grindz145 wrote:...my old 350 watt hub motor that is pretty much a pile of rust.
nutsandvolts wrote:My motor has been through slushy salt hell, and though parts of it appear to be rusty, it still works the same.
I'm not sure I'd try to seal it because water WILL get in there then become trapped.An apparent solution would seem to be sealing the motor against water entry, but at least from our experience this is not the case. A disproportionately high number of these failures occured on motors that had had the wire entry to the hub thoroughly sealed with silicone or other goop. Rather than keep the motor dry, water inevitably leaks in and is then trapped inside. Unless you can be sure that you have sealed 100% against water entry, it would be better to leave the wire port as is and to always store the bike indoors, preferably in a warm place, after riding in the rain so that the hub innards get a chance to dry out.
Troubleshooting
People who live in salt slush hell know that you can't avoid the stuff, the key is washing it off and letting it dry.
Mike1 wrote:...Then you put it in the oven for 2 hours at 200F.
Mike1 wrote:You could try Electrolube DCA Modified Silicone Conformal Coating. ]
ACF-50 ANTI-CORROSION FORMULA
HOW IT WORKS: ACF-50, Anti-Corrosion Formula, is a state of the art, anti-corrosion lubricant compound, specifically designed for the Aero Space Industry. It is an ultra Thin Fluid Film Compound (TFFC) that actively treats metal using advanced polar bonding technology. As seen from the diagrams, ACF-50’s synthetic inhibitors and active chemistry penetrates through the oxide deposits (white powder) to the base of the corrosion cell where it emulsifies, encapsulates, and then lifts the electrolyte away from the metal surface. ACF-50 then allows this moisture to evaporate while providing an atmospheric barrier that prevents further moisture contact. With the electrolyte removed the corrosion process is halted. ACF-50 actively penetrates and “creeps†into the tightest seams, lap joints, micro cracks, and around rivet heads, displacing moisture and other corrosive fluids (orange juice, coke, coffee, salt water) in these corrosion prone areas. ACF-50’s thin film acts like an “OFF SWITCH†for corrosion remaining effective for up to 24 months.
dogman wrote:It made sense to me, once a drop of water gets in, it would tend to stay in there.
zukster wrote:dogman wrote:It made sense to me, once a drop of water gets in, it would tend to stay in there.
I just pointed a heat gun on the low setting at my motor for a few hours. About 6 inches away. It finally worked
after that. But I'd rather do that once in a while then drill a vent hole that could potentially let even more water.
Affliction wrote:You park the bike in the fall and go to ride in the spring and the motors are usually frozen solid with rust!
Affliction wrote:You need a product that is semi fluid so that it creeps and reapplys itself continuiosly to protect the metals from rusting and this includes the tiny hall sensors....Now get a water repellant lubricant such as silicone spray and fog your motor with it
Users browsing this forum: bobzilla, Hwy89, ioputielmomo, justforfun and 14 guests
