Comet torque converter to rear 10" wheel mod
Postby ioniscool » Wed Dec 21, 2011 8:20 am
I wonder if some has tried to use a comet torque converter from http://gokartsusa.com/GTC-Comet-TAV2-30-Torq-A-Verter.aspx but using the secondary belt pulley to mount DIRECTLY to the rear wheel 10" outer diameter and not sprocket to the wheel sprocket. I wonder how much effieciency could be generated from this setup. Using a me0909 3800 rpm unloaded and 2500rpm loaded.
ioniscool
Re: Comet torque converter to rear 10" wheel mod
Postby Hillhater » Wed Dec 21, 2011 6:19 pm
ioniscool wrote: I wonder how much effieciency could be generated from this setup. Using a me0909 3800 rpm unloaded and 2500rpm loaded .
:?: where and how would you store all this "effieciency" that you generate, and what would you use it for ?? :? :lol:
Hillhater
1.21 GW
1.21 GW
Postby sk8norcal » Fri Dec 23, 2011 5:25 pm
ioniscool wrote:I wonder if some has tried to use a comet torque converter from http://gokartsusa.com/GTC-Comet-TAV2-30-Torq-A-Verter.aspx but using the secondary belt pulley to mount DIRECTLY to the rear wheel 10" outer diameter and not sprocket to the wheel sprocket. I wonder how much effieciency could be generated from this setup. Using a me0909 3800 rpm unloaded and 2500rpm loaded.
I don't think you would get enough lean clearance when mounted to the wheel,
best to use another stage..
here's one on a moped,
but read his comments...
sk8norcal
Return to E-Scooter and Motorcycle General Discussion
Who is online
Users browsing this forum: No registered users and 3 guests
