Around a 13 mile round trip, WOT on Low just about the whole way, fully charged before I left. I forgot the wattmeter, though, left it on the charger at home.
I noted as I pulled the battery (slightly warm) out to charge it that the controller itself was fairly toasty inside the cargo pod with my backpack and stuff against it; I think I need to secure it's casing better against the cargo pod's aluminum front wall--right now just the tabs on the ends make contact, the rest of it is about a half a millimeter away, which I had not noticed before. I'll file out the screwholes on the endplate brackets of the controller a bit to allow me to slide them upward far enough so that bolting them tightly against the sidewall will force the surface of the controller against the sidewall too, and also add a bit of thermal paste on the controller fins to help contact/heat transfer.
The Fusin motor was only warm on the outside case, but I expect it is toasty inside. I should put a thermal sensor in there for summer use.
The trailer did quite well, especially since I deliberately picked some crappy roads to ride on to test it for behavior and pothole resistance, etc. One problem found is that even though the casters were held off the ground by about 1/2" for the ride itself (by tightening the stem hitch pivot so the trailer's front is lifted above ground level when the bike is upright), they often touched ground anyway, because of flex of the front edge of the trailer even when empty.
This is a serious issue, because it is causing such flex of the whole front end that by the time I reached home, it cracked the aluminum at the corners of the front end, just in front of the caster mountings. There is zero problem with the back end, which has more weight on it, so it is not likely caused by the wheel vibration, but rather back and forth flex of the hitch. I'll have to put a T-frame there that bolts the top bar of the T across the front end inside the aluminum "box", just behind the hitch, with the hitch bolted to that, and the vertical of the T horizontally behind that toward the back, bolted in a couple of places along it's length to the top panel. That should stop the major flex.
Then I need to fix the corners, and reinforce them so I can safely put weight on those casters again (which only needs to happen when it's stopped/parked, usually). I'll probably just weld up some corner-plates to fit inside the corners and bolt to top, front, and side with the caster mounting bolts being the side bolts.
