gogo wrote:I'd like to see a test of a shear pin or cotter pin through the axle and nut using the nut and pin to transfer the torque to an arm.
AussieJester wrote:I cut up 8 (curbside bikes) bikes today so have 8 sets of forks laying here destined for the bin, pitty your in North America freight would be a killer...
KiM
dogman wrote:Here is a pic of the forks from bikes I'll never reassemble. Turns out only four, I put together some of the junk bikes and sold em the first week of school at the university.
From left to right, cheap bmx forks, Cheap roadmaster mtb forks, Steel suspension mongoose wallbike mtb forks, and some vintage but quality cromoly QR hub forks from an mtb.
BLUESTREAK wrote:The best is a good tight fit of the torque plate hole to fit the axle all the way around and good flat friction surface like DOGMAN has been trying to pound in to everyone from the start will save most from having a spinout. If the torque plates fit solid on the axle and is squeezed tight on both sides of the dropouts that thing will stay put. In the test done by JUSTIN the axle has space on the top and bottom of the torque arm and there is room for the material to go into that space, if all the material has no place to go the axle can't spin. Good work JUSTIN.
BLUESTREAK wrote:The idea of drilling a hole through the nut and axle and putting a keeper pin through is ok for keeping the nut from comming loose and releasing friction on the washers and torque arm and dropouts is good but the nut with the pin through can not take much torque as it will shear the pin.
BLUESTREAK wrote:Yes shear pins made of certain hardness can be like a fuse. but in this case the problem is not the torque on the nuts that hold it's the torque on tha axle. in something much larger in size the shear pin can hold a lot of torque.and JUSTIN may be right this needs more testing.
justin_le wrote:BLUESTREAK wrote:The best is a good tight fit of the torque plate hole to fit the axle all the way around and good flat friction surface like DOGMAN has been trying to pound in to everyone from the start will save most from having a spinout. If the torque plates fit solid on the axle and is squeezed tight on both sides of the dropouts that thing will stay put. In the test done by JUSTIN the axle has space on the top and bottom of the torque arm and there is room for the material to go into that space, if all the material has no place to go the axle can't spin. Good work JUSTIN.
Hi Bluestreak, this seems "intuitively" correct to a lot of people and so that's probably the main reason why it hasn't been challenged. But once you actually spin an axle through a dropout plate and watch the metal smear out of the way, you realize that it doesn't make much of a difference if the original slot was a dead perfectly tight fit or a little sloppy. Once you hit the yield point of the metal, it just starts to move no matter if it started snug. The failure is quite localized at the contact point, the rest of the torque plate often doesn't suffer any deformation at all.
-Justin
mwkeefer wrote:No offense.... but Canada...
Maybe someone in the states should duplicate the experiment to reduce overall cost (S&H)?
justin_le wrote:Surely somebody converted a suspension bike and given the advice from this list, replaced the original suspension forks with solid steel ones, and now has this extra pair of forks and a nagging question in their head about whether they would have been strong enough? Now you can find out!
johnb wrote:justin_le wrote:BLUESTREAK wrote:The best is a good tight fit of the torque plate hole to fit the axle all the way around
Not just intuitive I think. A loose fitting spanner will quickly round off a nut with only a little torque. With a tight fitting spanner you can apply much more torque to the same nut. Why is it not the same with torque plates and axle flats?
justin_le wrote:What I am saying is that if you look at the diagram below, I wouldn't expect there to be any notable difference in the spinout torque between case A and case B,
philf wrote: Spinout is one, but the other thing that doesn't sit well is the notion of pulling the bike along through the shocks. Other than during braking, they're mostly used to going up and down.
Users browsing this forum: Bing [Bot], flexy, Moya, zypher and 15 guests
