Vectrix 102 cell NiMH Battery Analysis
Mr. Mik   1 kW
Post by Mr. Mik » Sep 05 2008 10:23am
Hi,
I'm new on this forum. :D
I have been reading the recent thread on NiMH Thermal Balancing and found it most interesting. There seems to be a good knowledge base about NiMH issues on ES.
My Vectrix is out of warranty and I call it the Vectux.
I am planning to dismantle the NiMH battery pack in order to determine if any of the 102 cells are damaged or under-performing. I am also considering to install a BMS, Cycle Analyst or other monitoring system whilst the battery is in pieces.
It will be a big job, taking up at least a full week, maybe a month.
I have an IMAX B5 Balance Charger to play with and a West Mountain CBA2 battery analyzer in the mail.
I have previously removed the batteries in order to enable motor controller repairs, but have not yet taken the individual cells apart.
I need ideas about how to plan this, in order to minimize downtime, and maximize knowledge gain.
There will undoubtedly be more questions once the cells are separated from each other, but I need a clearly laid out testing and recharging plan to follow once I begin to dismantle the cells, or the spontaneous discharge rate will make individual cell results more difficult to compare to each other.
I hope to get away with about 1hr per cell for internal resistance and capacity testing, and then 6 hrs to recharge a set of 6 cells at a time.
Any suggestions how to tackle this?
Mr. Mik
There is always a way if there is no other way!
The writer of this post accepts no responsibility or liability resulting from attempts to repeat or perform the procedures described in this post. This information may be used at your own risk.
docnjoj   100 GW
Re: Vectrix 102 cell NiMH Battery Analysis
Post by docnjoj » Sep 05 2008 2:37pm
I dont know anything about scooters, but have been using NiMh for quite a while. What capacity and voltage for the system and how many cells? I count 54 but i cant tell if there is a second layer. It sounds like the BMS keeps charge percent between the high and low, sort of like the Prius.
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
Mr. Mik   1 kW
Post by Mr. Mik » Sep 05 2008 5:40pm
docnjoj wrote:I dont know anything about scooters, but have been using NiMh for quite a while. What capacity and voltage for the system and how many cells? I count 54 but i cant tell if there is a second layer. It sounds like the BMS keeps charge percent between the high and low, sort of like the Prius.
otherDoc
They say 125V, 30Ahr, 3.7kWhr.
The number of cells is 102.
They are arranged three layers deep in two separate aggregates:
The larger one on the left is the rear battery in the scooter and weighs 47kg. It has two strings of 27 cells in it.
The smaller one weighs 42kg and has a single string of 48cells in it.
Here is a schematic to show the principle - the cell numbers are different:
This design is making it possible to disconnect the batteries without potentially getting exposed to the full voltage.
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 06 2008 1:46am
The multiple small black and white cables coming out of the packs are the connections to the 12 temperature sensors spread throughout the two packs.
I am planning to take the cover off the batteries soon and to remove one or a few cells in order to prepare for the big job.
Then replace them so the scooter runs until I am ready to work on it daily for at least a week.
The aims:
1) Determine torque settings to be used in the re-assembly of the pack. Let me know if you have any idea how to do this, please! (I have torque wrenches)
2) Prepare a connector that easily and securely attaches to the cells for the 204 measurements and 17 recharges.
This needs to include a good, fast thermal connection for the temp sensor which is on the way together with the West Mountain CBA2 battery analyzer.
I am considering to do an initial resistance test on each cell as described in the CBA2 owners manual:
Charge the pack, set the CBA, for example, to 11 A; assuming the battery is safe at that level. Run the test
for 30 seconds and record the voltage at the end of this test. Run a test again at perhaps 1 amp for another
30 seconds and record the voltage again. If the battery has .5 volts less at 11 A than it does at 1 A use
Ohms law: R=E/I. R being resistance in Ohms, E is voltage in volts and I current in amperes. The internal
resistance of the pack, in this example, would be: R = .5/10 or .05 ohms. Note that we used the difference
in current between the two tests of 10 A.
and then a capacity test on each cell.
3) allow inspection of an individual cell.
4) start marking/numbering the cells, at least the top layer.
5) assess if and how fast temperature measurements of the cells can be obtained in order to assess if they receive different amounts of fan forced cooling air flow. This will have to be a fast and well planned operation to enable comparison of all cell temperatures before they spontaneously equalize. IR thermometers might or might not work reliably on the reflective metal surface of the cells. I hope the plastic cover around the cells can be removed quickly to allow access to one surface of each cell so that I can take temp readings with an IR thermometer. Maybe I'll record sound whilst calling out the battery number and corresponding temperature reading, then transcribe it later and cross reference it with the internal resistance values.
I might have to paint pats of the cells to enable IR temp measurements.
6) do a test run of resistance and capacity measurement and recharging procedure using the IMAX B5 Balance Charger.
Mr. Mik
olaf-lampe   10 kW
Post by olaf-lampe » Sep 07 2008 5:34am
You will not get any significant temperature differences spontaneously, unless you draw excessivly high currents.
Why do you want to disassemble the whole pack? It looks like you can charge/discharge the single cells by using simple krokodile -clamps on the battery connectors.
-Olaf
Mr. Mik   1 kW
Post by Mr. Mik » Sep 07 2008 4:06pm
Thank you, Olaf.
I hope you are right about there likely not being any temperature differences.
Temperature differences might occur due to varying internal resistance and high current draw or over-charging.
The temperature could also differ between cells because less of the heat is removed from some areas of the pack due to differences in the air flow pattern.
During riding air enters through inlets under the front fairing, during recharging two fans continuously suck lots of air in through the same inlets and pump it out above the rear wheel. Sometimes these fans also start to run during or after riding, or when the scooter has just finished charging and the batteries are very warm.
I believe that I need to dis-assemble the pack because if I did discharge one cell at a time, running the capacity test whilst it is still connected to the other cells, that would surely cause some trouble, maybe destroy the pack???
It might also be impossible to get to the two lower layers of cells with alligator clips.
And I would like to check that all connections are firm, especially the ones between the three layers of cells.
Today I have jerry-rigged a hoist to lift the batteries out more easily and set up a space to do the testing when all is ready to go.
So far the plan is to ride the Vectux until 1/2 empty, then remove seat, battery cover etc and place the scooter in the right spot under the hoist, then jack it up into a stable position on a concrete block. Then I'll loosely place the cover back on, just enough to keep the air-flow characteristics unchanged from normal, but removable in seconds.
Then I'll do a full recharge, followed immediately by lifting off the cover, disconnection of the blue connector between the three strings of cells in the batteries, removal of the pos and neg battery cables and temp sensor cables, attachment of the hoist and lifting out of the batteries.
Then immediately measure individual cell temperatures.
A slow test run will be done first to test and practice it all, the plan might change....I'll keep your suggestions in mind!
Mr. Mik
Ypedal   100 GW
Post by Ypedal » Sep 07 2008 4:38pm
Welcome to the forum !
Interesting pack, nicely built from the looks of it, any model/brand/etc info on the cells themselves ?
A few different ways to do this, but if it was me and i wanted to know the health of the pack without getting too fancy... i'd rig up a stationary load ( like a big honking resistor or a wack of lightbulbs )
Check the voltage of each cell , note..( yes. all 102. gulp.. i have done similar things with a big string of D cell nimh 8ah , 72v, time consuming, but fun if you are that geeky !! :P )
Discharging/charging the whole pack in one shot will speed things up considerably and you don't have to seperate the cells to do it. Also a good way to assess the charge termination of your charger !!
ES site status page:
Mr. Mik   1 kW
Post by Mr. Mik » Sep 08 2008 5:30am
Thanks, I'll consider that, too!
No writing on the visible parts of the cells; Parker-Hannifin made, I believe.
EDIT 2010-09-07: Cells are made by Gold Peak.
More detailed photos of the pack can be viewed in this previous post on V.
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 09 2008 6:32am
I got a reply to an email enquiry from BattEQ makers Smartsparkenery today: Unfortunately no NiMH BattEQ is available yet.
They are prioritizing the work on the SolarBridge and do not know when/if a NiMH EQ will be made, although the Switched Capacitor System is theoretically suited to all battery chemistries.
Does anyone reading this have the experience to take an educated guess if a Switched Capacitor System could be home-made and how difficult it would be?
At a guesstimated cost of AU$6000.- for a battery replacement for the Vectux it would be cost neutral to build a BMS that increases lifespan of the pack by 30% even if it costs AU$2000.- (Excluding my labor, that is paid for by the learning experience!)
If it is made from durable components then it might be used again in the next pack, or even in a pack with a different chemistry.
Or what other approaches to make a NiMH BMS could be taken?
Maybe it is not even remotely useful to install an equalizer into a Vectrix NiMH pack.
I hope we will be able to clarify this in the next few weeks.
The West Mountain CBA2 battery analyzer should be here tomorrow and things will be a lot less theoretical from then on!
I'll probably test it on a few innocent NiMH AAA's to get my bearings before diving into the Vectux pack...
Mr. Mik
fechter   100 GW
Post by fechter » Sep 09 2008 9:10am
Welcome!
Yes, that is an ambitious project. Looking at what Honda and Toyota do with their hybrid packs, I would suggest testing blocks of cells, like 6 or 7, whatever is convenient. If one block tests significantly differently, then it may warrant testing at a single cell level.
I designed a switched capacitor balancer, but using available switched capacitor IC's the current was very low, like 100ma. It would also take a crapload of them for that pack.
Other battery managment schemes for large Nimh packs usually involve measuring the voltage at every 6 - 8 cells and using a microprocessor to limit the charge and discharge.
A modified version of my LiFePO4 BMS circuit could provide a similar function. I would not recommend monitoring every cell, but again groups of cells.
One problem is charging Nimh is different than lithium. Detecting end of charge is trickier but they make chips designed to do this. Simple temperature controlled charging might work too if there were enough temperature sensors.
olaf-lampe   10 kW
Post by olaf-lampe » Sep 12 2008 7:57am
If you are interested in a Data logger that is capable of measure up to three temperatures, volts, ampere and so on, you may like this one:
http://www.hobbycity.com/hobbycity/stor ... 3_E-Logger
This way you can compare your batteries blockwise (up to 70V) while you drive and download the logged Data to your PC and compare it.
-Olaf
Mr. Mik   1 kW
Post by Mr. Mik » Sep 13 2008 5:12pm
Thank you for your replies. Most helpful.
There is some trouble with my Photobucket account, nothing seems to work right at the moment.
All the old links have disappeared, too. Hope that gets sorted.
So, no pictures for now. :cry:
I did consider monitoring blocks of cells with a PackTracker before, and data logging might be very interesting indeed.
I'll have time to research these options once the capacity testing is under way. All 102+ hrs of it...
It took longer than expected to solder connectors onto the CBA2 and the Imax B5 charger, but now it's all ready to roll.
Test runs on a very mixed bunch of AA, AAA and "D" NiMH cells continue to teach me about the glitches etc. which I might encounter during testing of the 102 cells. Very nice toys, the CBA2 and the charger.
I decided to go with the flow instead of trying to design the optimal setup for the test. I just have to accept that the Vectux will be off the road for several weeks. It has been running well for several thousand kilometers now - good to enter into "preventative maintenance" territory for once!
The rear battery is now dismantled and the front battery will be next.
I did fully charge the batteries with the on board charger before taking it apart, but as the Real World has it, it behaved strangely during the last recharge, just to muck things up!
Instead of displaying EC, and counting down for the last hour of charging, it showed CP and continued to count up, then stopped after about an hour. But the current draw was as it would have been in EC mode.
The battery is "relatively" full and should be about as balanced as the Vectrix BMS can achieve.
I hope that starting with a full pack will allow more accurate comparison of the individual cell's capacity.
Because it will take weeks to complete testing, I might wait a few days before starting the capacity testing, as spontaneous self-discharge is highest early on. Apparently up to 10% on day one. So if I wait at least 24hrs after the last charge, then the differences between cells might be less due by self discharge. And I have more time to get ready...
The interesting results so far:
1) Torque for the inter-battery connection bolts is 10Nm. Using my torque wrench in reverse, I could loosen most of the screws with 8-9Nm torque. Re-tightening them at 10Nm caused the same result, so the setting I will use is 10Nm.
2) The battery recall was indeed necessary - it appears to me that the bolts holding the "inter-level-connectors" have been torqued to 5Nm (the lowest one was only 3Nm) instead of 10Nm. These bolts are the same size as all the others, but have different letters and numbers on the top.
My guess is that the batteries were assembled into packs of 8 and 9 cells at the battery factory, using correct torque settings; and then the assembly into complete packs of 102 cells was buggered up somewhere else by using 5Nm instead of 10Nm to tighten the bolts holding the battery temp sensors and the connectors between the three layers of cells.
None of the connectors in the rear battery had actually rattled loose - guess that says something about the tolerance level built into that part of the scooter.
3) There are 2 voltage sensors (and a ground connection) in addition to the 6 temp sensors in the rear battery,
I am expecting more voltage sensors in the front battery, will find out soon.
More when Photobucket works again...
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 14 2008 8:14am
Photobucket still seems to be going through some turmoil....
Now the old linked photos are back, but my "Albums" have disappeared....
So yesterdays pics will have to do for now:
I'll make an educated guess that the batteries were assembled into packs of 8 and 9 cells at the battery factory, using correct torque settings; and then the assembly into complete packs of 102 cells was buggered up somewhere else by using 5Nm instead of 10Nm to tighten the bolts holding the battery temp sensors and the connectors between the three layers of cells.
None of the connectors in the rear battery had actually rattled loose - guess that says something about the tolerance level built into that part of the scooter. But tightened to the correct torque of 10Nm will make tham much safer!
I was expecting more voltage sensors in the front battery, but there are none.
Added 2008-09-18: Sorry, but I just learned that the conventional way to number batteries in series is to start with Nr1 at the negative end of the series. I took a punt without researching it and got it wrong!
Some more pictures:
Mr. Mik
docnjoj   100 GW
Post by docnjoj » Sep 14 2008 9:55am
What kind of cells did they use?
otherDoc
Mr. Mik   1 kW
Post by Mr. Mik » Sep 14 2008 3:59pm
docnjoj wrote:What kind of cells did they use?
otherDoc
I am not sure, but believe they are a custom cell for the Vectrix.
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 14 2008 7:44pm
This photo shows the entire 102 cells and the way that they are connected in series when they are inside the scooter.
The thin black and the thin red cable are added in to show where the shorter leads of the blue connector would be connected to.
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 14 2008 9:05pm
Here are the first capacity test results:
Added later: THESE ARE ALL WRONG DUE TO CABLE AND CONNECTOR RESISTANCE! SEE POSTS BELOW!
Added 2008-09-18: Sorry, but I just learned that the conventional way to number batteries in series is to start with Nr 1 at the negative end of the series. I took a punt without researching it and got it wrong!
The testing started 25hrs after the last recharge, so about 10% capacity might have been lost to spontaneous self discharge.
I set the voltage cutoff at 1.1V. This is quite high and causes a lower capacity to be found than if, say, 0.9V was used as the cutoff voltage.
The reason for this is that the Vectrix electronics shut down power delivery to the motor at a battery string voltage of 108V.
108V / 102 cells = 1.0588V/cell.
The CBA 2 software allows 0.1 increments in cutoff voltage, so I chose 1.1V. Maybe I could have typed into the field and used 1.06V but I thought of it too late. Now I want to continue with the same setting for all cells to make the results more easily comparable.
The discharge current was set as 20A. Although the CBA2 can apparently test a single NiMH cell at up to 25A (to a cutoff level of 0.9V) it gives a warning message at anything over 20A.
So I kept it at 20A.
This is the discharge curve for the first cell (I numbered them starting from the cell at the POS end of the string.):
10.56Ah capacity under these specific conditions.
The next screenshot shows the overlay of the discharge curves of cells 1 to 5:
Nicely balanced by the looks of it.
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 14 2008 11:10pm
Here are part of the txt file the CBA2 allows to export after a test.
They show the capacity for the first 20 cells tested.
I wonder if there is a systematic error of sorts which causes the gradual decline in capacity.
Added later: YOU BET!!! THESE ARE ALL WRONG DUE TO CABLE AND CONNECTOR RESISTANCE! SEE BELOW!
It might also be due to spontaneous self discharge.
Any ideas about this, anyone?
Here is the data:
West Mountain Radio - CBA
Test Report: Vectux Cell Nr 1
Description: 1 NiMH cell, 30.0 Ah @ 20.00A
Started At: 09/14/08 18:08:22 E. Australia Standard Time
Discharge Rate: 20.00 A
Starting Voltage: 1.20 V
Ending Voltage: 1.10 V
Total Time (hh:mm:ss): 0:31:41
Tested Capacity: 10.56 Ah
Test Report: Vectux Cell Nr 2 error 0.9V cutoff
Started At: 09/14/08 18:58:33 E. Australia Standard Time
Ending Voltage: 1.18 V
Total Time (hh:mm:ss): 0:00:30
Test Report: Vectux Cell Nr 2 repeat at 1.1V cutoff
Started At: 09/14/08 19:03:31 E. Australia Standard Time
Starting Voltage: 1.19 V
Total Time (hh:mm:ss): 0:30:50
Tested Capacity: 10.28 Ah
Test Report: Vectux Cell Nr 3
Started At: 09/14/08 19:45:23 E. Australia Standard Time
Total Time (hh:mm:ss): 0:31:30
Tested Capacity: 10.50 Ah
Test Report: Vectux Cell Nr 4
Started At: 09/14/08 20:25:17 E. Australia Standard Time
Total Time (hh:mm:ss): 0:31:10
Tested Capacity: 10.39 Ah
Test Report: Vectux Cell Nr 5
Started At: 09/14/08 21:02:47 E. Australia Standard Time
Total Time (hh:mm:ss): 0:30:44
Tested Capacity: 10.24 Ah
Test Report: Vectux Cell Nr 7
Started At: 09/14/08 22:28:11 E. Australia Standard Time
Total Time (hh:mm:ss): 0:31:09
Tested Capacity: 10.38 Ah
Test Report: Vectux Cell Nr 8
Started At: 09/14/08 23:07:02 E. Australia Standard Time
Total Time (hh:mm:ss): 0:30:41
Tested Capacity: 10.23 Ah
Test Report: Vectux Cell Nr 9
Started At: 09/14/08 23:42:17 E. Australia Standard Time
Total Time (hh:mm:ss): 0:29:48
Tested Capacity: 9.93 Ah
Test Report: Vectux Cell Nr 10
Started At: 09/15/08 00:33:30 E. Australia Standard Time
Total Time (hh:mm:ss): 0:29:05
Tested Capacity: 9.69 Ah
Test Report: Vectux Cell Nr 11
Started At: 09/15/08 05:38:54 E. Australia Standard Time
Total Time (hh:mm:ss): 0:28:44
Tested Capacity: 9.58 Ah
Test Report: Vectux Cell Nr 12
Started At: 09/15/08 06:16:41 E. Australia Standard Time
Total Time (hh:mm:ss): 0:28:50
Tested Capacity: 9.61 Ah
Test Report: Vectux Cell Nr 13
Started At: 09/15/08 06:52:03 E. Australia Standard Time
Total Time (hh:mm:ss): 0:28:42
Tested Capacity: 9.57 Ah
Test Report: Vectux Cell Nr 14
Started At: 09/15/08 07:41:09 E. Australia Standard Time
Total Time (hh:mm:ss): 0:28:32
Tested Capacity: 9.51 Ah
Test Report: Vectux Cell Nr 15
Started At: 09/15/08 08:14:02 E. Australia Standard Time
Total Time (hh:mm:ss): 0:28:43
Test Report: Vectux Cell Nr 16
Started At: 09/15/08 09:25:46 E. Australia Standard Time
Total Time (hh:mm:ss): 0:29:32
Tested Capacity: 9.84 Ah
Test Report: Vectux Cell Nr 17
Started At: 09/15/08 09:59:08 E. Australia Standard Time
Total Time (hh:mm:ss): 0:28:48
Tested Capacity: 9.60 Ah
Test Report: Vectux Cell Nr 18
Started At: 09/15/08 10:34:12 E. Australia Standard Time
Total Time (hh:mm:ss): 0:29:08
Tested Capacity: 9.71 Ah
Test Report: Vectux Cell Nr 19
Started At: 09/15/08 11:10:15 E. Australia Standard Time
Total Time (hh:mm:ss): 0:28:24
Tested Capacity: 9.47 Ah
Test Report: Vectux Cell Nr 20
Started At: 09/15/08 11:49:03 E. Australia Standard Time
Total Time (hh:mm:ss): 0:28:51
Tested Capacity: 9.62 Ah
End of data......................................................................................................................
This next screenshot shows Cell 1 and cell 20 curves:
Here are some more questions I need some help with, if you please could answer:
Could I just add on a 30sec discharge test at 10A at the end of the capacity tests to calculate internal resistance?
The curve seems to be still quite flat at that stage so I think this might be feasible.
Or would different voltages be better for this purpose, maybe a 10A and a 1A run of 30s each?
I am not always at the computer when the test finishes by reaching the 1.1V cutoff, so it might be better to run two tests with varying voltages rather than "tagging on" only one more test, because there would be a varying time interval between cutoff level being reached and the next test.
Any suggestions how to best do this? Which voltages and for how long?
It would save a lot of time if I could do the resistance testing when the individual cell is already connected. It takes time to screw the cables to the cells for the measurements:
And how - if adviseable at all - should I best recharge the cells with the IMAX B5 charger?
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 14 2008 11:45pm
I think the cables and paticularly the connector are introducing too much resistance.
The cable temp is 27C and the connector 33C in 24C ambient temperature.
Pulling the connector apart and then re-connecting it prior to testing cells 22 23 caused higher capacity results again:
10.01Ah and 10.21Ah.
I guess I'll solder much thicker cable straight to the CBA2 and to two of the inter-cell connectors to get rid of this problem.
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 15 2008 8:28am
I have soldered thicker cables straight to the CBA2:
The results appear massively improved so far:
Test Report: Vectux Cell Nr 25
Started At: 09/15/08 21:38:47 E. Australia Standard Time
Starting Voltage: 1.32 V
Total Time (hh:mm:ss): 1:17:07
Tested Capacity: 25.71 Ah
Taking into account the 55hrs since the last charge the result of 25.71Ah probably very close to true this time.
I'll just have to figure out how to best complete the discharges of the 24 cells measured with the old setup.
I need to point out that I did solder a different connector to the West Mountain CBA2 battery analyzer before doing any tests.
The local electronics shop people told me that the Andersons connector that was originally on it is rated to 25A, and the cconnector I replaced it with is supposedly rated to 70A. ( I was initially planning 30A or 40A discharge rates)
So, maybe the CBA2 would have been fine for the job if I had not done anything to it.....
But I believe the thicker cables are an improvement.
Anyways, a valuable lesson learned. Amazing how an increase in resistance by 11% can cause the Ah rating (AKA Range) to drop to less than half! Image
I was initially worried about my soldering when the cables coming out of the CBA2 measured a temp of 33°C during the Cell 25 measurement; but it turns out (by running the CBA2 without the red bottom part for Cell 26 and using an IR thermometer) that the soldering is fine, the cables just act as a heat sink.
Is it normal for the 25A fuse in the CBA2 to heat up to 68°C at 20A???
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 20 2008 6:03am
As I have mentioned in the above posts: I was not aware of the conventional numbering system for cells in a battery string and unfortunately started to count upwards from the positive end of the string, the opposite of how it should be.
It is too much effort to change all the file names, and the text displayed in the .bt files that the CBA2 software produces cannot easily be changed at all.
So for now I'll stick with the erroneous numbering system.
It's easy enough to calculate 103 - "incorrect cell number" = correct cell number if you need to know the correct number in the string.
So I'll call the cells "103-x", with "x " being the number I have written on the cells.
Here is the data from Block "13-4," containing cells 103-28 to 103-35.
(Since I soldered thicker cables without connectors to the CBA2 I am getting consistent results.)
Test Report: Vectux Cell Nr 103-28
Started At: 09/16/08 13:43:25 E. Australia Standard Time
Starting Voltage: 1.31 V
Total Time (hh:mm:ss): 1:12:57
Tested Capacity: 24.32 Ah
Test Report: Vectux Cell Nr 103-29
Started At: 09/16/08 15:02:58 E. Australia Standard Time
Total Time (hh:mm:ss): 1:11:33
Tested Capacity: 23.85 Ah
Test Report: Vectux Cell Nr 103-30
Started At: 09/16/08 16:38:40 E. Australia Standard Time
Total Time (hh:mm:ss): 1:13:13
Tested Capacity: 24.41 Ah
Test Report: Vectux Cell Nr 103-31
Started At: 09/16/08 18:25:44 E. Australia Standard Time
Total Time (hh:mm:ss): 1:11:51
Tested Capacity: 23.95 Ah
Test Report: Vectux Cell Nr 103-32
Started At: 09/16/08 19:43:34 E. Australia Standard Time
Ending Voltage: 1.09 V
Total Time (hh:mm:ss): 1:13:20
Test Report: Vectux Cell Nr 103-33
Started At: 09/16/08 21:01:50 E. Australia Standard Time
Total Time (hh:mm:ss): 1:12:36
Tested Capacity: 24.20 Ah
Test Report: Vectux Cell Nr 103-34
Started At: 09/16/08 22:23:52 E. Australia Standard Time
Manually cut off at 1.1V : Tested Capacity: 24.47 Ah
Total Time (hh:mm:ss): 1:10:54
Tested Capacity: 23.63 Ah
Test Report: Vectux Cell Nr 103-35
Started At: 09/17/08 04:23:56 E. Australia Standard Time
Total Time (hh:mm:ss): 1:10:10
Tested Capacity: 23.39 Ah
Here are the screen shots (click to enlarge):
And here the overlay of the 8 cells - this block 13-4 seems to have relatively well matched capacities and/or balanced cells:
Unfortunately this is not the case with all the 12 blocks. I'll post more later on.
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 20 2008 7:34am
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 20 2008 9:27am
Here are the screenshots from Block 13-5:
And here is the overlay:
About 1.5Ah difference in capacity between the highest and the lowest capacity cell.
But block 13-5 still looks kind of acceptable to me....
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 20 2008 9:48am
But Block 13-6 contains an abnormal cell:
(This is where the graph-overlay function of the CBA2 shines!)
Here are the individual graphs:
Over 9Ah reduced capacity in cell 103-48...this one will will get a closer look when the first run of tests is done.
Mr. Mik
docnjoj   100 GW
Post by docnjoj » Sep 20 2008 9:51am
Looks pretty good to me also! I wish my 10 ah cells were in that good shape! Thats only 5% difference at 20 amps! those are really good quality cells!
otherDoc
