BMS facts and how to charge lifepo4 without it!
Re: BMS facts and how to charge lifepo4 without it!
Postby AussieJester » Tue Feb 02, 2010 6:35 pm
^^ I dont even use Lifep04 ...Dont use a BMS either...I also wouldnt
recommend any noob to this hobby follow your no bms advice either...
I gues i fall into the category of "this advice isnt for everyone" :mrgreen:
just my 2c
KiM
AussieJester
Postby dumbass » Tue Feb 02, 2010 6:46 pm
maxwell65 wrote:
BTW to anyone whose interested the actual time to monitor a prismatic pack is about 5 minutes a month, if that,provided they follow the outline i wrote.
Just to add another 2 cents (mine again) if you feel it takes to long to manually check each and every cell then maybe you can do as I intend to do and install these http://www.hobbycity.com/hobbycity/stor ... oduct=9282 They will check your charge and give a LV alarm. Yes I agree if you have 80 cells then they too are a problem do to cost ($300 for 10 to handle 8 cells each). But for 8 or 16 cell setups I think they would work well (I'll let you know).
dumbass
Postby AussieJester » Tue Feb 02, 2010 7:05 pm
^^ i have the other 'version' the Battery Medic on order from HC they too are out of stock and have been for a few weeks :-(
KiM
AussieJester
Postby dumbass » Tue Feb 02, 2010 7:47 pm
AussieJester wrote:^^ i have the other 'version' the Battery Medic on order from HC they too are out of stock and have been for a few weeks :-(
KiM
Can you give us a link?
dumbass
Postby webfootguy » Tue Feb 02, 2010 8:06 pm
KiM
I think this is the link http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=10328
webfootguy
Postby AussieJester » Tue Feb 02, 2010 8:21 pm
^^yupz it be the one...
KiM
AussieJester
Postby morph999 » Wed Feb 03, 2010 1:08 am
if you are running your pack to 50 - 60 % DOD and you kill a cell, that cell wasn't any good anyway. That's how I look at it. Suppose you take your pack out fully charged, you run it to 50 - 60 % and when you get back, you discover that a cell is dead. How would a monitor help you at all in that situation assuming you are running prismatic cells? It wouldn't help you at all. YOu'd only find out a little sooner.
morph999
Postby dogman » Wed Feb 03, 2010 6:12 am
Yes indeed, a cell with 40% less capacity than the others would be a dead duck, bms , no bms. whatever. A runt is a runt.
Several times I had the bms save my pack when the charger failed to fully charge the pack. I'da killed it for sure without a bms lvc, or some kind of low voltage indicator or warning. So for sure you need to have a lvc warning of some kind. I don't think using a monitor on the cells is going without a bms, it's just a different form of the same basic thing. Monitoring a cell, or all the cells for low voltage in use. Discharging a bare pack of cells with no way to know when voltage is too low really is riding bareback.
Charging isn't the major problem if you have a decently matched set of cells. A good set will tend to stay balanced enough, and even a cheap sla " smart charger" can trickle charge the low ones up a bit eventually if the pack is left on it after the green light goes on. That's basicly how I treated my ping for 2000 miles of riding. My charger was slightly undercharging the pack so the bms wasn't doing any balancing. When I got a higher voltage charger, the bms still did nothing, why? Because after all that time, 200 cycles or so, the pack was never unbalanced. Discharging at a lowish c rate and long periods on the charger is why the pack stayed balanced.
As for prismatic packs or larger round cells being somehow superior to other forms, that is mainly true only when you have to remove and replace a cell, or if you want to add cells to make a higher voltage pack.
For cell monitoring purposes, one 20 ah prismatic , two headways, four ping pouches, or ten 18650's are all the same thing. They are a string of paralell cells.
There isn't one big cell in a 20 ah prismatic or a 10 ah headway . Inside the larger cell you will find a paralell string of smaller cells. So nobody is monitoring a single cell on a 20 ah pack. They are monitoring a paralell string. Since paralell cells all rest at the same voltage, it behaves electronicly like a single cell regardles of whether it's ping cells soldered together, spot welded 18650's or a 20 ah prismatic cell. It's not one bit harder to manually monitor cell groups in a prismatic 20 ah format or a 18650 string of paralelled cells.
But it sure as hell is harder to replace a bad string of 18650's. Or unsolder a ping pack. But none of that has any bearing on the bms discussion, I've just strayed to another topic.
Back to the bms topic, I again state my opinion, that only riding along with no real idea of the voltage of the pack is ill advised. A bms with individual cell lvc, monitoring a known weak cell with a voltmeter, a lvc warning buzzer on a known weak cell, pack trackers etc are all good ways to know you have not overdicharged the pack. I just find the bms that comes on a pingbattery to be affordable, and reliable. A voltmeter monitoring a single cell group could easily reassure somebody who was wanting to make sure the bms is working right.
Just having a voltmeter on the whole pack doesn't cut it. Controller lvc doesn't cut it. Planning to use only 50% of the capcity doesn't cut it if you are only assuming that you have a full charge.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby dumbass » Wed Feb 03, 2010 2:54 pm
dogman wrote:Yes indeed, a cell with 40% less capacity than the others would be a dead duck, bms , no bms. whatever. A runt is a runt.
Your points are taken however, I disagree with a BMS or LVC (low voltage cut off) being the same as a monitoring alarm. A BMS on discharge is a LVC and as such will do just that (cut off the power from the batter). Whereas, a monitoring alarm will not. Furthermore, most if any BMSs do not have a readout but the monitoring alarms as indicated in my last post does.
Please remember we are talking about a charged pack before riding. Yes, we do know that the pack was charged to the normal level that we prefer to charge to. We are not just jumping on the bike willy-nilly and riding off into the sunset without a care of the level of our charge. We (I) do track Ahs and mass voltage as riding. And as stated by myself and others we are very kind to our cells and only discharge to about 50% to 60%. So the risks are minimal with the exception of a short which would not be detected. However, if a cell had an internal short it's dead anyway.
It also sounds like you have charged exactly the same way as I and others have done. I don't know that these SLA chargers do any better at balancing or not. I am guessing the fact of cells being in reasonable balance is because the are bottom balancing so well and the SLA charger doesn't charge as high as a lifepo4 charger does.
dumbass
Postby dogman » Wed Feb 03, 2010 3:29 pm
Sure. A bms and a low voltage alarm are not the same thing. But my point is that they basicly aim to acheive the same goal, not overdischarging the pack to the point where cells get ruined. One way is automatic, the other requires the operator to take action, but both aim to actually monitor cell voltage, not make assumtions as to state of charge at the start, or make assumtions as to how much has been used. Instead either method measures the actual voltage of cells under load.
When I talk about knowing you have a charge, I am thinking of some times my bms saved my ass. I had two different chargers that had weak solder in the output end of the circuit. Twice it was inside the charger, and three times it was just the plug. In all five events, the charger happily turned green light, and I rode off thinking I had a full charge, and ran out halfway home. Since the loss of contact was intermittent, the next day the charger seems to work fine but then again interrupts the charging halfway. The first time it happened, it took me a week of sometimes getting home, and sometimes not to figure out I had a bad connection in my charger. I'd look at it, and it works fine. Maddening till I figured it out. Meanwhile, the bms saves me time and time again.
This I why I comment on actually knowing you have a charge. Not taking the freaking chargers word for it. Now I have a killawatt so I can measure the power the charger uses, and smell a rat if my rides come up short.
To my way of thinking, especially with a larger pack worth thousands, the best way would be to have a bms, and then also monitor all the cell groups voltage by several methods. Low voltage alarms and a voltmeter that can switch to monitor each cell group. And perhaps, even cell monitors that log every detail for diagnostic purposes when needed. The pilot in me loves redundancy.
But on a bike, with a pack worth only a few hundred. Trusting my ping bms is working fine.
As for the chargers, with my battery a good size one discharged mostly at about .75 c, balance what? You gotta get inbalanced to need balancing. I also believe in being nice to your cells, and find a matched set treated nice stays pretty balanced. The guys with more powerfull controllers are the ones with a need to balance the battery. The tiny trickle of current from my soneil sla charger would eventually balance the pack on those rare occasions that I did get it out of balance. The bms would take action if leaving it on the charger constantly ran a cell too high. After the first 2000 miles, I figured out how to turn up the voltage to activate the bms every charge if needed. At that point I was charging my 36v ping to 47 v. Nowdays the same charger only reaches 45.5v.
dogman
Postby slayer » Wed Feb 03, 2010 4:00 pm
Me too i run my pack without a bms... but it dosent mean that i don t believe in a bms or that i would not add later on 2 of the 8 cells monitoring from hobbyking with audible alalrm and the software for the computer.
but the fact is that if a cell dies and the pack was protected by bms ...they say you just change the cell
but if you have no bms and a cell dies, they think the pack is good for garbage. it s the same solution in the end.
and if it happens too many times maybe that owner should think learning more about lifepo4 or get a good bms or get out of battery powered vehicule. loll
slayer
Postby pgt400 » Wed Feb 03, 2010 4:10 pm
I have a 16S3P A123 pack with no BMS (built as (4) 4S3P). I put all cells in parallel before building my packs for a couple of days on a single cell charger. I now charge them with a 5amp / 12 volt SLA smart charger by putting the (4) 4S3P in parallel (Anderson connectors). During use, I montor my CA and never draw more then 6 AH from a fully charged pack. So far (~20 cycles) they are staying in balance. That said, I intend to get the new goodman BMS when availble or maybe the cellog.
03' Ninja EX250, Agni #95 reinforced, 25S1P 40ah CALB Lifepo4, Mini-BMS.
05' Mongoose 20" BMX, Golden Hub Motor, 48 volts @ 9ah, A123's, Signalab BMS.
http://www.evalbum.com/1955
http://www.evalbum.com/3337
pgt400
Postby slayer » Wed Feb 03, 2010 4:30 pm
And by the way i ran all last summer with only one incident where i ran the bike after two weeks without use and did not charge before use ( wich i will now do ) and noticed that it was not behaving the same (only by looking at cycle analyst) and luckuly by the end i had a flat and had to walk home and one of the cell was 2.5 volts so i recycled a couple of times and it is now back to normal, i guess i found the weak cell that way ... i now check this one the first.
slayer
Postby AndyH » Wed Feb 03, 2010 4:51 pm
morph999 wrote:if you are running your pack to 50 - 60 % DOD and you kill a cell, that cell wasn't any good anyway. That's how I look at it. Suppose you take your pack out fully charged, you run it to 50 - 60 % and when you get back, you discover that a cell is dead. How would a monitor help you at all in that situation assuming you are running prismatic cells? It wouldn't help you at all. YOu'd only find out a little sooner.
The problem here is you're limiting your 'logic' to a single event - a bad cell. What happens when a connection loosens a bit and a cell or a couple of cells don't fully charge? Or maybe one cell has a bit higher resistance when cold and doesn't take a charge a quickly as the other cells? There are a LOT of reasons why cells can get out of balance or not be completely charged when the charger shuts down. And that completey ignores the days when you only need to take a short ride to the post office so you pull the pack off the charger before it's done.
Over-discharging a cell - regardless of the reason - kills the cell. Catching a low cell before it's discharged to zero or reversed keeps the cell alive and saves the time and money it takes to diagnose and swap cells. Anyone that thinks they can prevent over discharge by only using 60% capacity is only looking at part of the 'problem'. They're likely thinking along the lines of: "The only way I'll have a low cell is if it's already bad - and at that point I don't care if it completely discharges." But they're missing the rest of the story: "But maybe the low cell isn't bad - instead of guaranteeing it's death, maybe I can find out why it's not fully charged, fix the problem, and get more than 20 cycles from the pack."
Here's a real-world example of what I'm talking about. This is a fully-charged 21S pack on a cold-weather ride - with and without the 2.7V LVC connected. The blue line is 3.0V, the red line three 'ticks' below is 2.7V. The LVC, connected to the throttle, limited the max current I could draw from the pack and limited top speed. But it kept the low cells from being overdischarged. Keep in mind - this is the FIRST 10 MINUTES from a fully-charged pack.
(89.35 KiB) Downloaded 295 times
(90.35 KiB) Downloaded 295 times
Simply measuring the cell voltage once a quarter will not show what the pack is doing. Yes - one can use single cell chargers to tweak the low cells after the bank charger finishes. And yes - if one has matched the cells, always rides at the same temperature on the same route at the same throttle setting, they might feel that's enough risk management - especially if they consider their time to be worthless and their pack disposable... But as you can see above - cells change as they age and the four lower-performing cells are working harder than the rest even fresh from a full charge.
Andy
AndyH
Postby morph999 » Wed Feb 03, 2010 6:45 pm
Andy, on the 2nd graph, does that mean every 5 minutes or so the LVC was kicking in? What kind of enjoyable ride would that be anyway? You'd have to replace that cell eventually with or without LVC.
morph999
Postby maxwell65 » Wed Feb 03, 2010 7:17 pm
i just want to say im not suggesting not to use a bms,as i have every intention of installing one,im just saying that if a bms stops working properly the possibility exists to keep on charging by other means.
maxwell65
Postby dumbass » Wed Feb 03, 2010 8:56 pm
[quote="AndyH"][/quote]
You bring up several very good points however, as most that don't use a BMS have stated they verify the charge before riding. So a bad connection for example would have been noticed by low voltage during this verification. As to our time...everyone has there own value on their time. When I was working for a living it was very expensive. But now that i am retired and I am doing this 100% for my personal enjoyment it's not worth a hell of a lot. That being said my money still is.
My question to you is this; your graph indicates a LV condition on several ocations. And you say that it only limited your max speed. But it has always been my understanding ( and no one here has ever indicted it was wrong) the if a low voltage accured it BMS would shutdown the pack discharge. This is not the same as limiting your speed. Are you saying that after the BMS shutdown you reset it and continued on at a reduced speed because of the LV condition? Or did the BMS actually limit your max speed automaticly? To me LVC means "low voltage cutoff" not "low voltage control" But If a BMS only linits your current draw it is a different situation and i would like to hear more and where you bought this BMS.
dumbass
Postby AndyH » Thu Feb 04, 2010 1:46 am
morph999 wrote:Andy, on the 2nd graph, does that mean every 5 minutes or so the LVC was kicking in? What kind of enjoyable ride would that be anyway? You'd have to replace that cell eventually with or without LVC.
The entire graph is only 10 minutes - and the horizontal voltages for the first ~2 minutes is putting on a helmet and backing the bike out of the garage.
No. The LVC signal is connected to the throttle input. It's not 'jerky' like a controller LVC or an LVC connected to the brake inhibit. It behaves as if the BMS limits how far open you can move the throttle - it's very smooth. I actually prefer the jerkiness of the brake inhibit as it tells me that something's happening. The only thing I can 'sense' with the throttle connected LVC is that I might have lost some top speed.
Enjoyment is subjective, but I'm much more relaxed knowing that I can ride and not constantly stare at the PakTrakr display. A low cell can drop too far so fast that it's not a comfortable ride for me at all.
AndyH
Postby AndyH » Thu Feb 04, 2010 2:21 am
dumbass wrote:My question to you is this; your graph indicates a LV condition on several ocations. And you say that it only limited your max speed. But it has always been my understanding ( and no one here has ever indicted it was wrong) the if a low voltage accured it BMS would shutdown the pack discharge. This is not the same as limiting your speed. Are you saying that after the BMS shutdown you reset it and continued on at a reduced speed because of the LV condition? Or did the BMS actually limit your max speed automaticly? To me LVC means "low voltage cutoff" not "low voltage control" But If a BMS only linits your current draw it is a different situation and i would like to hear more and where you bought this BMS.
How the operator 'feels' the LVC event depends on the type of LVC signal and how it's used. For example - in the E-S/Goodrum/Fechter BMS, the low voltage event 'detection and reporting system' is based on a voltage detector that signals when a cell hits the low point. The 2.1V detector will signal as voltage drops down thru 2.1V, and will release it's signal when voltage rises above 2.2V. There's no latching at all, just the .1V difference between 'signal on' and 'signal off'. Since nothing latches off, there's nothing to reset. Protection is automatic, repeatable, and much faster than one can respond to a LED or a buzzer.
Let's use the low voltage signal to do something.
One method is to connect it to the controller's brake inhibit line - just like another brake lever.
(27.28 KiB) Downloaded 354 times
When a cell drops thru 2.1V, the BMS essentially closes a brake switch. This tells the controller to cut power to the motor. Once there's no load on the pack, cell voltage recovers. Once the low cell voltage springs back up thru 2.2V, the virtual brake handle is released and power is restored. If the throttle is left open thru multiple low voltage events, the rider will feel about 1-4 pulses per second depending on how quickly the cell voltage recovers.
Another method is to use the low voltage signal to operate a relay or contactor or MOSFET switch that cuts power from the pack. One of Gary Goodrum's LVC boards has such an active power disconnect function. Same scenario here as well - cell drops low, active shut-off opens the wire to the controller, cell voltage recovers, power is restored. I don't know how quickly the pulses will happen here - I haven't ridden this type of disconnect.
The method I'm trying on my bike - and the method that was in use when I collected the charted data - is a throttle pull-down. The circuit is listed in one of the BMS threads.
From looking at the circuit, I expected that a low voltage event would abruptly cut the throttle and result in feeling 'power pulses'. But with my hall-effect throttle there's no jerking at all - just what seems to be a reduction in how much current I can draw. With no LVC connected, I can twist the throttle and pull 100A regardless of the status of the pack. With the LVC signal connected to the throttle, I was limited to about 73A max as a cell bounced around the 2.7V set point. It was very smooth and was undetectable on the road except that it seemd my top speed was down a bit and that acceleration dropped off a bit faster than normal. I didn't realize I had bounced off LVC until I looked at the data after the ride.
I hope that helps some,
Andy
AndyH
Postby JUICED » Thu Feb 04, 2010 10:40 am
This is all interesting as we were doing this before the posting of this information here.
It is great to see others with the same mindset.
There are several ways to accomplish the monitoring of the charge and discharge of your batteries. This one posted by maxwell65 is just another way of doing it. It seems to work well if you know what you are doing.
If there were quality BMS units that were inexpensive and really did their job, most of us would never have considered this way of running our Batteries.
******* Our setup******
I have 8 single cell chargers all tied to a 8s4p box through a Molex which I just plug in to start the charging process.
No BMS and since they are isolated chargers, you can charge the box all at one time.
They charge up better than when I had the POS BMS in the system. I have received better BMS units since then (Replacement units) but am content with how everything is running. The chargers are only 14$ a piece delivered and I can see if I have any issues by how long it takes for all the red lights to go green.
Since I have 4 Headway cells paralleled together and then set up as groups of eight, the 4 paralleled cells cannot really be monitored individually anyway. I use the controller to limit the LVC and set the point high enough before most damage should occur even if I have a crappy cell. I do not need to run my bike to 80%.
We just did the changover recently. I should have some really good updated distance numbers as soon as it WARMS UP!!! :):)
Juiced
EV Ed
juiceddragracing.com Electric Dragbike Fun!!!
Ev Album 2456,2457,2458,2681,3456,3630
JUICED
Postby pgt400 » Thu Feb 04, 2010 11:10 am
Yeah, but your application is the exception not the norm.....your single cell chargers are probably only 2 amp output units? Take forever to charge a 50-60ah pack. We want to charge in 4-5 hours and run to 80% DOC. Andys graphs cleary show that that 2.1 volts can come pretty fast based on low temperature and/or lower state of charge. The goodman bms with cell level LVC and HVC (call it balance if you like) with modulated charger seems the way to go. I tried a couple of volt blockers a while back...and yes they started to bleed current at 3.6 volts.... but without charger modulation the cell kept right on charging!
pgt400
Postby JUICED » Thu Feb 04, 2010 12:05 pm
pgt400 wrote:Yeah, but your application is the exception not the norm.....your single cell chargers are probably only 2 amp output units?
Absolutely! (40 AH)
Although I have not really seen any "Normal" bikes to date. All of them have their different designs and particular purpose.
I can ride it to work (9 Miles one way), go to lunch, run to the parts store and ride home. I can charge it overnight.
I am working on a solar charging station now as well.
If I wanted to charger it faster, I would just get bigger chargers! :) :)
Battery Management Systems have their place.
This particular setup works well for me. When the BMS company get their act together and build one that will work well ( and fit in the allotted space) on my motorcycle I will add it, until then this works fine.
Juiced
EV Ed
JUICED
Postby morph999 » Thu Feb 04, 2010 5:23 pm
I use two chargers. That way, I'm positive that I at least put some kind of electricity into the pack. I can use a 10 amp charge for 1 hour or 30 min then finish it up with the 3 small chargers that I have.
morph999
Postby dumbass » Thu Feb 04, 2010 6:03 pm
Andy,
An absolutely great explanation on how it works. Thanks, I really learned a lot from it. Your comments about what I will call pulsed motor response is the same comment that was stated by Jim Olson from Cyclone USA the first time he tried a lifepo4 pack with a 500w Cyclone kit. Ether the pulsed protection or the speed limiting protection sounds like something I would consider. Now that you have done such a great job explaining the discharge protection can you please explain the charging protection? From what I have read (and this is something I don't like) is that the BMS is just bleeding off the voltage on high cells. I have also read that with some BMS they cut off the charge once the first cell reaches a full charge.
You mention “Gary Goodrum's LVC boards”. Is this only a LVC or a BMS with LVC with ether pulses or a reduction is current draw. I like the idea of using individual cell chargers but would like the addition of a low voltage control.
dumbass
Postby JUICED » Thu Feb 04, 2010 6:25 pm
Just as a side note.
I removed the cells today from one of my BMS (not a great BMS unit ) boxes that I fully charged yesterday.
I did a load test on them and was surprised on how low in power they were. I re-charged them using the 2 amp LifePo4 charger
and it took forever to top them off.
I waited until this evening and then did a load test. The batteries now ran as I would have expected.
I will be using the individual chargers until I see and proven BMS that can match
the quality and power of these Tenergy chargers.
Juiced
EV Ed
JUICED
Next
Return to Battery Technology
Who is online
Users browsing this forum: pm_dawn, Sigmacom, zombiess and 9 guests
