The main judder problem caused by the headset is fixed, gone. YAY!
I expected the 26" wheel's change of the bike's geometry to cause me death-shimmy problmes at speed, but up to 24MPH, the fastest I got up to, it was smooth as could be. Actually was far better than it had been with 24", as the twitchiness and over-sensitivity to correction steering is gone. I can now lean back and just touch the bars to keep going.
This makes sense, as I designed the bike for same size tires front and rear, although i didn't do any calculations or anything to figure it out, I did fix it up and adjust it for two 24" wheels, originally. All frame adjustments and whatnot were done around those, right up until I put the 26" 9C motor on the front. I did try a 26" regular rear wheel at one point, but I don't remember the results of that, other than bending up the rim on potholes and taking it off, going back to a 24"--taht was back when I still had powerchair chain-drive.
So now it's two 26" wheels, and although the bike is a tad taller than I want, it rides way better than 26" rear and 24" front.
Ideally, I will get the GM/9C combo motor laced up into a 24" wheel, and then be able to go back to the 24" wheel in front, and then I'll have essentially the same geometry as I do now, so it should feel the same. Well, except for better takeoff torque from the smaller wheel, and lower top speed (which I don't care about, as I can already do 15MPH over what is allowed on the roads--for commuting, all I care about is how quickly I can get started and up to 20MPH
The only problem I had at all was in the last mile, when the rear tire started to slowly go flat. Might've started before that but I could feel it then. As noted above, it was probalby a tire lever gash, and took over an hour to get the wheel off to fix it. I have not yet put the wheel back on as I am testing another thicker tube at high pressures off the bike before I mount the wheel.
I had not planned to take it apart to check the axle/dropouts but since I did ahve to, I looked at them and saw no sign yet of problems, even with max throttle and max regen braking repeatedly over the test ride. We'll see how they last over time, though. It took months or more for the wrench-torque-arm to break, and the hose clamp on the other torque arm to shear thru.
Since I am using clamping droputs *and* axle nuts, hopefully I will not have problems like that again.
The patched tube, and the flat:
