus can run 20-30HP continuous with a good cooling system and their is signs showing it should take 50kw (67HP) for ~10 sec! Because of its efficiency maybe more but it will also depend on batteries and the voltage Splinter uses. Right now Splinter is running around 10hp or less. So once he ups the power he will have a fairly quick bike and hills should not be a problem!
Arlo1
Postby Astropower » Thu Aug 30, 2012 2:48 am
You can read this article and see the test results of Gear and NON-Gear with benefits when installed gearbox.
http://www.fallbrooktech.com/sites/default/files/videos/LEV_CVT_Whitepaperrev10.pdf
This is Automatic Gear system.
I have this system on my Scooter, (see the rear wheel, that is not Hub motor)
viewtopic.php?f=35&t=38385
i can tell you, that i got huge differernt when i turn off the gear and turn on the gear. and it save me space because it is hub gear wheel.
i can drive any place and any hill, with 180KG Load of two people without problem. with 1.2KW motor only (1.9KW Peak maximum i get in my scooter screen).
Astropower
Postby SplinterOz » Sat Nov 10, 2012 3:34 am
ok so it has been weeks and weeks. Most of this time has been at work (upwards of 70 hours most weeks) or sick, laid out all last week.
However I have managed to layout all the components how I want them, now to cut and mount them up in 1mm or 2mm aluminum.
IMG_20121105_203900 by Splinter, on Flickr
I also got some time to put on the new handle bars with switch gear and the [url="http://www.jozztek.com/shop/throttles/44-billet-aluminium-throttle.html"]Jozztek throttle[/url].
It is starting to look really good, this coming week and weekend should have all the components fully mounted and my wiring loom starting.
Switch gear by Splinter, on Flickr
Right Hand Grip by Splinter, on Flickr
Overview by Splinter, on Flickr
SplinterOz
SplinterOz
Postby dr_frost_dk » Wed Nov 14, 2012 1:07 pm
looking good, did not read the whole thread, but a good tip on cooling (if you didn't do LC) is to sand (fine) down the face off the motor and maybe in between if it is made like the 80/100 + apply cooling paste, this will pull heat out of the stator and windings, this has helped tremendous on my Electro Ciao and will let the motor handle more power and run cooler
dr_frost_dk
Postby SplinterOz » Sun Nov 18, 2012 2:53 am
I have about two weeks to get the bike ready for the Canberra EV festival on the 1st December.
Man do I have a lot of work to do.
Ok first I have the gauges on the "dash" and the wiring started.
Dash Setup by Splinter, on Flickr
I have also setup the mounting for the controller. This will go under the tank along with the BMS, DC/DC converter and low amp high voltage fuses.
Here is a shot of the controller in the mounting bracket.
Controller on mount by Splinter, on Flickr
A couple of it positioned on the bike.
Controller mounted by Splinter, on Flickr
Last edited by SplinterOz on Sun Nov 18, 2012 2:54 am, edited 1 time in total. View post history.
SplinterOz
SplinterOz
Postby jonescg » Sun Nov 18, 2012 3:35 am
Looking slick Tony! I love the dashboard. Is that a D-sub with balance taps I see?
Voltron the Electric RG250 - Dual Agnis, Kelly 1200A controller, 6 kWh of A123 cells from Cell_Man and a shitty old chassis from 1985 :| Top speed 180 km/h, max current 600 A @ 100 V.
VoltronII 8)
Say no to spaghetti junction LiPo! Assembled Hi-power LiPo packs of any size!
Come on Casey! If you want prototype racing, throw your leg over something with lithium in it :D
jonescg
Postby SplinterOz » Sun Nov 18, 2012 4:22 am
jonescg wrote:Looking slick Tony! I love the dashboard. Is that a D-sub with balance taps I see?
Indeed it is... hopefully over the next day or so the BMS will be mounted and plugged in.
SplinterOz
SplinterOz
Postby SplinterOz » Sat Nov 24, 2012 4:15 pm
Quick update with all the work I have done this past week to be ready for the festival.
To be ready for engineering requires the last of the 12volt wiring loom... and well that is it.
SplinterOz
SplinterOz
Postby jonescg » Sat Nov 24, 2012 8:23 pm
Looking very neat Tony!
See the good thing about taking 3 years to build a bike is that it will look really good by the time you're done. You really can't rush these things. The way all of your components fit so neatly in the bike is a testament to your patience :)
Have fun at the Canberra EV festival!
VoltronII 8)
jonescg
Postby SplinterOz » Sat Nov 24, 2012 8:34 pm
Chris, thanks a lot I am really happy with the fit and finish. There is a bit yet to do, I have blown the seals on one front fork (totally my stupid fault) and I have to get the 12 volt completed but I am hoping to have the whole thing going and registered by the end of January.
Just a couple of shots before I put on the chain and make sure it all goes still :)
Elmoto Glamour Shot by Splinter, on Flickr
SplinterOz
SplinterOz
Postby SplinterOz » Tue Jan 08, 2013 4:15 am
... and now it goes as good as it looks.
SplinterOz
SplinterOz
Postby jonescg » Tue Jan 08, 2013 6:57 am
Love the throttle management skills :lol:
"......Fark it's keen!" :D Love it.
Good stuff Tony. Keep cool eh? We've had more than enough heatwave over here.
VoltronII 8)
jonescg
Postby dingoEsride » Tue Jan 08, 2013 8:03 am
Thats sweet, way better than the two strokes of old
ride like the wind
dingoEsride
Postby Gregory » Tue Jan 08, 2013 9:08 am
Wow, great job. Looks sweet and seems to go pretty fast. I can't believe that motor can put out so much power.
Will you be able to register it with red HV wiring?
1) x5305 Hub Motor in a 24" Sun rim with 10G spokes, Kelly 72601 controller, 74V 10Ah Turnigy LiPo 20C Battery and CycleAnalyst
2) Mac 10T rear hub in a 700C "comfort bike" 15S 5Ah LiPo, stock 28A Xie Cheng controller
Gregory
Postby SplinterOz » Tue Jan 08, 2013 3:47 pm
Gregory wrote:Wow, great job. Looks sweet and seems to go pretty fast. I can't believe that motor can put out so much power.
No I won't, the red wires were from the bench setup for he motor. My orange HV wires are back on. I have to change some of the other wiring for the new controller as well.
His feels so quick, I have to put it side by side with some standard bikes.
SplinterOz
SplinterOz
Postby Byte » Wed Jan 09, 2013 3:55 pm
Definately do that! Would be nice to see.
Nice video! :mrgreen:
Bergli
Turnigy 80-100 130kv
10S 16Ah LiPo
Castle Creations HV 160
Byte
Postby SplinterOz » Mon Jan 28, 2013 5:29 am
Quick update... 12 volt wiring mostly done.
SplinterOz
SplinterOz
Postby jonescg » Mon Jan 28, 2013 5:37 am
I need to learn how to do wiring harnesses neatly... Tantalisingly close mate!
VoltronII 8)
jonescg
Postby SplinterOz » Mon Jan 28, 2013 5:43 am
jonescg wrote:I need to learn how to do wiring harnesses neatly... Tantalisingly close mate!
Well don't learn from me... It is nowhere near as neat as I wanted it.
The project might have to park for another month as Dani goes in for surgery in two weeks..
SplinterOz
SplinterOz
PreviousNext
Return to E-Scooter and Motorcycle General Discussion
Who is online
Users browsing this forum: floatingdog and 7 guests
