We all know that Ping is one of the cheapest long lifetime LiFePO4 packs out there(Calendar life is still being tested by the community, lol.). However, it lacks the ability to supply great current. A123s are great at supplying the high amps when you need it most(going up hills, accelerating from a start, etc.) but are fairly expensive for any reasonably long-distant range. However, the motor is usually consuming a lot less current when it's reached "top speed", so the a123s are being used for a lot less than their potential for a great majority of the time. So why not get the best of both worlds and use a lot of Ping and a little of the a123s(or other high-C alternatives like 20-30C liPos?)?
As some of you might know, I'm working on an electric scooter which I've developed some electronics for. I think I have the necessary electronics experience and materials to create the necessary "current splicer" circuit, haha. So, what do you think of the idea and does anyone have ideas on how the best of both worlds can be combined at the technical level?
I think the ramifications of this basic idea would be most drastic for motorcycles. Instead of going with a huge ton of a123s to get any decent range, why not use a lot of the low C-rate lifepo4 and use a little of the premium content when the current needs are high? It seems like it would drastically cut down construction costs but yet have nearly the same range of performance(Assuming decent range is desired from the beginning).
