A123 cell has a puncture,is it usable?
Postby flexy » Tue May 08, 2012 4:00 pm
I just received my A123 cells from Victpower, I found one with a cut in the bottom.
It also had some droplets of liquid on it, I'm not sure if this came out of the cell, it looks like air has got into the pouch so it doesn't feel as rigid as the others (I guess they are vacuum sealed).
the cell measure 3.27V identical to the rest. Would it be safe to keep this cell or will the puncture cause degradation?
flexy
Re: A123 cell has a puncture,is it usable?
Postby ZOMGVTEK » Tue May 08, 2012 4:12 pm
It's not something you want to use when the pouch looses the seal.
Is the 900mAh sticker to fool customs or something?
ZOMGVTEK
Postby flexy » Tue May 08, 2012 4:45 pm
I think it must be, they were listed as 900mAh on all the docs.
They seem to package them in boxes of 14 cells, this must be the optimum for postage weight/volume.
This particular cell came in a box of 6 so they weren't as rigid as the the other packages - and may have been damaged as a result
flexy
Postby el_walto » Tue May 08, 2012 4:49 pm
Throw it out.
el_walto
Postby miuan » Tue May 08, 2012 6:02 pm
let me guess, you have ordered no spares and now looking for an excuse to salvage this one. horrible idea. it may be ok just sitting on the desk, but start using it, add some shock, temp and moisture changes, and the cell could slowly degrade. i've carefully punctured lipo in a similar way with no apparent ill effects, but that cell would never make it into my pack again.
miuan
Postby dnmun » Tue May 08, 2012 6:13 pm
the term is 'hermetically sealed' and the pouches are assembled inside a machine where the atmosphere is totally controlled to prevent any moisture or humidity to reach the lithium on the anode and the lifepo4 cathode mixture since moisture causes the lithium to oxidize. and yep it is a vacuum to suck it all tight.
you are the first person who has a clear reject delivered to you. i expect they will replace it even though they should pay shipping, they won't i expect. maybe buy an extra one or two when you contact them so the shipping cost is not totally wasted.
dnmun
Postby liveforphysics » Tue May 08, 2012 6:56 pm
It's toast. Once they get oxygen inside, they are a hazard. Don't just throw it in the garbage either. Destroy it with overcharge, or slash it open in a bucket of water (outside obviously) and leave it alone for a few days of little bubbles until the potential energy is dissipated.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby texaspyro » Tue May 08, 2012 10:34 pm
liveforphysics wrote:It's toast. Once they get oxygen inside, they are a hazard. Don't just throw it in the garbage either. Destroy it with overcharge, or slash it open in a bucket of water (outside obviously) and leave it alone for a few days of little bubbles until the potential energy is dissipated.
Awww, now where's the fun in that? :roll:
texaspyro
Postby flexy » Wed May 09, 2012 2:20 am
Message received, loud and clear :)
I do have some spares but I will ask for a replacement. Strangely, it looks like it was cut on purpose - maybe customs wanted a peek inside such a large 900mAh cell :wink:
I wish I knew a local place I could properly recycle these, got some dead headways too, can't waste lithium!
flexy
Postby flathill » Wed May 09, 2012 2:33 am
flexy wrote:Message received, loud and clear :)
Another casualty of the war on drugz
wouldnt have cut it open if they thought it was a bomb
Thanks for protecting not protecting our safety while looking out for the old boys
flathill
Postby JRP3 » Wed May 09, 2012 6:33 am
Actually lithium is cheap and there isn't much in the cell at all. Maybe you could discharge it and dissect it just for fun, then put the foils in with recycled metals.
Building the AMPhibian http://amp-phibian.blogspot.com/
JRP3
Postby bigmoose » Wed May 09, 2012 7:54 am
Likely cut with a box cutter during all the shipping steps these cells went through.
If you still have the cell and are willing. A photo documented disassembly of the cell would be useful for us all to try to determine what could have been accidentally "misplaced" by the A123 production machinery.
bigMoose's electronic pieces & parts (GENUINE IRFB4110Pbf's, Nomex 410, AntiCorrosion Grease, Current Sensors) available HERE.
Thanks to Justin ebikes.ca for securing the board then setting us FREE! Tech Tips in the WiKi: http://endless-sphere.com/w
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
bigmoose
Postby flexy » Wed May 09, 2012 4:21 pm
I will have a go, but should I try and discharge it with a resistor across the terminals first?
Liveforphysics method sounds fun :twisted: (but maybe too destructive)
flexy
Postby ZOMGVTEK » Wed May 09, 2012 9:11 pm
Resistors are slow. Big metal things dropped across the terminals is faster.
ZOMGVTEK
Postby bigmoose » Wed May 09, 2012 9:21 pm
Yea, dead shorts are faster; but we don't want to destroy the evidence inside. We have seen lots of fireballs, but I do not think we have seen the internals of an A123 Prismatic yet. It would be great to see inside, au natural, don't you think?
bigmoose
Postby liveforphysics » Wed May 09, 2012 10:09 pm
Yes! Dave's idea is much better. Connect a car headlight or brake light lightbulb across those terminals, and let it sit for a few days until the voltage reads 0.2v.
Put on safety glasses, a plastic face shield, a respirator, long plastic gloves, and cut away the foil off the top of the pouch. Then, the safest option would be submerging it outside in a bucket of water for a day to make sure everything is fairly neutralized.
Then begin dissecting (with proper safety equipment on, outside or in a place with excellent ventilation).
liveforphysics
Postby flexy » Thu May 10, 2012 3:51 pm
I was thinking along those lines, or that gear Ypedal's wearing :)
This ingredient breakdown was on the docs that came with the cells, not sure if it applies to these cells in particular or it's just safety guidelines for generic lipo.
http://dl.dropbox.com/u/8208701/Electric%20scooters/lipo%20chemicals.PDF
flexy
Postby JRP3 » Thu May 10, 2012 4:50 pm
Is there really that much potential for mayhem with a fully discharged LiFePO4 cell? Especially when I've seen some of you guys holding smoking cells of more volatile chemistries in your bare hands :shock:
JRP3
Postby liveforphysics » Thu May 10, 2012 4:55 pm
JRP3 wrote:Is there really that much potential for mayhem with a fully discharged LiFePO4 cell? Especially when I've seen some of you guys holding smoking cells of more volatile chemistries in your bare hands :shock:
The A123 pouches can be pretty touchy. If I was doing it myself, I would just cut into it with a razor knife and bare hands and get it done. But I would never encourage anyone else to take my approach, too many things could potentially go wrong, and too many nasty solvents and chemicals that might hurt someone who is into doing the longer-term-staying-alive thing.
liveforphysics
Postby potatorage » Fri May 11, 2012 6:50 pm
I had a cell that wasn't as tight as the others, but I don't see any noticeable flaws. Is it safe to use?
potatorage
Postby flexy » Sat May 12, 2012 1:26 pm
I have taken the cell apart, here are some pics.
There was a strong sweet smell from the liquid inside ,this soon evaporated.
You can see where the cell was originally punctured the cathode/anode has started to degrade. there were about 60 layers altogether.
Hard to see what might have been out of alignment, without a reference to compare to. I did notice on some of the others what appears to be loose bits of tape, trapped under the case, causing an uneven surface. This might cause problems when they are all under compression in a large pack, causing them to be rejects.
All photos here https://www.dropbox.com/sh/kmnlhfj21ibb22i/Ip4onBU4xq
flexy
Postby bigmoose » Sat May 12, 2012 1:46 pm
Flexy, THANKS! Outstanding execution of a Destructive Physical Exam! I would bet the "bump" I fell down the center of one of my cells is a full wrap of that green tape. Looks like a straightforward zig zag of the separator with alternate cathode and anode. Each with a tab at the top of thin foil that gets ultrasonically welded together to thick tabs to exit. The kapton tape around the ultrasonic weld almost looks hand applied, but that can't be true. Interesting that there are 3 or 4 layers there. Would have thought automating the process would be one layer of a thicker kapton...
Your capture of the degradation of the plates once the foil pouch was cut is priceless! Thanks again for doing this. We have all learned from your bad cell. :D
bigmoose
Postby flexy » Sun May 13, 2012 6:00 am
bigmoose wrote: The kapton tape around the ultrasonic weld almost looks hand applied, but that can't be true. Interesting that there are 3 or 4 layers there. Would have thought automating the process would be one layer of a thicker kapton...
There is just a single layer of kapton either side of the weld.
Most of my cells had small dents on the tabs like they had all been tested with a voltmeter by hand (Victpower Quality Control?)
I also had one labelled "test" which had a lower reading than the others, that's not getting picked for the team either!
flexy
Postby bigmoose » Sun May 13, 2012 6:49 am
Good catch where the eye is better than a photo! Here is the area that interested me, can you tell what the other two "films" or tapes are that have straight cut edges. So the serrated edge is a single kapton tape.
bigmoose
Postby flexy » Sun May 13, 2012 10:21 am
The serrated edge is where the kapton tapes from the front and back of the terminal weld come together.
The other cut edge is the bottom of the slightly opaque plastic (or teflon as some have called it) which surrounds the terminal where the top of the pouch is sealed.
flexy
Return to Battery Technology
Who is online
Users browsing this forum: No registered users and 6 guests
