gokart battery
Re: gokart battery
Postby Kin » Tue Apr 03, 2012 2:06 pm
Ok! Yeah! You are right. I wasn't looking as closely at his parameters, somehow I read "I want to go 7 and 1/8 miles". apologizes.
Humor me for a moment, but: Perhaps there are certain benefits to a brushed system. If it's a drag race, perhaps there would be no need for a controller, and you could simply use some insane mechanical switch to connect the batteries directly to the motor (if it's just a DC motor, as opposed to AC or BLDC. Is that ever done? Kind of absurd, I admit.
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Re: gokart battery
Postby chbaird » Thu Apr 05, 2012 10:29 am
A mechanical switch works great until it welds itself closed and you can't open it when you're going 90+ mph down a very short road.. :)
chbaird
100 µW
100 µW
Re: gokart battery
Postby 999zip999 » Thu Apr 05, 2012 10:32 am
Pic's please.
999zip999
Re: gokart battery
Postby Kin » Fri Apr 06, 2012 9:39 am
chbaird wrote:A mechanical switch works great until it welds itself closed and you can't open it when you're going 90+ mph down a very short road.. :)
True! yeah. Freakishly true. Thinking through the consequences of what I suggested, I had a worried laugh. I suppose, though, that it could be designed with a failsafe (second crowbar designed to always be connected, but with the option of disconnecting it).
Still, I don't like the mechanical solution for further reasons in so far as it's so un-useful.
Kin
Re: gokart battery
Postby Arlo1 » Fri Apr 06, 2012 10:15 am
Yup working on harleys I have seen lots of start solinoids weld them selfs shut. The the bike wont quit cranking till you pull the battery wire off.
On another note You can not use a mechanical set up on a lot of motors the one I have is shunt wound so you need to limit the amperage going to the field coil seprate from the brushes and you can gain some speed by weakening it at higher rpms. As well you can not just short LIPO batteries to any motor as a rule because either the batteries or motor will fail. Lipo will produce more amps then its rated for causing damage to the battery and the motor is only going to take so many amps before the windings burn as well. Remember the brushed karts with BOOST SWITCHES use Led based batteries and led can take it because it just SAGS the voltage way down saving the motor!
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Re: gokart battery
Postby Kin » Fri Apr 06, 2012 10:25 am
True, Arlo1. There would have to be ways to limit the current. I was hoping the resistance in the brushed motor would be enough to limit the lipo's short so that things wouldn't blow up over 15 seconds, but I might be underestimating how precisely low the resistance of these batteries are. anyway, I think i distracted the post a little; i apologize. Your warning is good to keep so that anyone reading this out of context doesn't go ahead without thinking through that problem.
Kin
Re: gokart battery
Postby Arlo1 » Fri Apr 06, 2012 10:54 am
They are taking orders for prebuild Revolt (couger controllers) Here 144v 500 amp $700 pluss 20 shipping in us. 6 month warenty.
Arlo1
Re: gokart battery
Postby Arlo1 » Thu Apr 19, 2012 11:21 pm
999zip999 wrote:Pic's please.
Here is a couple of mine Its 234lbs with full rollcage and suspension. No driver or batteries.
Arlo1
Return to Battery Technology
Who is online
Users browsing this forum: Hillhater, SHARKBITEATTACK and 14 guests
