Apparently now they are making the nano-tech's in small cylindrical format. I took the largest capacity one they have listed (1.2Ah), and ran the numbers on it. Came out in cost between their 25C and 40C nano-tech pouch cells, but a higher density both by volume and weight than any of their other cells. Not anywhere near the Panasonic 18650's in density, but a hell of a lot higher C rate than those too. They're using an interesting, non-standard size. Converting to standard naming convention would be a 15580 format I guess.
Capacity: 1.2Ah
Constant C-rate: 15C
Length: 58mm
Diameter: 15mm
Weight: 23g
Cost: $2.80
USD/Wh: $0.63
Wh/kg: 193.04
Wh/L: 433.41
Also found this video introducing them.
http://www.youtube.com/watch?v=D_PsILc1h8E
Judging from the post date, it looks like they only launched them 6 days ago, so I guess that answers the question I was going to ask, which is has anyone gotten any of these to play with.
I can't quite tell from the picture they have what the terminals are like or how rigid the casing is, but these look interesting, imo.
