Rodney64 wrote:Deutch the 3 speed switch you were talking about are you making it yourself or did you buy it.
I purchased it from Lyen with my controller. Over 2000 miles on it switching between 40% 99.9% and 120% with zero issues of any kind so far.
korpin wrote:hey by Deutch420,are you gonna have any air cooling on that 10,500 watts?....wow the bomber is only 4500 watts on the specs,but I do not know the true voltage times amps on the bomber do you?
not sure about the 8 gauge wire but according to the electricians chart,if you are intermimittent rating of maxinum 2 minutes then its fine but 6 would be needed for a longer duration of 80 amps and over 115 volts for over 2 minutes but its close
and any idea on what kinda weight you will be at?
Yes, i plan to have air cooling. For the Phasor i plan to use the 5
40
3 from the group buy. Its huge. Just some holes drilled in the side covers should be more than enough. In fact, i have about 2000 miles on my current setup, (18fet lyen @ 80amps 5
30
4 STOCK 100v 24s4p) without any issues at all, so far. My GM at 5kw melted 2 phase wires together, but the 5304 has had no issues. Yes, i am now, and will be, over double the power of a bomber. But you must realize that just b/c i have the power doesnt mean you always use it. I use 10kw for maybe 1-3 minute intervals. I assume if i was to blast around at 10kw for longer periods than that, other components would be an issue well before the wire would. I dont think stealth has the luxury to tell the consumer they cant use the bike to its full potential for over 3 minutes blah blah.... They must limit the power as to avoid noobs overheating things, so it has its tradeoffs.
In regards to weight. My Kona weighs 38lbs stock. I use 24x of the 4S hardecase packs and the 5304 and my bike weighs 95lbs (including some mud). So im assuming between the hub, battery pack, wires, controller, gps, CA etc.... i should expect 50-55lbs worth of crap getting added the the Phasor. I think David already said how much everything weighs, however i have no idea how much just my frame weighs, so this is the best comparison i could do.
GM Rear, 12 FET Lyen @ 45A, 24s2p Turnigy LiPo, 1999 Mongoose: 49MPH.
5304 rear 18FET lyen @ 80amps, 24s4p Kona Dawg: 52mph | 5403 rear @ 80amps 100v = 58mph
Winter build *5403 rear 24FET Lyen @ 100amps, minimum of 100v 20ah. Phasor 4130 frame
