Warp Factor II Battery Modules
Re: Warp Factor II Battery Modules
Postby EVDragRacer » Sat Aug 18, 2012 8:29 pm
nieles wrote:not really needed to test the whole pack. you can measure different aspects of the packs an then calculate the v-drop or whatever you want to know.
just make sure you make a plan how you are going to measure it.
below is a picture of how i would measure the contact resistance of the cell connections:
if you do the above, make sure the positive and negative of both packs are protected from eachother
Thanks I will give it a try!
International Electric Drag Racing Association
EVDragRacer
Postby EVDragRacer » Sat Aug 18, 2012 8:37 pm
I want to give some weight number from our pack modules:
10P 1S (3.7n 4000amp)
10 cells = 3.5 lbs
Copper = 1.5 lbs
Each 10P = 5 lbs
35S 147V Pack = 185 lbs est..
54S 227V Pack = 280 lbs est..
80S 336V Pack = 420 lbs est..
EVDragRacer
Postby Hillhater » Sat Aug 18, 2012 8:47 pm
EVDragRacer wrote: I can video tape the BMS Monitor screen which will allow me to see each cell's voltage and each cell's temperature..
ron, ..You wont be able to check individual cell voltages once they are assembled into 10p modules.
You will only see the voltage of the module.
..but that is still V useful.
Hillhater
1.21 GW
1.21 GW
Postby hillzofvalp » Sat Aug 18, 2012 9:05 pm
what kind of PPE do you employ when working with those voltages..?
hillzofvalp
Postby Doctorbass » Sun Aug 19, 2012 10:10 am
I agree for that test. It look like a great way to test the resistive loss thru the parallel connnections !.. It would be interesting to see the results!
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby Hillhater » Sun Aug 19, 2012 7:11 pm
Yes a good initial test, but still only using 1/8th of the max planned 4000A load, so difficult to draw conclusions from.
Ron, if you are all ready for the track this weekend, couldn't you run her up on a dyno and monitor the pack voltage ?
or will you just get that data from your first runs.?
Hillhater
1.21 GW
1.21 GW
Postby EVDragRacer » Sun Aug 19, 2012 9:37 pm
Hillhater wrote:Yes a good initial test, but still only using 1/8th of the max planned 4000A load, so difficult to draw conclusions from.
The Soliton Shiva will provide data from each run.
EVDragRacer
Postby Hillhater » Sun Aug 26, 2012 7:08 pm
EVDragRacer wrote:.....Our first drag race will be this Saturday at Lebanon Valley Dragway.
Any feedback.. ??
Hillhater
1.21 GW
1.21 GW
Postby EVDragRacer » Mon Aug 27, 2012 1:43 pm
Well, just returned from the track. Good day of testing, completed two shake-down runs. Track was swamped today with Gamblers, etc....Only problem is no data, the wire was too short would not reach the computer, will have data on next test.
Results:
Test #1:
1500 BA (each controller)
2000 MA
190 Motor Volts
(Pack was at 230V.)
Time: 60' 1.5 seconds, 1/8 6.6 seconds, 1/4 10.6 @121.36 mph
__________________________________________________ ___
Test #2:
2000 BA (each controller)
2000 MA
200 Motor Volts
(Pack was at 230V)
Time: 60' 1.4 seconds, 1/8 6.5 seconds, 1/4 10.4 @123.83 mph
EVDragRacer
Postby EVDragRacer » Mon Aug 27, 2012 1:44 pm
Additional test day information:
Battery only dropped about 7 volts per run. Cell temp remained under 50c. No sparks from motors or brushes. Controllers worked flawless (I think, no data).
Car developed a clunk in rear diff, will check ring and pinion. Might also change front springs.
Wish I could have tested at full power, but not enough time and very very very HOT day!
EVDragRacer
Postby liveforphysics » Mon Aug 27, 2012 2:10 pm
Isn't that 60ft a little slow for that chassis? 1.5's are pretty easily had by FWD Honda Civics on slicks. :-)
I think if you want to drop a lot of ET, you gotta go something like 3000MA, and you could leave BA at 1500-2000 if you don't want to stress it. Get the 60ft into the 1.3's and I bet it will be running a single digit.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby Hillhater » Mon Aug 27, 2012 6:26 pm
EVDragRacer wrote:Test #2:
2000 MA
200 Motor Volts
(Pack was at 230V)
2000 BA into each controller, so is that 4000 A total load on the pack ??
Hillhater
1.21 GW
1.21 GW
Postby EVDragRacer » Sun Sep 02, 2012 7:19 pm
liveforphysics wrote:Isn't that 60ft a little slow for that chassis? 1.5's are pretty easily had by FWD Honda Civics on slicks. :-)
I agree Luke. These runs were just shake-down runs to check for damage. The pack work flawless and the car launched nice. Last year we ran a 1.4 60', 10.08 1/4 mile @ 128mph with the same settings. The car is a little lighter, but I experimented and installed 3.00 rear ring & pinion, compared to my last years gear of 3.25. I was hoping for a better top end and maintain the 1.4 60', but that did not happen. I am getting data from a dyno this week before I change anything. I know I can get 1.3 60' time if I up the MA to 3000amps, but might need more motor voltage for a higher top end. Many tests ahead. :shock:
EVDragRacer
Postby Arlo1 » Sun Sep 02, 2012 7:22 pm
WHats the stalled motor resistance? You might need more voltage to get the motor amps up!
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby EVDragRacer » Sun Sep 02, 2012 7:23 pm
2000 MA
200 Motor Volts
(Pack was at 230V)
The pack delivered 4000amps with ease.
EVDragRacer
Postby EVDragRacer » Sun Sep 02, 2012 7:24 pm
Arlo1 wrote:WHats the stalled motor resistance? You might need more voltage to get the motor amps up!
The data will show what is needed. I definitely agree that more voltage will be needed to get more motor amps.
EVDragRacer
Postby EVDragRacer » Sun Sep 02, 2012 7:27 pm
This is info I received from an expert in the field.
"Ron,
Yes, the controller is perfectly capable of delivering 3000A to the motor while only drawing 2000A (or even much less) from the battery. All that is necessary is that the motor voltage be 2/3rds the battery voltage when it does so. If your 230V pack did not sag at all then your motor could be driven with a maximum of 153V at 3000A while pulling 2000A from a 230V battery.
The caveat here is that motors require more voltage both to spin at a higher RPM and at a higher torque load (current). That is to say, the more current you push through the motor the more voltage you need to spin at a given RPM.
Because your times didn't change much in going from 1500A to 2000A, I suspect you are maxed out on motor voltage. I don't remember the precise details of your setup in Warp Factor II, but I seem to recall you were running a similar battery voltage back then, no?"
EVDragRacer
Postby Hillhater » Sun Sep 02, 2012 9:24 pm
EVDragRacer wrote:The pack delivered 4000amps with ease.
Did you get any voltage (sag) data from the runs ?
Hillhater
1.21 GW
1.21 GW
Postby EVDragRacer » Sun Sep 16, 2012 9:21 pm
Very little, pack is stiff. Temps only rose to 35c to 40c after each run. The EMUS BMS worked flawless!
Will be getting data at EVCCON, they back to the track at full power. :shock:
EVDragRacer
Postby Hillhater » Wed Oct 31, 2012 5:10 pm
Ron has been a little quiet on here lately ?
..but i notice he posted this on another forum recently..
EVDragRacer wrote:...I know why I am stuck at 10.2 seconds in the 1/4 mile, it's the sag which dropped my voltage down to 113V from a 230V pack. I think adding cells in series will lower my 1/4 mile ET,
:shock:
So , 50% + voltage sag is "very little" is it Ron ?
:roll: :roll:
And appears to have revisited his pack design tab connection method in a 15p module ..
Last edited by Hillhater on Wed Oct 31, 2012 5:36 pm, edited 2 times in total. View post history.
Hillhater
1.21 GW
1.21 GW
Postby liveforphysics » Wed Oct 31, 2012 5:50 pm
The moment you sag past 50%, you extract less power from the battery by pulling additional current.
At 50% sag you're also dumping an equal amount of energy into heating the battery as you are extracting power from it.
Last edited by liveforphysics on Wed Oct 31, 2012 6:18 pm, edited 1 time in total. View post history.
liveforphysics
Postby Hillhater » Wed Oct 31, 2012 6:06 pm
Hillhater
1.21 GW
1.21 GW
Postby EVDragRacer » Sun Nov 04, 2012 2:19 pm
Hillhater wrote:Ron has been a little quiet on here lately ?
:shock:
:roll: :roll:
I'm glad you are following me so closely, can you scratch my azz since your so close? :P
EVDragRacer
Postby EVDragRacer » Sun Nov 04, 2012 2:24 pm
We have decided to stick with our 10P packs and build two separate packs for each Shiva. The picture shown above will not happen. Our 10P batteries cannot be separated so I am drilling & tapping in three location on each 10P side. Plenty of copper to work with, the new series connection method will use a thin copper strip to connect all six holes, and a large braided battery strap from each 10P center hole we tap. Pictures coming soon, I am still testing the condition of all my 10P cells.
EVDragRacer
PreviousNext
Return to Battery Technology
Who is online
Users browsing this forum: 3nslav3 and 12 guests
