lifepo4ever wrote:hey guy I found this product for 11$ from my canadian tire store
http://www.corrosionfree.com/automotive.htm I will test it for you this week because i ride my new ebike on snow I will also drill a hole to my side cover and give him a good shoot
the product resist to 260 Degree no leaking no solvent ,its a gel like and also Di-electric to 40,000 volts
they said to soak the metal in so the stuff stay on the surface for 18 month , its to good to be true you can even use like a lubricant
so stay tuned i will reply in 1 week or two
here are the spec: * Formula 3000 with CSC 850
* Rust & Corrosion Fighting Lubricant DripFREE Lubricant Gel
* Especially formulated for coastal and salt water environments
USES
Electrical
Electric motors, starters, generators, alternators, switches, terminals, rheostats, circuit panels, ignition systems, light sockets and any electrical point of contact.
Mechanical
Pre-assembled metal parts, winches, pulleys, bearings, shafts, bushings, hinges, cables, aluminum wheels, steel rims steel or aluminum castings and anything that moves.
Appearance / Detailing
Doors, trunk lids, engine hoods, lapped seams and joints, nuts, bolts, chrome and aluminum accessories, and basically anything requiring protection from the elements.
BENEFITS
* Terminates rust and corrosion in all metals
* Clean, clear, DRIPFREE - no sticky residue
* Dissolves and neutralizes existing rust and corrosion
* Penetrates the start of new corrosion
* Protects paint from blistering at edge of lapped seams
* Stops electrolysis between dissimilar metals
* Protects UnderBody including brake and fuel lines
* Penetrates deeply and lubricates
* Repels salt water and moisture
* Will not wash off with water
* Heavy Duty gel formula for extended protection
METHOD OF APPLICATION
* Formulated to be applied under high pressure to hidden areas using the CorFREE applicating system, or brushed / wiped on to exposed panels
* Can be applied to wet areas
* Apply every 18 months or annually as required
SPECIFICATIONS
* A proprietary blend of lubricants, moisture displacers, corrosion neutralizers and inhibitors
* Solvent-free - Odor-free - Non Toxic - Non Conductive - Di-electric 40,000 volts
* Non Flammable as a liquid - Low Fire Hazard - High Flashpoint
* Not a controlled substance - not subject to TCSA - not controlled by WHMIS
* Specific Gravity .86 - Boiling Point 260 C - Negligible solubility in water
* Non Carcinogenic - Light Green Color
