Hyperion EOS 1420i NET3 14s Balance Charger...
Re: Hyperion EOS 1420i NET3 14s Balance Charger...
Postby hillzofvalp » Sat May 05, 2012 7:41 pm
someone right before you posted a similar issue... :wink:
hillzofvalp
Postby EBJ » Mon May 07, 2012 7:00 pm
ok, I know somewhere in this mile-long post is my answer...
but I just spent 30 min looking to no avail.
Question:
When wiring up the balance-wires coming from the Hyperion to go to a DB-25 Connector,
I first just wired my balance wires as if I were plugging in my 2 5S batteries to the hyperion balance port plugs. (one battery to ports 1-6 of 16, then the other battery to ports 9-14 of 16)
It worked well, but I realized after I wired it that way, that when I cycle through the "ports", the Hyperion shows a "blank" voltage for ports 6 and 7...
(because I had skipped over those two and jumped into port 8 to continue w/ wiring the other 5S)
So I have a few questions:
1. What is the best way to wire in 10S to the Hyperion ? (as far as port-use)
2. If I wanted the Hyperion to register 1-10 ports for my 10S pack, then how would I wire in the second 5S balance wires to the Hyperion ?
-examples: first 5s balance wiring is pretty clear... wire "ground", 1, 2, 3, 4, 5.... but then the second 5S pack is a little confusing to me since "ground" voltage is actually the same as (port 6 ... or cell "5" voltage)... in which case, do I wire "ground" w/ the second pack to port 6 w/ "cell 5" ? or do I skip it all together and start wiring "6" to port 7 ? Then what do I do with "port 9" when the Hyperion is wanting "ground" of the high-pack to go there ? arg!.
I'm sorry if no one can follow the above. I find it challenging to explain.
EBJ
Postby FastDemise » Mon May 07, 2012 8:02 pm
EBJ wrote:ok, I know somewhere in this mile-long post is my answer...
Question:
Just use 1-6 then 9-14 and it's work out. I've tried just using all 1-11 to try 10s but it freaks out and beeps alot. The charger is happy to charge any number of cells as long as it's in pairs or up to 7s single. Not sure how cells with a odd number of cells aka 13s can be charged and if you can charge it up using the 7s balance connector then the 6s balance would be my guess.
21" Hardtail, Docs Torque Arm, Lipo 20s2p, ebikes.ca 9C 8x8 and Lyen 6fet (both Mineral Oil cooled)
FastDemise
Postby kfong » Tue May 08, 2012 11:00 am
Here is a picture of how I do it. viewtopic.php?f=31&t=39291
The last picture shows how it's done. You need to use their battery balance port connectors since it's not a one to one pattern unless you want to rewire.
Question:
kfong
Postby docnjoj » Tue May 08, 2012 11:51 am
OK so here is a dummy question. I will have 2 6S lifepo4's A123 in series to make 12 S How should I wire the balance leads so the Hyperion will recognise all of the cells. I would buy Kin's system if I needed it, but how do you plug the 2 6S connectors into Hyperion. Cells 1-6 starting with ground in Port A and cells 7-12/ground in Port B? I'm confused!
otherDoc
Edit: Yes the pack will be a split one with 6S cells on each side of the trike. Much better balance for handling just like my old Ping is doing now.
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby wojtek » Tue May 08, 2012 12:03 pm
docnjoj wrote:OK so here is a dummy question. I will have 2 6S lifepo4's A123 in series to make 12 S How should I wire the balance leads so the Hyperion will recognise all of the cells. I would buy Kin's system if I needed it, but how do you plug the 2 6S connectors into Hyperion. Cells 1-6 starting with ground in Port A and cells 7-12/ground in Port B? I'm confused!
otherDoc
yes, you connect 2x6s in series [44v] and the subpack's balance leads with black main charge wire connected to charger goes to port A and red one goes to port B [very important]
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Postby EBJ » Tue May 08, 2012 12:50 pm
otherDoc
and remember "A" and "B" are not in logical spots... "A" on the right, "B" on the left.
EBJ
Postby EBJ » Tue May 08, 2012 12:53 pm
kfong wrote:Here is a picture of how I do it. http://www.endless-sphere.com/forums/vi ... 31&t=39291
Thanks for the pic. It seems the way I wired mine to begin with is the way you guys are also wiring it.
I just thought people were wiring differently to eliminate a wire and/or get the Hyperion to register 10S without any "0V" ports between.
EBJ
Postby kfong » Tue May 08, 2012 1:35 pm
Yeah I wanted to eliminate all the wires in between, but when you ohm it out you soon realize they went with an unusual wiring pattern that would make it more trouble to rewire and I still wanted to use their setup from time to time.
kfong
Postby wojtek » Tue May 08, 2012 1:40 pm
if i connect 2x EOS 1420i to one single 1500w power supply, will it all work fine? thanks :)
i want to be able to charge my 100v pack as 2x 50v [12s] separately with 2 hyperions and have one 1500w meanwell SPV-1500-24 so i thought it is pretty much enough power for both of them...
wojtek
Postby docnjoj » Tue May 08, 2012 3:00 pm
Um............Black(negative bat terminal) balance wires to port A and Red (positive Batt terminal) balance wires to Port B. Oy! I think I better hold my mouth just right and cross my eyes. If I do it wrong does the smoke come out?
otherDoc
docnjoj
Postby EBJ » Tue May 08, 2012 3:16 pm
otherDoc
The two are marked A and B underneath where the tabs connect. The tabs are only for the balance wires. There are two larger wires for you to tie in the Positive and Negative main wires from the pack.
It's not very tricky... i'm just making it more confusing by asking all these questions about alternative ways to connect the balance wires. I'm going to just stick with what I know works and stop asking questions. lol
EBJ
Postby Sacman » Tue May 08, 2012 4:00 pm
I've made a custom 3-foot wiring harness to connect my Hyperion 1420i to my 12s4p LiPo pack on my ebike via a single VAL-U-LOCK connector plug. Note that I've labeled the A and B portions of my harness to connect to the respective A and B ports on the 1420i. Also note the RED and BLACK wire positions on the harness. You can use that those RED and BLACK wire positions as a guide so you don't confuse yourself on your wiring.
Sacman
Postby rkosiorek » Tue May 08, 2012 8:38 pm
Here is a simple schematic how to wire up the 12S pack to the PortA abd PortB connectors
1420i-12s Balancer by rick_kosiorek, on Flickr
worked fine for me.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby docnjoj » Wed May 09, 2012 6:50 am
Thankyou Rick! That makes sense! My connection between B6 and B7 will be the connection of the two split packs so it will be doubled 12 ga wire and be about 20"long.
otherDoc
docnjoj
Postby 999zip999 » Thu May 10, 2012 11:32 pm
Docnjoj, Are you making a split pack of two 6s one on each side ?
999zip999
Postby cwah » Fri May 11, 2012 1:54 am
I'm looking for a cheap but quiet power supply.
I've found a 600W pc power supply here:
http://www.ebay.co.uk/itm/Envizage-600W ... 1979wt_982
Would that work with the hyperion? And how should I reanrrange the output cables to fit the hyperion?
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby neptronix » Fri May 11, 2012 2:03 am
You'll want 24v and 600w continuous.
+ 12v will not give you the full power ( more like 200-300w ) of the charger.
+ PC power supplies are not rated on their continuous power. They often deliver less than half of what they are rated.
2 x server supplies with their fans tuned down would be good.. and cheap as hell :). Can find them for $15-$20 a pop shipped on eBay..
^-- my vid
https://sites.google.com/site/tjinguytech/my-projects/diy-24v-47a
^-- some info on converting these.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby cwah » Fri May 11, 2012 2:26 am
I would prefer something simpler to set :lol:
Do you think this one would work?
http://www.ebay.com.au/itm/24V-23A-600W ... 3220wt_922
cwah
Postby neptronix » Fri May 11, 2012 2:37 am
Chinese power supply with no brand name or model.
Looks like it might be a distant meanwell ripoff. You get to be the guinea pig and find out if it's gonna blow up on you or not :mrgreen:
neptronix
Postby docnjoj » Fri May 11, 2012 6:22 am
999zip999 wrote:Docnjoj, Are you making a split pack of two 6s one on each side ?
Yes that is how my trike is set up now, and the handling is excellent, If I put a single 12s pack on the rear rack it really handles poorly.
otherDoc
docnjoj
Postby 999zip999 » Fri May 11, 2012 2:15 pm
Triing to fit the 24s on a bike somewhere so I'm going with two 12s. I just order a 24v1000w power supply. So The Hyperion 14s sounds like the best for my needs I'm looking forward to your progess. Docnjoj Have you gotten that Hyperion all plug in and working ?
999zip999
Postby cwah » Fri May 11, 2012 2:23 pm
neptronix wrote:Chinese power supply with no brand name or model.
Just purchased 2 for my dual hyperion.
Going to be a guinea pig. Hope it's going to work well.
cwah
Postby docnjoj » Fri May 11, 2012 2:24 pm
999zip999 wrote:Triing to fit the 24s on a bike somewhere so I'm going with two 12s. I just order a 24v1000w power supply. So The Hyperion 14s sounds like the best for my needs I'm looking forward to your progess. Docnjoj Have you gotten that Hyperion all plug in and working ?
I've played with it a bit but at the moment I dont have any batteries to charge with it that are useful. My pings are both 12S but I need to make a6Sx2 adapter for them. The Fatpacks in // self balance and have no taps on them. I really got it for the A123 20 AH batt I am building. I will start with my 15 volt 24 amp power supply and see what happens. 3-4 amps is fine for me to charge with for36 volts batts. I don need no steenking 24 volt power supplies! ( I hope). I did power it up and went through some of the menus but I am kinda lazy this week!
otherDoc
docnjoj
Postby 999zip999 » Fri May 11, 2012 5:15 pm
I got 1000w 24v that can be 2- 12, 500w. So I have double what every you got 25 cells ect. Great. Sure sounded good. 24s
999zip999
PreviousNext
Return to Battery Technology
Who is online
Users browsing this forum: dendy and 11 guests
