DIY battery + Capacitors, useless or ok?
Re: DIY battery + Capacitors, useless or ok?
Postby spuzzete » Sun May 27, 2012 11:49 am
megacycle wrote:Looking forward to that if you do, though do'nt use those 1F 5.5's, they'll be back up type, they wont work at all.
You need the pulse power low/ultra low esr variety. I'm about to purchase mine thru Maxwell's site.
Tectate's on the site are the same price right up to 10F @ 2.7v @ $2,so x2, 5F @ 5.5v $4 x 10 =$40 + shipping.
There's also be the time constant thing, i'm trying to get my head around as my set up is to be multi tier
how much power to deliver into what impedance, for what duration :?: Back emf oh no headache again :?
Fetchter's and co. have been doing some nice mod's on the cell logs @ http://endless-sphere.com/forums/viewto ... 14&t=20142, i'm using them and done the jumper mod, not sucking so much now on the 1&2 channels.
Good Luck with it.
Thank you for the suggestion!
I will update as soon as I will have all I need to begin the tests.
8)
My little experimentation cave ( e-bike / li-ion batteries / electronics / etc. ): jacopo.tk
My Build: 36v 24ah "Home Made" Li-Ion & 500W rear Bafang
spuzzete
Postby spuzzete » Sun May 27, 2012 11:53 am
etriker wrote:
That is with no load.
10 x 3.7v is 37 volts.
11 x 3.3 is 36.3 volts.
This is interesting!
What you presented there are the nominal voltages. What are the real voltages of the batteries fully charged?
I charge my li-ion cells to 4.1v each so the pack is about 41v fully charged.
8)
spuzzete
Postby etriker » Sun May 27, 2012 12:03 pm
Right. The A123 pack is slighty lower and when first connected with no load the laptop pack will discharge a little and the A123 pack will overcharge a little. Not much because the laptop pack does not have much power to deliver at that voltage and the voltages even out soon.
I take off and ride right after I connect them in parallel so they both start to discharge soon.
Dkangls mapping battery cells posts show the voltages where cells have their power.
You can also map whole packs.
The goal is to use all the cells so not to overload any of them and run them in the range suggested in their data sheets.
Alone an a123 11s 3p pack will not power my trike for long and the 10s 4p laptop pack would be way overloaded by itself.
Together they will push my trike about 40 miles if I help a little. :)
I Think We're All Bozos On This Bus
http://www.youtube.com/watch?v=lmWFrMq3qNY
etriker
Postby liveforphysics » Sun May 27, 2012 1:43 pm
Just working some energy storage vs voltage drop calcs.
You could add enough super caps to your battery to be equal to the size and weight of your battery, and have less than 10sec of discharge before the caps drop to the voltage your cells would sag to with no caps, making the caps dead-weight until you let off the throttle for 20-30seconds again, then you could get 10seconds of simulating running a less saggy battery again.
Also, this is kinda funny, but good RC LiPo can output higher power per volume and per weight than super caps.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby CamLight » Sun May 27, 2012 2:55 pm
megacycle wrote:These are the one's was hoping to use, 2 in series should give the time constant i need, though how does this relate to :? scratching my head again :roll: :lol: .
http://www.tecategroup.com/store/index. ... ucts_id=95
Those are very high internal-resistance caps. Be sure to do the math for their current-supplying capabilities. :D
John M.
Owner
CamLight Systems
CamLight
Postby CamLight » Sun May 27, 2012 3:02 pm
ProDigit wrote:Well, just try it out if you don't believe me. Capacitors should be placed in parallel:
http://lmgtfy.com/?q=solder+capacitors+ ... +or+series
http://www.electronics2000.co.uk/calc/s ... ulator.php
Capacitor calculator shows a DECREASE in capacity when soldering in series; they will function,but just less good than when you'd just take the most powerful capacitor and connect it by itself.
Huh?
Of course caps can be placed in series. It's the only way to use capacitors in an application where the voltage level is higher than the cap's rating. There's absolutely no way I can use a 2.7V-rated 400F supercap along with a 4S LFP motorbike starting pack without the cap blowing up instantly. However, I can take six of those 400F caps, wire them in series, and get a killer 67F-equivalent pack that easily supplies 200A for a couple of seconds.
Do I go down from 400F to 67F when putting them in series? Of course, that's basic electronics for caps in series. But not because caps are supposed to be in only used in parallel. It's the only way to achieve a voltage rating for the thousands of applications out there for 2.7V (in that range) supercaps.
John M.
Owner
CamLight Systems
CamLight
Postby CamLight » Sun May 27, 2012 3:10 pm
spuzzete wrote:Will it be better or worse if I will connect a 1F 5.5v cap ( http://www.ebay.ca/itm/1F-1-Farad-10000 ... 27c21b24d5#ht_1628wt_952) to each one of the 3.6v cells?
Using supercapacitors and having to balance them separately sounds like a pain.
8)
Using a 5.5V cap connected across each cell is a great idea. Unfortunately, that cap you mentioned will only supply milliamps (if that) at a time. You need a cap that supplies 10's of amps, with a very low ESR (resistance) value to prevent large voltage drops inside the cap. This low ESR requires LOTs of room to achieve and leads to very large supercaps. There's just no way to do it with small caps.
There are some 5.5V caps with moderate ESR that might be able to help your cells a bit. Not as much as another cell or the very-low ESR cap types (typically 2.5V or 2.7V-rated), but perhaps just enough. Or, you could wire two 2.7V low-ESR caps in series across each cell and just take your chances in regard to balancing. With only two caps in series there's a lower chance of them going out of balance.
John M.
Owner
CamLight Systems
CamLight
Postby CamLight » Sun May 27, 2012 3:12 pm
liveforphysics wrote:Also, this is kinda funny, but good RC LiPo can output higher power per volume and per weight than super caps.
Agreed!
I'm working with a client now doing some preliminary tests using LiPo in an application where we were originally only considering supercaps. There are some definite benefits to both approaches, it's been very interesting!
John M.
Owner
CamLight Systems
CamLight
Postby liveforphysics » Sun May 27, 2012 3:14 pm
It's also important to realize the energy storage of caps placed in parallel or series is identical.
Say we have 4 x 2.5v 100F caps. If we stick them all in parallel, we get a 2.5v 400F cap. If we go 2p2s, we get a 5v 100F cap. If we go 4s, we have a 10v 25F cap.
2.5v^2*400F = 2500J
5v^2*100F = 2500J
10v^2*25F = 2500J
No matter how you group them, as many in series or parallel as you like, the energy stored is just the energy storage of a single cap multiplied by the number of caps, the capacitance decreasing as you stack them in series is not a decrease in energy storage.
Caps are great for filtering voltage spikes in either direction. Caps are an awful alternative to a battery for anything involving stead-state current draw.
liveforphysics
Postby megacycle » Mon May 28, 2012 9:00 am
Really enjoying this thread, very lively :D, learning a lot.
Sorry :oops: about the double post i'll try and have it deleted,
think it happened as there were two or more of us posting at a time.
Good to have some figures Luke.
If those 3x16V@25F small blocks i mentioned were used that would be around 4000J, yeh then there's losses in those series esr's and even say 3800J is say only 380W of sag fill for those 10 sec you were talking about, and the caps then asking for recharge from a depleting battery anyhow, so hill climbing's no good and at around $400+ for those cap's, those supplementary A123's look good for the solution to your problem.
With the secondary packs that could hold true for a few combinations, that's great news.
Iron Horse SGS Pro DH.
72V 16AH lipo. 3kW charging system.
Modded Crystalyte 72V/50A, regen, 3 stage overcurrent.
4060 ☆/\, 20mm cover holes.
Hyena supplied motor (much appreciated Onya mate)
5404 next build giant strata, A123 20Ah, 72/large.
megacycle
Postby spuzzete » Mon May 28, 2012 4:44 pm
Hi liveforphysics,
wouldn't be cheaper and less complicated to use RC LiPo (http://www.hobbyking.com/hobbyking/stor ... _Pack.html) instead of supercaps then? Etriker did it with A123 cells, but I think it's better to use lipo with li-ion, the operating voltages are closer than A123.
I find this discussion extremely interesting, lots of learning for me.
8)
spuzzete
Postby spuzzete » Mon May 28, 2012 4:50 pm
CamLight wrote:Using a 5.5V cap connected across each cell is a great idea. Unfortunately, that cap you mentioned will only supply milliamps (if that) at a time. You need a cap that supplies 10's of amps, with a very low ESR (resistance) value to prevent large voltage drops inside the cap. This low ESR requires LOTs of room to achieve and leads to very large supercaps. There's just no way to do it with small caps.
Thank you for the heads up on the 5.5V caps! I would have wasted my money!
I think I would wire 2x2.7V supercaps to each cell if I decide to try supercaps.
8)
spuzzete
Postby etriker » Mon May 28, 2012 4:59 pm
I stopped testing rc lipo when I found the cells can dead short.
A shorted lipo cell in a pack that is in parallel with another pack could be really bad.
Other than that they might work ok. Or they might get puffy and well, you know ! :)
Anyone want to try and let us know ? I am scared to try that. :)
I am collecting Makita cells to test in a parallel pack with laptop cells. If they don't need balancing then the whole setup could be charged at once.
The A123 cells I am using are from 2006 recovered from bad Dewalt packs.
6 years old and still going ! :)
Overcharge them, overdischarge them, for being li cells they are hard to kill.
Laptop cell packs make good extender packs for long rides. My laptop cells are also from 2006 recovered from bad hp battery packs.
etriker
Postby megacycle » Tue May 29, 2012 6:10 am
6 years :shock: how many cycles you had, and how are they handling, capacity and C still good :?:
megacycle
Postby etriker » Tue May 29, 2012 8:43 am
Over 120 on the laptop cells at least. Am using b grade cells for sure that were stacking up so I wanted to do something with them.
The A123 cells are on their 3rd life. They were used in a rc car.
When going on trips of about 12 miles or less the A123 pack alone is fine.
Up to about 40 miles I hook them both together.
The A123 pack has way more cycles than the laptop pack.
There is another goal too and that is to make the pack last because it sure does take a lot of time to test the cells and build one.
Old laptop cells will last longer if you don't get them too warm.
I charge the laptop pack at about 2 amps. Slow. The cells don't get warm.
Same with discharge. Don't sag them too hard and only use about 70% or less.
The A123 cells charge really fast. :)
etriker
Postby megacycle » Tue May 29, 2012 9:52 pm
Yeh that A123 fast charge is great I've been pumping my 20Ah pouches , let me rephrase that :shock: at 80A+ :evil:
megacycle
Postby eTrike » Mon Oct 15, 2012 9:55 pm
I see that this thread is several months old now, but having read through it I thought I would offer the information I have gathered regarding the benefits of supercapacitors. As others have stated the excess weight and cost would probably be best used for more batteries. Supercapacitors have the advantage of softening the brute force load experienced by the batteries which leads to voltage sag. The voltage sag is a detrimental phenomena which would ideally be mitigated completely, and as the evidence suggests would lead to great improvements in the useable lifespan of even low-power rated laptop cells. The combination of the two yields the best of both, just as eTriker's A123/Laptop hybrid pack enjoys benefits of power from A123 and capacity from laptop cells. In the case of supercapacitors, the available power is multiplied several fold. I've done a substantial amount of research recently. Here are a few papers to Google and read if you'd like.
1. "Performance Studies of Li-Ion Battery-Super Capacitor Hybrid Systems"
2. "Performance Optimization of battery-capacitor hybrid system"
3. "Power and Life Extension of Battery-Ultracapacitor Hybrids"
4. "Nanotechnology Enabled Hybrid Power Systems"...
The fourth uses A123 and Ioxus technologies. Interesting reads, for those so inclined.
There is also a venture using lead-acid/ultracap systems which has been tested extensively by Honda, if memory serves.
Cheers to the future!
eTrike
Postby megacycle » Tue Oct 16, 2012 10:18 pm
Hi buddy.
Exciting stuff happening in all sectors.
Just biding time one, till new generation, storage and delivery technology become of age.
Be good for my retirement, about 10yrs, cheap clean energy, massive densities and fast delivery and recharge availablity.
megacycle
PreviousNext
Return to Battery Technology
Who is online
Users browsing this forum: evee, parajared, Rollodo, seanski and 11 guests
