High Current Schottky Diodes?
Re: High Current Schottky Diodes?
Postby rkosiorek » Tue May 15, 2012 8:24 pm
full-throttle wrote:@ rkosiorek: I know what the "ideal diodes" are http://www.ti.com/lit/an/slva139/slva139.pdf
I've used the P-ch circuit as reverse polarity protection
It won't work in this case since each pack will turn the fet on and subsequently short the two packs together
A circuit based on fets would work as long as there's logic in place to turn the highest pack on only - but that is not an "ideal diode" anymore
well "true ideal diodes" with a proper controller do not allow reverse current under any circumstances.
http://cds.linear.com/docs/Datasheet/4357fd.pdf
that TI appnote is not a full implementation of an ideal diode. it just a partial implementation that uses some features of an ideal diode in a charger. in a true ideal diode.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby full-throttle » Tue May 15, 2012 11:54 pm
rkosiorek wrote:well "true ideal diodes" with a proper controller do not allow reverse current under any circumstances.
In the event of a power supply failure, such as if the output of a fully loaded supply is suddenly shorted to ground, reverse current temporarily flows through the MOSFET that is on. This current is sourced from any load capacitance and from the other supplies. The LTC4357 quickly responds to this condition turning off the MOSFET in about 500ns, thus minimizing the disturbance to the output bus.
page 6 in your link
Otherwise it's essentially what I wrote
full-throttle wrote:A circuit based on fets would work as long as there's logic in place to turn the highest pack on only
Look, I don't want to argue - it appears our definition of "ideal diode" is different. Others got to understand they are not really diodes so should not be treated as such.
full-throttle
Return to Battery Technology
Who is online
Users browsing this forum: Trailblazer and 7 guests
