2 New dewalt with different voltage
Postby itron » Tue Sep 04, 2007 2:47 pm
I got 2 new dewalt packs on ebay (still in the original package). I soldered the discharge wires directly on the battery tabs (bypassing the BMS), I wired them in 2p connecting a fuse and a diode in series on each of them and then rode about 10 Km being careful to not let the voltage drop below 30V, then I charged them with the dewalt charger.
The charger charged them both until the three LEDs were on, but when I checked the voltage on the discharge terminals, I found that one was 36.7V and the other was just 35.7V. I tried to charge the latter a bit further leaving it in the charger for several hours (hoping that it coul be just a matter of balancing the pack) but it stayed at 35.7V.
Anybody has any suggestion? would it be a good idea to remove the diodes and just parallel the packs, so they can balance each other?
Thanks
itron
Postby Doctorbass » Tue Sep 04, 2007 3:26 pm
The voltage between 35v and 37v represent a capacity of few percent only... if you draw few amperes on these pack, the voltage will imediatly drop to 34 or 35v and stay to that voltage. This is not very important. I have some pack with lower voltage after charging and they have a little higher capacity than other with higher voltage after cahrging...
Many people border about these last 35 to 37volts... After many tests, i conclude that it's not enough significant...
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby Jozzer » Tue Sep 04, 2007 3:29 pm
That might help after a while. A few discharges/charges may help too. It takes time for the dewalt charger to work its magic (too much time for too little magic IMO). Checking each cell voltage would show where the problem lies. All 8 packs I bought needed balancing badly when I first got them.
If you have a method of charging individual cells to 3.7v then go through them all once and balance them by hand.
Mazda MX-5. 300KW power. Soliton 1 controller, 11" Kostov motor, 20KW/H Turnigy Lipo for 60-100 miles range. 120mph top speed.
Hudson Kindred Spirit 3 wheeler. Twin Agni setup, 300KG 80KW. 100mph top speed (maybe more, but no-one has the guts to try!)
Aprilia RS125, Agni motor, 600A 96v Kelly controller, 6kw/h Turnigy pack.
www.Jozztek.com
Jozzer
Return to Battery Technology
Who is online
Users browsing this forum: Google [Bot] and 13 guests
