visuthdy wrote:For those that purchased Hyperion with 1420i ttpack lvc board kit. Does any know if I can cut this board in half? I would like to cut it so I can put the batteries in the hammond case. I'm planning to do 12S2P. thanks.
EBJ wrote:ok, I know somewhere in this mile-long post is my answer...
but I just spent 30 min looking to no avail.
Question:
When wiring up the balance-wires coming from the Hyperion to go to a DB-25 Connector,
I first just wired my balance wires as if I were plugging in my 2 5S batteries to the hyperion balance port plugs. (one battery to ports 1-6 of 16, then the other battery to ports 9-14 of 16)
It worked well, but I realized after I wired it that way, that when I cycle through the "ports", the Hyperion shows a "blank" voltage for ports 6 and 7...
(because I had skipped over those two and jumped into port 8 to continue w/ wiring the other 5S)
So I have a few questions:
1. What is the best way to wire in 10S to the Hyperion ? (as far as port-use)
2. If I wanted the Hyperion to register 1-10 ports for my 10S pack, then how would I wire in the second 5S balance wires to the Hyperion ?
-examples: first 5s balance wiring is pretty clear... wire "ground", 1, 2, 3, 4, 5.... but then the second 5S pack is a little confusing to me since "ground" voltage is actually the same as (port 6 ... or cell "5" voltage)... in which case, do I wire "ground" w/ the second pack to port 6 w/ "cell 5" ? or do I skip it all together and start wiring "6" to port 7 ? Then what do I do with "port 9" when the Hyperion is wanting "ground" of the high-pack to go there ? arg!.
I'm sorry if no one can follow the above. I find it challenging to explain.
Question:
docnjoj wrote:OK so here is a dummy question. I will have 2 6S lifepo4's A123 in series to make 12 S How should I wire the balance leads so the Hyperion will recognise all of the cells. I would buy Kin's system if I needed it, but how do you plug the 2 6S connectors into Hyperion. Cells 1-6 starting with ground in Port A and cells 7-12/ground in Port B? I'm confused!
otherDoc
Edit: Yes the pack will be a split one with 6S cells on each side of the trike. Much better balance for handling just like my old Ping is doing now.
wojtek wrote:docnjoj wrote:OK so here is a dummy question. I will have 2 6S lifepo4's A123 in series to make 12 S How should I wire the balance leads so the Hyperion will recognise all of the cells. I would buy Kin's system if I needed it, but how do you plug the 2 6S connectors into Hyperion. Cells 1-6 starting with ground in Port A and cells 7-12/ground in Port B? I'm confused!
otherDoc
yes, you connect 2x6s in series [44v] and the subpack's balance leads with black main charge wire connected to charger goes to port A and red one goes to port B [very important]
kfong wrote:Here is a picture of how I do it. http://www.endless-sphere.com/forums/vi ... 31&t=39291
The last picture shows how it's done. You need to use their battery balance port connectors since it's not a one to one pattern unless you want to rewire.
Users browsing this forum: Bing [Bot], biohazardman, Melbourne and 7 guests
