Improved Weatherproofing Idea
ACF-50
Postby Affliction » Tue Nov 24, 2009 10:31 pm
It is superior anti-corrosion compound.
It kills corrosion in progress
It prevents new corrosion cells from forming for 12-18 months
It is an excellent penetrant.
It is an excellent light lubricant.
This is good shit! :mrgreen:
If you can get this stuff then it has the same properties of Wurth Film.
All I see while searching this is websites in the UK.
I'd definately use it if it was availabe in Canukistan :P
Lube, corrosion, and penetrating.... all properties you want to protect your hub motor from the elements..
This is probably the same stuff rebranded! The wurth film has actually stopped all rust on my unpainted kickstand mount!
The mount has direct spray from the rear tire and none of the protection has washed off.
Canadian Tire Supercycle Hooligan Frame. Koolstop brake pads.
Dual Chrystalite 408 hubs front and rear. 48 volt 15ah ping battery.
45 kph cruise speed. DX32 Alex rims. Schwalbe Ice Spiker Tires.
Homemade LED lighting. 365 day a year, all weather bike rider!
I buy all my E-bike parts at http://www.ridemore.ca
Affliction
Re: Improved Weatherproofing Idea
Postby rguy56 » Tue Nov 24, 2009 11:42 pm
There's no beach in the world that would compare to the "Rust belt".
If you've never heard the term "rust belt" it has to do with the freeze/thaw cycle that makes the salting of roads reasonable because salt will keep the freezing point of water slightly higher than if it were unadulterated.
I think you only have to look as far as the resale values of cars around the continent to see what the rust belt means. For me, I'd take Ben's advice on this thread...
Bob
rguy56
Postby dequinox » Wed Nov 25, 2009 12:27 am
We used to use a product called "Iron-clad" which was a spray-on compound in a can meant to protect shafts and bearing sheaves from surface rust to keep them looking nice. I imagine it could be applied to the interior components...
What is matter? Never mind.
What is mind? No matter.
- Thomas Hewitt Key
STABLE:
HI-V: Brushed 900 watt currie, Yiyun yk43b controller, 25s8p Sanyo Nicads (Batteries graciously donated by greenerwheels)
(Currently building) Push-E: Push-trailer, Aotema brushed 20" hub motor, 48v LiFePO4 (Parts generously donated by Rassy)
THANK YOU BOTH!
dequinox
Postby zukster » Wed Nov 25, 2009 12:45 am
grindz145 wrote:I plan on using ACF 50 on my motorcycle this winter as well. I think this may be a good bet on the hub motor as well. I still like the small hole idea for re-spraying whatever the corrosion inhibiting agent may be.
I really like the small hole idea to, but I'm going to open up my hub that's going on six months before
I decide for sure. I don't have any anti-corrosive film yet, so for the hub I just repaired with the bad hall
sensors for use with a sensorless controller, what I've done is
- Greased the gears and metal pieces that spin and rub.
- On the inside of the hub where the axle posts stick out, I've applied a good dose of grease to both sides,
to in theory, keep the water out a little while longer.
- Silicone RTV'd the hole where the wires exit the axle.
- Silicone II'ed the screw on cap to seal out the water.
GE Silicone II is just a neutral curing Indoor/Outdoor Silicone Caulking material. Its not as hard
as RTV so I might be able to get the cap of later (maybe).
I'll open this up in a couple of months and after I have acquired some anti-corrosive film spray, then
I'll redo with a small hole and the spray if it needs it.
zukster
Re: ACF-50
Postby zukster » Wed Nov 25, 2009 12:59 am
Affliction wrote:I'd definately use it if it was availabe in Canukistan :P
I think these guys ship to Canada from the US and seem to have resonable price. 14 bucks for 13 oz. spray.
http://www.aircraftspruce.com/catalog/cspages/acf50.php
they have a store in Brantford, Ont, that you can prob order from. I've emailed their main US site
regarding shipping as they may just have it shipped from Brantford anyway.
zukster
Postby zukster » Fri Nov 27, 2009 2:05 pm
No one is getting back to me from above.
Does anyone have any suggestion on alternative products with the same properties or close.
Maybe something a little more common and available around town?
zukster
Postby grindz145 » Fri Nov 27, 2009 3:06 pm
This place is out of GA/CA, I didn't see anything about shipping internationally but I don't imagine over the border to Canada would be a problem. Give them a try maybe. I am going to order some myself. The salt has already started...
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby Affliction » Fri Nov 27, 2009 6:58 pm
zukster wrote:No one is getting back to me from above.
You're not trying hard enough. Call the company and find the local sales rep for your area. These guys work on commission so they won't say no to a sale oportunity. You might have to pick your order up from one of their clients tho. Try calling auto body shops in your area because they frequently use Wurth Film to lubricate door hinges.
http://www.wurthcanada.com/en/contact.html
Company Information
Würth Canada Limited
6330 Tomken Road
Mississauga, Ontario, L5T 1N2
Telephone: (905) 564-6225
Toll Free Phone: 1-800-263-5002
Toll Free Fax: 1-800-347-0677
I.T. Pager 905-564-6225 x4848
1-800-263-5002 x4848
For inquiries about the website, please email webmaster@wurth.ca
For all other inquiries, please email info@wurth.ca
Affliction
Postby zukster » Fri Nov 27, 2009 7:56 pm
Wurth lost a customer. ACF-50 gained one. I called Spruce's Canada number in Brampton, Ontario and they
are couriering me a couple of 13 oz spray cans for 15 bucks each. You shouldn't have to push a company's
main office too hard to get the info I wanted.
Spruce's Bramton Canada number is 519-759-5017.
To order from the Canada web site, click Canada down on the left, the Search for ACF-50.
Its easier to phone them.
zukster
Postby Affliction » Fri Nov 27, 2009 9:29 pm
http://www.bikeradar.com/gear/category/ ... rmula-9086
By Michael Stenning
Products developed for use in the aerospace industry often translate very well to cycling and this is no exception. This is not a PTFE-based water displacer, rather it is designed to form an atmospheric seal against the elements which, it claims, remains effective for 12 months and kills corrosion on contact.
I applied a light application to a pair of SPD cleats sporting some surface corrosion. From the nozzle, ACF-50 is pinkish purple, but within a few minutes the mixture settles to a neutral hue and I was amazed to find the dirty brown corrosion on the cleats had apparently neutralised to a matt black.
While far thicker in viscosity than water displacement sprays, it lends itself better to corrosion prevention than lubrication, so isn't really a chain lube. But I have every confidence that, reapplied twice yearly, it should minimise chances of internal corrosion in frames, trailers and racks, and eliminate the need to drill out corroded SPD shoe fittings - even on bikes living in coastal regions.
Although £12 for a 369g aerosol might not seem particularly cheap, a little seems to go a long way.
Manufacturers description
Imagine a world without corrosion! Just think¿no rust, less maintenance, cleaner engines, greater reliability, higher residual machine value. How much easier things would be! Now imagine a highly sophisticated, non-toxic, active, thin film water-displacing compound. A compound with salt blockers and corrosion inhibitors that stays active for up to 12 months. A lubricant so advanced that it is approved for electrical components (40Kv dielectric yet NO electrical contact resistance). A product that will stop existing corrosion as well as preventing it from starting. A product that was developed to help jet aircraft stay airborne. As close to ZERO CORROSION as nature will allow.
I like the fact they say it coats thick but not good for chain lube? If acf-50 can't provide adequate lubrication then what good is it in a geared hub motor?
Affliction
Postby Affliction » Fri Nov 27, 2009 9:44 pm
I destroy pretty much every component on my bike during a winter from the effects of roadsalt. From the chain to the deraillers and the freewheel sprocket, it's all frocked come spring. The motors are another issue alltogether. Wurth Film is a new discovery for me since last winter and all the repairs I had to do. I lubricate just about every moving component on my bike with it now. All other lubes I tried in the past have washed off and rust ensued. I lubed my chain once when I installed it and I havn't had to do anything since. What good is acf-50 if it can't lubricate?
Affliction
Postby zukster » Fri Nov 27, 2009 10:10 pm
Affliction wrote:What good is acf-50 if it can't lubricate?
I'll let you know when I get it if it can lubricate or not. I'll try it on my chain. I don't care if it lubes the motor or not.
I just want to it to keep the water out, and kill any rust that starts.
Maybe research a bit before posting...
Now we have conflicting advice. In any event, I'll post an update here on how it works for me in both the motor
and chain. There's nothing like a real world test. I'm sure the Wurth Film works well since you've used it with
excellent sucess. That will be my backup plan if there's any problem with the ACF-50.
zukster
Postby Affliction » Sat Nov 28, 2009 12:18 am
The beginning of this thread was all about glorifying this ACF-50 without any proof, all the properties sound good on paper but I finally found a reviewer who uses this on his bike. http://www.bikeradar.com/gear/category/ ... rmula-9086
I've been reading about people prasing this shit for years. But none with actual use testimonials on bikes. Turns rust black? Sounds familiar.....
Auto body shops use a similar product all the time. You can buy this shit at canadian tire. frock I work with different lubricants on a daily basis! :mrgreen: What really turned me off on acf-50 was the review that it was not good for chain lube :P
Meaning it doesn't lubricate as good as the manufacturer advertizes. A bike chain has got to be the hardest thing to take care of on a bike. It is either a rusty mess or it flings grease all over your clothing. If you can maintain a bike chain with little or no effort or mess in road salt conditions then you have found the right product.
Affliction
Postby zukster » Sat Nov 28, 2009 1:39 am
For my chain I've been using I've been using Phil Wood’s Tenacious Oil for for over 20 years now. It sticks to the chain
in the rain and the muck and I only have to reapply ever couple of months (more in winter). If you use too much, some
will fly all over, but then what's left stays on well. I don't know how this stuff would work on winter salt roads.
Affliction wrote:Turns rust black? Sounds familiar.....
Yep, sounds familiar, but I'm committed to try the ACF-50 now. It's already ordered.
I'll post my review as soon as I try it for a while.
Now for Internal Motor Fun :!:
I just opened my 8-Fun Bafang SWXH Hub that's been sealed up and on the road for about six months.
The last couple months here have been like constant rain and I thought it would be a mess inside.
Well I was wrong. There was hardly any corrosion at all and the synthetic grease I applied looks brand
new still. :shock: Its pretty clear now that the motor never got nearly hot enough to liquefy the grease
I used (Castrol Syntec Multi Purpose Synthetic grease). Unfortunately I had the bike inside
by the furnace for a few days so I'm not sure if there was any water in the hub that evaporated before
I had a chance to open it up. The windings look good too, so the motor is still okay. Now I suspect my
controller was causing my bike dying in heavy rains problem.
What kind of hub motor do you have Affliction? The Bafang looks mostly Aluminum inside. That might
explain the lack of rust. There was a bit of white Aluminum Oxide corrosion on the screw on cap, but that
was it. I made no attempt to plug the hole where the wires exit the motor through the axle on this hub.
Now its hard to tell if I really needed to order a film type protective spray or not... If there was any water
in there, I like the films property of being able to keep the water off the motor parts. Maybe I'll just do
a little hole and spray in the ACF-50 when it arrives.
Also, people have discussed on the best way to plug such a hole. I'm inclined to drill it, then use
a metal tap to thread it, then put in a machine bolt with some silicone RTV on the threads. On the other
hand, if water did not get in where the wires come out, I doubt it will get in the little hole (like you
said Affliction). Still I'll probably tap the hole an put in a bolt. ADD sucks eh?
zukster
Postby Affliction » Sat Nov 28, 2009 2:14 am
I'm using Chrystalite 408's, yup DUAL 408's :mrgreen: Gotta be the worst motor in the world as far as weather proofing goes but I managed to do it.
The stator poles are iron thus the rust. The housings are aluminum. I replaced all the hall sensors on both motors last winter a month apart.
The motors were brand new in the previous spring. Soon as salt season hit everything frocked up. I had warranty so I didn't modify anything yet because I wanted to know the weaknesses of the systems. The way I ride, I'd kill your bafang in short order :shock:
I don't like geared hub motors for 1 simple fact, too much extra shit to go wrong. Good thing Justin didn't go with the E-Zee hub for a cross canada trip :oops: My friend Juergen at ridemore.ca has a flood of siezed hub motors every spring to repair.
Ohh and I now have my brothers Bionx here with a frocked hall sensor to repair as well and he rides in the winter too.
Notice a pattern? Aluminum oxide is the start zuckster, it will go to shit quickly if you don't adress it.
Retailers don't want to prevent breakdowns; why would they? They sell more bikes and kits this way.
Affliction
Postby Affliction » Sat Nov 28, 2009 2:23 am
On the other
Do as you wish......... :wink:
You'll just have to make a vastly larger hole to be able to tap a pipe plug into it.
The hole the size of a can straw is how big?............ :P
I like the ADD crack... got a joke for ya....
What is black and blue and doesn't like sex? A: zuckster in my basement :twisted: :mrgreen:
Affliction
Postby zukster » Sat Nov 28, 2009 3:13 am
Affliction wrote:What is black and blue and doesn't like sex? A: zuckster in my basement :twisted: :mrgreen:
You are truly evil Assfliction :mrgreen: :mrgreen: :mrgreen:
You can get taps the size of a little straw. I'm going to go a bit larger (about 1/8) just so the bolt will
be a bit larger and less likely to break. The freewheel is on one side but I don't have disk brakes, so that's
the side where it will will go.
zukster
Postby grindz145 » Sat Nov 28, 2009 10:23 pm
A grease fitting would be sweet too, just pump it up with some new stuff once and a while and clean up the overflow...
grindz145
Postby Affliction » Sat Nov 28, 2009 10:55 pm
grindz145 wrote:A grease fitting would be sweet too, just pump it up with some new stuff once and a while and clean up the overflow...
Ya , Ya do that allready; not really ideal for a hub motor tho. I grease my forks and crank and swingarm pivot with grease fittings.
Affliction
Postby johnrobholmes » Tue Dec 08, 2009 9:34 pm
How about Corrosion X? It is a great product for motors.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby Affliction » Tue Dec 08, 2009 10:05 pm
johnrobholmes wrote:How about Corrosion X? It is a great product for motors.
Is that like Boeshield?
I'm sticking my guns to this! :twisted:
Wurth Film is a nieche product not sold to the general public. You have to be a business to purchase it.
Wierd material saftey laws and all.......
All this other corrosion shit dries out ;ACF50, Boeshield and the like and they don't lubricate or continue to penetrate the metal.
Is corrosion X good chain lube?
Affliction
Postby johnrobholmes » Tue Dec 08, 2009 10:27 pm
Yep, look it up. You can soak a motor in it, then run the motor underwater for quite a while before needing to reapply.
Volt up, gear down!
johnrobholmes
Postby gestalt » Tue Dec 08, 2009 10:54 pm
Back to the conformal coating idea that was espoused earlier, upon taking apart my GM hpm5000b I noticed that all the wiring and coils are conformal coated. The motor is advertised as water proof and I think it would be more acurate to say that it's water resistant. I could see moisture could getting in through the outer bearings and the joint between the outer casing and the rear housing. For the joint I was thinking of using some sturdy silicone sealing glue. That corrosion X sounds like a great extra measure of protection though for the inside, it's officially on my grocery list.
- be seeing you
gestalt
Postby Affliction » Tue Dec 08, 2009 11:42 pm
Use CorrosionX to eliminate corrosion and protect all metal surfaces of your boat, trailer and dockside equipment. Especially recommended for brightwork (keeps stainless from pimpling), hatches, powerheads, antenna bases, hinges and latches.
CorrosionX is also the best lubricant you can use for maritime applications. It does not attract dust, outperforms lubricants fortified with Teflon* (PTFE), and due to it's unique polar bonding technology, CorrosionX repels water, and doesn't dissipate quickly or wash off in harsh saltwater environments. Use CorrosionX on throttle cables, steering mechanisms, seat swivels, locks, travelers, winches, pulleys, furling systems, tracks and on any other gear that would benefit from lubrication.
Due to its extraordinary dielectric properties, CorrosionX should be applied to all battery terminals, terminal strips, ignition switches, electrical connectors, circuit breakers, fuse holders, light switches, light sockets, electrical plugs, blower motors and fans to protect them from corrosion, extend their life and keep them working reliably. Although CorrosionX is inherently nonflammable, the environmentally-friendly propellant used in our aerosol cans is flammable. Please use caution when applying to electrical equipment. Before applying, make sure there is no current running though the system and that electrical motors are disconnected before applying.
I was convinced before I read this...
.... This is the same crap as ACF50!
If it doesn't remain fluid and tacky then it stops increasing the protection after application.
Affliction
Postby lifepo4ever » Wed Dec 09, 2009 1:05 am
the drill hole with some spray seem to be the best choice , but my new motor is 2807 9c and they already have a seal but is it enought
to protect the interior of the motor or should I protect it with spray can?
lifepo4ever
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: chrashing and 9 guests
