dnmun wrote:what equipment? how did you calibrate it?
Just simple Hyperion EOS0720 charger.
dnmun wrote: why did you only charge to 3.6 and shut off at 2.5 when everyone else uses 3.65V+ down to 2.1V end.
These parameters are suggested by charger, the same like for LiPo 3-4.2V, so I assume hyperion company know what they are doing. And who is everyone else? Maybe just You?
look at the characterystic of A123 system, this is for cylindrical but, I do not think there is much difference for pouch cell except capacity. Do you see how steep is at the end of discharge? How many mAh do you think is possible to get from range 2,5V - 2,1V? 20mAh? 50mAh? I can assure you not to much. Some of my cells are missing more than 0,5Ah and even close 1Ah. What with shortening life when I abuse them? The same story with charging.
dnmun wrote: what would you contest?
Maybe you did not read my post. But how about missing Ah from what is advertised?
dnmun wrote: is there something similar to certification that cells have the specific capacity?
Unfortunately no. My assumption are base only on pdf document from a123system.com
dnmun wrote: is it possible that the capacity will increase when you cycle them several times before you totally discharge them rather than totally discharging them on the very first cycle?
You know, hard to say. I only cycle the weakest 3 times. Capacity results are almost identical.
dnmun wrote:you should not be on this thread anyway since this guy just started the thread to trash the A123 cells he bot on ebay but he could not test them and made obviously distorted statements that the cells would not charge even though his video proved otherwise.
Sorry but I think this forum is to help each other, not to fight and kicking me off. How about my effort to and work I have done to share with others? Is it worthless for you? I have no intention to hijack his thread. I just think is much easy to find more info about A123 if they are in one thread, not to spread in hundreds. And I had no problems to belief him that these cells would not charge, like others does.
Pure wrote:Considering what these cells are, second hand factory rejects, I would still be happy with those numbers. They are still large prismatic A123s and should have no problems giving you a solid 17Ah run.
Probably you right. Dispute might be on for many weeks and I could not do anything with these battery. At least now anyone who buy from a123rc will know what to expect from them.
