DIY battery + Capacitors, useless or ok?
Re: DIY battery + Capacitors, useless or ok?
Postby Tommy L » Sat May 26, 2012 6:31 pm
spuzzete wrote:I think you missed the graph I posted. You can clearly see that 47Kph is downhill. My bike has a 36v 500w geared motor. Top speed on the flat (no pedalling) is 32kph If I want to go more I go downhill or I pedal. I am fine with that. Also typical power draw on the flat and no pedalling is between 300-500w depending on wind/slight uphill or downhill.
I may not be an expert in electronic but I can count.
Peace.
8)
Fair enough, it looks like you have it under control. :)
Tommy L sends.... \\m//
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
viewtopic.php?f=4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
Tommy L
Postby Tommy L » Sat May 26, 2012 6:33 pm
ProDigit wrote:And TommyL, it seems you're very close to being one of those forum jerks who only tend to bitch at people when they differ in opinion about something, or disagree with you, or talk about things you don't know pipsqueak about!
oh my, if you read any of my posts you will see that I genuinely try to help others here. And we help without using profanity.
Did you read this from my earlier post? It does clarify many things to a new poster here. I'm merely trying to assist "SPUZZET".
A battery is a transducer that converts chemical energy into electrical energy and vice versa. It
contains an anode, a cathode, and an electrolyte. The anode, in the case of a lithium battery, is the source
of lithium ions. The cathode is the sink for the lithium ions and is chosen to optimize a number of
parameters, discussed below. The electrolyte provides for the separation of ionic transport and electronic
transport, and in a perfect battery the lithium ion transport number will be unity in the electrolyte. The
cell potential is determined by the difference between the chemical potential of the lithium in the anode and
cathode, ¢G ) -EF.
My question is: what is the regular cathode material to be a regular Li Ion cell?
CoO2 (cobalt oxide)
Mn2O4 (manganese oxide)
NiO2 (nickel oxide)
FePO4 (ferrous phosphate, also know as Iron phosphate)
So the combined chemistry gives the cell a certain potential.
What concerns me here is that we are all trying to help each other, so I'm trying to point out that there is
no such thing as a Regular Li Ion Cell or Battery Pack for someone to purchase. Each chemistry has
pro's and con's and care/maintenance to have longevity and safety.
What one to pick and how much you need is almost always based on what you are trying to achieve and being able
to understand it's limitations and safety requirements once you choose a Li chemistry.
Tommy L
Postby SamTexas » Sat May 26, 2012 7:08 pm
spuzzete wrote:
Fullscreen capture 5262012 42609 PM.bmp.jpg (72.55 KiB) Viewed 345 times
If that's how you ride, you don't have a single thing to be concerned about your battery.
Looking at your final resting voltage and the number of Wh already used, I suspect you have overestimated the true capacity of your pack by 20% to 30%. I think your pack actual, usable capacity is 18 to 20Ah. By actual, usable I mean resting voltage of 3.30V per cell.
SamTexas
Postby megacycle » Sat May 26, 2012 7:27 pm
ProDigit wrote:
megacycle wrote:
ProDigit wrote:You can not solder caps in series, they won't function. THey'll function just like the weakest capacitor in the chain at best, at worst they will function just like an interrupted wire.
Electricity 101 you can put caps in series.
Well, just try it out if you don't believe me. Capacitors should be placed in parallel:
http://lmgtfy.com/?q=solder+capacitors+ ... +or+series
http://www.electronics2000.co.uk/calc/s ... ulator.php
Capacitor calculator shows a DECREASE in capacity when soldering in series; they will function,but just less good than when you'd just take the most powerful capacitor and connect it by itself.
Most tecs like me do calcs like these in their heads and i'm nowhere near as knowlegable as a lot of the guru's, i would'nt even be a Howard Wolowitz, but i've got a good grasp on what you can do with most caps just like other passives as long as you know the specs.
caps in series 1/sum of reciprocals, caps in parallel sum, capacity same, Yawn, want to refresh me on dv/dt.
Iron Horse SGS Pro DH.
72V 16AH lipo. 3kW charging system.
Modded Crystalyte 72V/50A, regen, 3 stage overcurrent.
4060 ☆/\, 20mm cover holes.
Hyena supplied motor (much appreciated Onya mate)
5404 next build giant strata, A123 20Ah, 72/large.
megacycle
Postby spuzzete » Sat May 26, 2012 7:54 pm
SamTexas wrote:If that's how you ride, you don't have a single thing to be concerned about your battery.
Thank you SamTexas!
I may have overestimated the real capacity of the pack of course, and maybe I made a mistake in my calculation assuming the pack would be 100% efficient. As there is always a loss in heat somewhere, I guess you're right. Still not bad for those used cells. I am amazed I could ride almost 50 km with no problems!
This last ride I did try to go the fastest I could on purpose to see the limit of the pack. I was almost expecting a cell failure on my way back home but this confirms that I tested those cells properly before putting them together.
8)
My little experimentation cave ( e-bike / li-ion batteries / electronics / etc. ): jacopo.tk
My Build: 36v 24ah "Home Made" Li-Ion & 500W rear Bafang
spuzzete
Postby SamTexas » Sat May 26, 2012 9:09 pm
You're welcome. If you do decide to proceed with the capacitor experiment, do come back for a detailed report. I would like to know how it works out.
SamTexas
Postby spuzzete » Sat May 26, 2012 11:37 pm
SamTexas wrote:You're welcome. If you do decide to proceed with the capacitor experiment, do come back for a detailed report. I would like to know how it works out.
I just ordered 2 cell-log 8s so I can produce decent data for the tests I am about to set. I am also tempted to order some of those 1F 5.5v capacitors and try to connect them to each 3,6v "block".
Let's see if it's a total bust or not!
spuzzete
Postby megacycle » Sun May 27, 2012 1:44 am
Looking forward to that if you do, though do'nt use those 1F 5.5's, they'll be back up type, they wont work at all.
You need the pulse power low/ultra low esr variety. I'm about to purchase mine thru Maxwell's site.
Tectate's on the site are the same price right up to 10F @ 2.7v @ $2,so x2, 5F @ 5.5v $4 x 10 =$40 + shipping.
There's also be the time constant thing, i'm trying to get my head around as my set up is to be multi tier
how much power to deliver into what impedance, for what duration :?: Back emf oh no headache again :?
Fetchter's and co. have been doing some nice mod's on the cell logs @ viewtopic.php?f=14&t=20142, i'm using them and done the jumper mod, not sucking so much now on the 1&2 channels.
Good Luck with it.
megacycle
Postby megacycle » Sun May 27, 2012 1:48 am
something like this but it's drawn wrong, as off, in the switching area.
Fetchter's and Co. have been doing some nice mod's on the cell logs @ viewtopic.php?f=14&t=20142, i'm using them and done the jumper mod, not sucking so much now on the 1&2 channels.
Good Luck with it.
megacycle
Postby Njay » Sun May 27, 2012 7:43 am
If you do that cap experiment remember that the cap bank will pull a huge amount of current the instant you connect it to the battery (all sparky and all), so you'll probably need to pre-charge the bank.
Njay
Postby etriker » Sun May 27, 2012 8:31 am
If you are using a 10s laptop cell pack then you can parallel a 11s A123 26650 pack and they will act like caps and keep the current draw lower on the laptop cell pack.
I am using 10s 4p 2600mah laptop cell pack in parallel with a 11 s 3p A123 26650 pack to keep the current draw low on the laptop cell pack.
Allows use of a smaller number of laptop cells.
Going up hills the A123's deliver the amps and down hill the laptop cells recharge the A123 cells.
About 14 ah total. 73 cells total.
A friend is using a 10s 4 p laptop cell pack in parallel with a 11 s 1p A123 pack and also gets good results.
His is an ebike and uses less peak amps than my etrike.
I Think We're All Bozos On This Bus
http://www.youtube.com/watch?v=lmWFrMq3qNY
etriker
Postby Tommy L » Sun May 27, 2012 8:59 am
etriker wrote:If you are using a 10s laptop cell pack then you can parallel a 11s A123 26650 pack and they will act like caps and keep the current draw lower on the laptop cell pack.
This is interesting. What is the voltages of the two packs?
10s V?
11s V?
I'm trying to wrap my head around this. :)
Tommy L sends...
Tommy L
Postby etriker » Sun May 27, 2012 9:17 am
They are in parallel so the voltages on each pack are the same when sitting with no current draw on the packs.
With a load both packs will sag depending on the load.
The A123's will sag less than the laptop cell pack and deliver more current as the load increases.
Real world ebiking is up and down hills and stop and go for most of us.
The max load on my laptop cell pack does not go very high because the A123 packs hold the voltage up and the laptop cells cannot sag.
The less you sag the laptop cell pack the less you overload it.
etriker
Postby Tommy L » Sun May 27, 2012 9:28 am
etriker wrote:They are in parallel so the voltages on each pack are the same when sitting with no current draw on the packs.
May I please have the standalone voltages of each pack....
10S pack voltage?
11S pack voltage?
When you parallel packs, the higher voltage pack will try to discharge into the lower voltage pack continually trying to equalize.
Do you unplug these packs while not in use?
Or do you charge them together so the voltages always remain the same?
Tommy L sends....
Tommy L
Postby etriker » Sun May 27, 2012 9:38 am
They are discharged in parallel and disconnected and each pack balanced charged with a Hyperion charger.
When they are first connected, both fully charged, the laptop cell pack will deliver current to the A123 pack starting at about 7 amps and dropping to 0 amps in about a min or two.
That is with no load.
10 x 3.7v is 37 volts.
11 x 3.3 is 36.3 volts.
The difference in voltages is the key to this working.
Makes a battery pack setup that can deliver high amps but with a duty cycle.
http://www.zena.net/htdocs/FAQ/dutycycle.shtml
etriker
Postby spuzzete » Sun May 27, 2012 11:49 am
megacycle wrote:Looking forward to that if you do, though do'nt use those 1F 5.5's, they'll be back up type, they wont work at all.
Fetchter's and co. have been doing some nice mod's on the cell logs @ http://endless-sphere.com/forums/viewto ... 14&t=20142, i'm using them and done the jumper mod, not sucking so much now on the 1&2 channels.
Good Luck with it.
Thank you for the suggestion!
I will update as soon as I will have all I need to begin the tests.
8)
spuzzete
Postby spuzzete » Sun May 27, 2012 11:53 am
This is interesting!
What you presented there are the nominal voltages. What are the real voltages of the batteries fully charged?
I charge my li-ion cells to 4.1v each so the pack is about 41v fully charged.
8)
spuzzete
Postby etriker » Sun May 27, 2012 12:03 pm
Right. The A123 pack is slighty lower and when first connected with no load the laptop pack will discharge a little and the A123 pack will overcharge a little. Not much because the laptop pack does not have much power to deliver at that voltage and the voltages even out soon.
I take off and ride right after I connect them in parallel so they both start to discharge soon.
Dkangls mapping battery cells posts show the voltages where cells have their power.
You can also map whole packs.
The goal is to use all the cells so not to overload any of them and run them in the range suggested in their data sheets.
Alone an a123 11s 3p pack will not power my trike for long and the 10s 4p laptop pack would be way overloaded by itself.
Together they will push my trike about 40 miles if I help a little. :)
etriker
Postby liveforphysics » Sun May 27, 2012 1:43 pm
Just working some energy storage vs voltage drop calcs.
You could add enough super caps to your battery to be equal to the size and weight of your battery, and have less than 10sec of discharge before the caps drop to the voltage your cells would sag to with no caps, making the caps dead-weight until you let off the throttle for 20-30seconds again, then you could get 10seconds of simulating running a less saggy battery again.
Also, this is kinda funny, but good RC LiPo can output higher power per volume and per weight than super caps.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby CamLight » Sun May 27, 2012 2:55 pm
megacycle wrote:These are the one's was hoping to use, 2 in series should give the time constant i need, though how does this relate to :? scratching my head again :roll: :lol: .
http://www.tecategroup.com/store/index. ... ucts_id=95
Those are very high internal-resistance caps. Be sure to do the math for their current-supplying capabilities. :D
John M.
Owner
CamLight Systems
CamLight
Postby CamLight » Sun May 27, 2012 3:02 pm
ProDigit wrote:Well, just try it out if you don't believe me. Capacitors should be placed in parallel:
Huh?
Of course caps can be placed in series. It's the only way to use capacitors in an application where the voltage level is higher than the cap's rating. There's absolutely no way I can use a 2.7V-rated 400F supercap along with a 4S LFP motorbike starting pack without the cap blowing up instantly. However, I can take six of those 400F caps, wire them in series, and get a killer 67F-equivalent pack that easily supplies 200A for a couple of seconds.
Do I go down from 400F to 67F when putting them in series? Of course, that's basic electronics for caps in series. But not because caps are supposed to be in only used in parallel. It's the only way to achieve a voltage rating for the thousands of applications out there for 2.7V (in that range) supercaps.
John M.
Owner
CamLight Systems
CamLight
Postby CamLight » Sun May 27, 2012 3:10 pm
spuzzete wrote:Will it be better or worse if I will connect a 1F 5.5v cap ( http://www.ebay.ca/itm/1F-1-Farad-10000 ... 27c21b24d5#ht_1628wt_952) to each one of the 3.6v cells?
Using supercapacitors and having to balance them separately sounds like a pain.
8)
Using a 5.5V cap connected across each cell is a great idea. Unfortunately, that cap you mentioned will only supply milliamps (if that) at a time. You need a cap that supplies 10's of amps, with a very low ESR (resistance) value to prevent large voltage drops inside the cap. This low ESR requires LOTs of room to achieve and leads to very large supercaps. There's just no way to do it with small caps.
There are some 5.5V caps with moderate ESR that might be able to help your cells a bit. Not as much as another cell or the very-low ESR cap types (typically 2.5V or 2.7V-rated), but perhaps just enough. Or, you could wire two 2.7V low-ESR caps in series across each cell and just take your chances in regard to balancing. With only two caps in series there's a lower chance of them going out of balance.
John M.
Owner
CamLight Systems
CamLight
Postby CamLight » Sun May 27, 2012 3:12 pm
liveforphysics wrote:Also, this is kinda funny, but good RC LiPo can output higher power per volume and per weight than super caps.
Agreed!
I'm working with a client now doing some preliminary tests using LiPo in an application where we were originally only considering supercaps. There are some definite benefits to both approaches, it's been very interesting!
John M.
Owner
CamLight Systems
CamLight
Postby liveforphysics » Sun May 27, 2012 3:14 pm
It's also important to realize the energy storage of caps placed in parallel or series is identical.
Say we have 4 x 2.5v 100F caps. If we stick them all in parallel, we get a 2.5v 400F cap. If we go 2p2s, we get a 5v 100F cap. If we go 4s, we have a 10v 25F cap.
2.5v^2*400F = 2500J
5v^2*100F = 2500J
10v^2*25F = 2500J
No matter how you group them, as many in series or parallel as you like, the energy stored is just the energy storage of a single cap multiplied by the number of caps, the capacitance decreasing as you stack them in series is not a decrease in energy storage.
Caps are great for filtering voltage spikes in either direction. Caps are an awful alternative to a battery for anything involving stead-state current draw.
liveforphysics
Postby megacycle » Mon May 28, 2012 9:00 am
Really enjoying this thread, very lively :D, learning a lot.
Sorry :oops: about the double post i'll try and have it deleted,
think it happened as there were two or more of us posting at a time.
Good to have some figures Luke.
If those 3x16V@25F small blocks i mentioned were used that would be around 4000J, yeh then there's losses in those series esr's and even say 3800J is say only 380W of sag fill for those 10 sec you were talking about, and the caps then asking for recharge from a depleting battery anyhow, so hill climbing's no good and at around $400+ for those cap's, those supplementary A123's look good for the solution to your problem.
With the secondary packs that could hold true for a few combinations, that's great news.
megacycle
PreviousNext
Return to Battery Technology
Who is online
Users browsing this forum: Alan B, nieles and 14 guests
