wesnewell
The controller has 4 shunts in parallel. Look at pictures.
http://endless-sphere.com/forums/viewtopic.php?f=2&t=31643
If you cut one, that would reduce amperage by 25%. Yours probably has 2 or 3. Cut 1 of 3 to reduce amperage by 33%. Cut 1 of 2 and you'll reduce amperage by 50%. To be honest, you should not have a problem with the battery packs you have as the controller rarely uses max amperage unless it's under extreme load. You could have something wired wrong too, causing excessive amp draw, like wrong phase wiring or bad battery connection causing excessive voltage drop..
