Ninja 250 Conversion in Progress
Postby bquick » Sat May 31, 2008 7:08 pm
I've been working on a Ninja 250 conversion:
This is the bike I started with. The guy I bought it from said the engine lost power and it made him crash. It now cranks like it has no compression. Perfect! The windshield is broken off and some other cosmetic damage, but it's a nice platform to start from.
This is my pot box for the throttle (pull-pull) and regenerative braking. I used the clutch lever for the brakes. The clutch already had a switch on it to keep you from starting in gear. I cut some off the actuator so the switch energizes when the clutch is first activated rather than when it's pulled all the way in. I then wired it through an ice-cube type relay so that it triggers my brake light as well as the regenerative braking.
Throttle and Brake.jpg (45.15 KiB) Viewed 4372 times
I built a new windsheld and instrument panel. The instrument panel is covered with a sheet of lexan. The blank spot to the right is where my electronic display will eventually go.
Windshield and Dash.jpg (48.29 KiB) Viewed 4364 times
This motor mount will eventually hold a Perm 132 motor (I hope to get it in a week or so). It is designed to bolt to the existing motor mounts.
Motor Mount.jpg (59.68 KiB) Viewed 4358 times
The Perm motor prefers to rotate clockwise, so I had to flip the rear wheel. This meant I had to move the rear brake to the opposite side. I got a new rear tire since I had to flip the rear tire on the rim to get it to spin in the proper direction and it was dry rotted.
Rear Brake.jpg (56.02 KiB) Viewed 4350 times
I built a battery shelf using some 2" x 2" x 1/4" fiberglass angle. I screwed some 1/4" plexi-glass to the angles.
Battery Shelf.jpg (57.1 KiB) Viewed 4343 times
Here are the batteries. I'm using (80) 10 amp hour LifePO4 cells from Headway. I got them shipped directly from China. This will give me a 40 amp hour, 64 volt pack that's capable of 200 amps continuous, 400 amps peak.
This is half of the cells after initial soldering:
Soldered Cells.jpg (63.99 KiB) Viewed 4337 times
Here is one of two packs, soldered and stretch wrapped:
Finished Pack.jpg (51.42 KiB) Viewed 4323 times
bquick
Re: Ninja 250 Conversion in Progress
Postby vanilla ice » Sat May 31, 2008 9:29 pm
The bottom ends on those motors werent the strongest. Should be perfect for a convert, lightweight and plenty stout. The '08 250R's are so sexy. Makes me want to buy one.
projects: tandem cruiser, aweset12.5
vanilla ice
Postby frodus » Sun Jun 01, 2008 10:18 pm
nice looking bike....
what controller are you using? How much were those lifepo's? and what BMS/charger are you using?
frodus
Postby bquick » Mon Jun 02, 2008 6:59 am
I'm using a Kelly 72401 controller.
The batteries cost around $1800, including shipping.
To start with, I'm charging the batteries using a CellPro 10S from FMA Direct. It's made for charging R/C batteries. With it, I can charge half of the pack at a time at 6 amps. It will balance the cells as well. I'm working on building a low voltage cutoff device that may eventually also assist in balancing while charging.
I mounted most of the electrical components last night. I'm still waiting for the motor.
- Brad
bquick
Postby Malcolm » Tue Jun 03, 2008 2:51 am
Hi bquick
Looks like a well thought out build! I'm interested in the regen setup. Can't quite work out your arrangement. Are you using the clutch lever for regen braking, or using a twin cable throttle?
Looking forward to hearing how the headway cells perform as well.
Malcolm
Malcolm
Postby bquick » Tue Jun 03, 2008 7:14 am
Malcom,
Thanks for the comments.
Yes, and Yes. I'm using the clutch lever for regen braking. It pulls the single arm potentiometer. The trottle is pull-pull. In addition to the potentiometers, the Kelly controller also has a provision for a switch to energize the braking and a separate switch to energize the throttle. I'm not sure if these are required or not. The clutch already has a switch on it, so I made that switch power a DPDT relay. One pole of the relay controls the brake light. The other side energizes the brake switch. When the brake isn't activated, it energizes the throttle switch.
- Brad
bquick
Postby Jozzer » Tue Jun 03, 2008 8:06 am
FYI, the switch for throttle isn't required (throttle works without it) but the switch for the brake IS needed (no regen without it). Brake switch needs PWR voltage to function..
The brake is supposed to run on halls 0-5v, though I had to adjust a halls throttle to really give 0-5 (not 1-4v), since theres no dead zone calibration in the software. All the regen happens in the first 1/4 twist. I'd suggest you aim for 0-3v to make it to the AN1 pin..
Nice project, looking good!
Steve
*KMX Trike, Puma hubmotor,24s1p A123 batteries. 3KW power. Total weight 21KG. Range 4 miles
*Aprilia RS125 with Agnimotor, Kelly 500A controller and 72v 40AH LifeBatt batteries. 80mph top speed.
*Poor Ducati is in bits, perhaps she will live again with some fresh LiPo's this summer! Anyone want a project?
*Hudson Spirit Trike, oh the fun! 2 Agni's driving the renault 5 gearbox, 96v 120AH LifeBatt pack, pulling 750A peaks batteryside.
*Mavizen TTX02 production racebike. Have to hang on tight!
Jozzer
Postby bquick » Tue Jun 03, 2008 9:45 am
Steve,
Thanks for the input. I was originally thinking that I needed 0-5K on the brake. I used a 10K pot because my mechanism doesn't spin the pot far enough to use the full range. The other night I realized that the brake needs 0-5V, so I wired it accordingly but I'll only get about 0-3V out which is what you suggest.
If it performs anything like your bike, I'll be happy!
- Brad
bquick
Postby bquick » Tue Jun 10, 2008 7:55 pm
I'm still waiting for my motor to arrive.
Here are some new photos:
It's a little difficult to see, but the Kelly controller is mounted to an aluminum sheet. To the left is a Sevcon DC-DC converter.
This is the other end of the aluminum sheet. On the left is the main disconnect. On the right is a shunt and fuse.
Here are some copper bars used to attach the main disconnect and fuse to the controller.
The bottom of the gas tank was a little close to the top of the battery packs, so I cut the bottom of the gas tank out. Saves weight too.
I mounted a 4 x 40 backlit LDC display to the dashboard.
- Brad
bquick
Postby bquick » Wed Jul 02, 2008 8:32 pm
It's finally running!
Here's a video of a ride on it:
http://www.youtube.com/watch?v=b5l3BaYCV-w
I was able to hit 60 mph, but my motor was getting hot, so I geared it way down. It currently maxes out at 48 mph. I'm planning on going up a tooth on the front sprocket to bump up the speed a little.
I've ridden it to work and back (11.2 miles each way) for the past three days. Until I get my BMS working, I'm charging it when at work and at home.
Acceleration is good, but It draws 250 amps on hard acceleration. It takes 60 amps to cruise at 48 mph.
- Brad
bquick
Postby Jozzer » Wed Jul 02, 2008 8:59 pm
Nice job:)
I can run mine for 20 miles hard on a hot (25C...It is England!) day before the motor reaches 70C. My controller see's over 300A batteryside, and I regularly run the bike over 60 or even 70 mph. Main difference between our builds are that I have a clean airway to the top half of the motor maybe?
When things get warm, I turn on one of these ( http://cgi.ebay.com/ebaymotors/Marine-b ... 0237726276). Generally it will scrub off 10C or so, and let me finish the batts off before the temp gets above 70 again. It especially helps when you have had a hard run, then sit in traffic. When you get clear and ready to thrash again, the motor is much cooler.
Nice neighbors you have there too:) Say hi from the internet!
Steve
Jozzer
Postby frodus » Thu Jul 03, 2008 10:57 am
bquick wrote:It's finally running!
- Brad
Great job on the build.... awesome project. Why did you cut the tank like that? to swap batteries easily?
what is your front/rear sprocket ratio? I'm at 4:1, and ordering a 60tooth rear so I can do 5:1.
Is that 250A on the battery side or motor side?
My EM hits ~80A on Battery side at 72V, but I get 350A on the motor side under heave acceleration, with a 6.7" ADC motor, custom Synkromotive controller and that 4:1 ratio. We topped out at 63 or so (see my evfr http://www.youtube.com/frodus17 ).
Keep some cooling on that motor. Does it have a built in fan? Thats the great thing about 6/7" motors, they've got a fan in the shaft output end that sucks from the brushes, through the field windings and out the face.
frodus
Postby bquick » Thu Jul 03, 2008 10:22 pm
Steve,
On a normal ride to work, it doesn't get all that hot. I'm going to have to gear it back up to where I can hit 55 mph. My current ratio is 13 to 60. If i go 15 to 60, I should hit 55 mph
Frodus,
I cut the tank out so that I could keep anything metal away from the batteries. My plan is to fill the tank with battery chargers.
I'm currently charging with an FMA direct 10S charger. It can charge 10 cells at at time, so I have to do half the pack at at time.
- Brad
bquick
Postby Jay64 » Thu Jul 03, 2008 11:20 pm
Nice. 8)
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
'81 TS 185: Etek RT, Kelly Controller, lifebatt pack.
'07 ezip: 2p 28v Milwaukee packs (stolen :( )
Jay64
Postby recumpence » Wed Jul 09, 2008 6:47 pm
Hmm, gearing up for 55? I might have to do the same! :wink:
Great build, Man. Very good to hear from you too.
I keep running across your number in my address book. I will give you a ring soon.
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
1 GW
1 GW
Location: On Earth right now. That can change at any time, though..........
Next
Return to E-Scooter and Motorcycle Photos & Videos
