HK Cell-Log Cell Voltage Monitor 2-8S Lipo?
Postby SamTexas » Tue Jun 26, 2012 10:11 am
http://www.hobbyking.com/hobbyking/stor ... _Lipo.html
I am very dissatisfied with HK Battery Monitor 2-6S (http://www.hobbyking.com/hobbyking/stor ... _2_6S.html). They are extremely inaccurate. I'm now looking for something better with the data logging ability.
Questions:
1) Are you satisfied with the voltage accuracy of the above Cell-Log?
2) What (if any) features/functions you like the least?
3) Would you buy it again?
4) Is there a better product in that price range (around $30)?
Thanks.
SamTexas
Re: HK Cell-Log Cell Voltage Monitor 2-8S Lipo?
Postby Ykick » Tue Jun 26, 2012 10:24 am
Great device, I started with M versions but this year went with S version from EPBuddy and it's awesome to record cell voltage curves during rides. Accurate enough for me and will read 1S up to around 40V I believe? Built a simple test lead and often use it as a handy pocket volt meter.
Ykick
Postby docnjoj » Tue Jun 26, 2012 10:29 am
Yep Cell logs are cheap and mine seem to be accurate. I fried one with reverse polarity on a single cell reading. Oops! Otherwise great.
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby 999zip999 » Tue Jun 26, 2012 1:15 pm
I got the hyperion pack sentry. It shows the cell voltage one by one total pack voltage to 7s and % of difference of high and low cell. It was 13usd. but would like to see all cells voltage at same time. It's O.K. Needed something.
999zip999
Postby Gregb » Tue Jun 26, 2012 6:44 pm
I have 2. (8s) wouldn't be without them. voltages readings agree with my DMM. Use the LV alarm facility attached to a flashing red taillight to provide me with discharge protection.
Gregb
Postby Ricky_nz » Tue Jun 26, 2012 7:39 pm
Yep celllogs work fine. They don't take kindly to being thrown in a bag with heavy items as the display is quite easy to break though.
Latest Projects: High power vector controller for Turnigy 80-100, Keewe Stealth DJ bike with Turnigy 80-100 180.
Youtube channel: http://www.youtube.com/user/rwhitenz?feature=mhum
1) Specialized Hard Rock + surviving 1/2 of Elation 300W + Sick Bike Parts freewheel and sprockets + echo cranks.
2) Commuter bike with 1000W GM rear hub.
Ricky_nz
Postby elmannen » Wed Jun 27, 2012 6:11 am
I like them to. I have 5 cellogs and everyone is working as excpected so far.
And you can adjust them to bee more accurate so that is no problem either.
/Lasse
elmannen
100 µW
100 µW
Postby dogman » Wed Jun 27, 2012 6:26 am
I have found the single cellog 8 that i have to be more accurate than my cheap chargers. So it's good for me.
As I've said many times though, I don't care about accuracy to .01v. I'm happy enough that however much my cellog is off, all 8 channels read the same compared to each other. So for my purposes, noticing if a cell is .05 off and doing something about one when it gets near .1 off, the cellog has been my tool to have.
Next time I have an order off to a place that sells em, I plan to buy several more.
One feature I really like, is that while bulk charging a pile of paralelled packs, you can put a cellog on the balance wires, and it will start beeping if a cell is overcharging. 8) So I want more of em, so I can put one on each pack as I charge 4 packs at a time.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby SamTexas » Wed Jun 27, 2012 10:20 pm
Thank you all for sharing your experience. This is great, no complaint at all (except for the easily broken display).
SamTexas
Postby deVries » Wed Jun 27, 2012 11:30 pm
I highly recommend the Celllog that will also log data while actually riding your ebike. I plan to post my data graphs using the A123 20Ah cells & also with my LiPo too. We need more actual in-use data from the field, and this is "the man" the celllog man for that job we need the data from. :idea: :twisted:
Another very cool feature using the Celllogs is it will work with Fechter's current limiter to shutdown the bulk charger if the Celllog detects a weak-high cell going "hot" at HVC. 8)
deVries
Return to Battery Technology
Who is online
Users browsing this forum: nlc, nomoreice and 7 guests
