Basically I want it to look something like this:
Does anyone know how to draw something as simple as this in Eagle??
Cheers,
CHRIS
jonescg wrote:......, but the jumper leads were in a bad way
Hillhater wrote:Probably a little late for you jonescg, but i thought this may interest you..
http://vimeo.com/34702692
..Any idea who "mic ofOz" may be ?
It's all good, but thanks for the offer! I'll try and come to one of the races in Victoria this year.jonescg wrote:I owe you one! Next time you're on your way over to South Africa, drop in to Perth and I'll shout you a beerNah seriously, name your price, that's awesome.
Malcolm wrote:I nearly posted that video myself, but if I've understood right it means that all the clamping force has to come from a pair of threaded plastic rods. Plastics tend to creep under load, so the clamping force will gradually decrease with time. One possibility would be to use steel threaded rod with a series of insulating sleeves around it. The total length of the sleeves would have to be slightly less than the clamped length of the rod. The spacers would also have to be incompressible, so plastic is out again.
full-throttle wrote:It's all good, but thanks for the offer! I'll try and come to one of the races in Victoria this year.jonescg wrote:I owe you one! Next time you're on your way over to South Africa, drop in to Perth and I'll shout you a beerNah seriously, name your price, that's awesome.
Gordo wrote:..... I expect to see Jack R. build a pack using this method soon.
.....I've made this module THREE TIMES in prototype form. The last has some 48 cells in a 4P12S configuration for a 40 volt 75 Ah module. It is 19.75 inches long, about eight inches high and about nine inches wide and weighs about 75 lbs. It represents a 3 kWh pack.
The prototype has spaghetti wiring on it for the Cellog 8S modules to monitor individual cell voltages. We bottom balanced the entire set of cells at 2.75 volts during assembly. We'll be charging it and discharging it to see what happens to the individual cells. Under load, poor connections and so forth show up.
This is kind of a leap of faith. We used nylon threaded rod and some pvc nuts and by following Mic's instructions and including a nut with every insulated piece, we think we've managed the clamping forces as well as they can be managed. But we do not want flexing between the tabs and the spacers in the vibrating environment of a vehicle. So we've cast the ENTIRE thing in the urethane resin we've been playing with.
Gordo wrote:We have used that nylon rod for many years to prevent electrolysis on fishing gear, mounting 200 lb pullers with them. The gear never comes loose.
jonescg wrote:They are actually copper ones, just rather flimsy at the business end. The only time a termination got hot was when the connection was poor and the heat generated was sunk buy the 2 mm copper plate. Even then it wasn't that bad.
Provided every connection I do is a solid one, there shouldn't be any overheating worth mentioning under hard use.
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: No registered users and 3 guests
