tahoe96150
- Joined
- Feb 10, 2010
- Messages
- 1
I noticed that my Currie Ezip bike would periodically cut out when it was going over bumps. I called Currie and they told me to check the connectors at the bottom where the bike conncected to the RMB to see if the buttons would push in. They didn't. I got home that night and took it apart and found that the plastic surrounding copper buttons that touch the bottom of the RMB had melted. Yes melted. it melted in such a way that rather than being vertical the buttons were angled off a number of degrees so that they would not move up and down.
I called Currie about this and they told me that I could get replacement parts for this for about $50 (I have 2 bikes) with the same exact problem.
I was a bit twisted because this seems to be a defect in the design because it makes no sense that the plastic would melt as the unit was being used in the manner in which it was intended. that was bad enough but it happened on two bikes. I asked about the replacement parts and were told that they were the same. I asked about the history of this issue with others and the answer I got suggested that this had been a problem. He told me that when people replacement parts there wasn't a problem in the future but at the using the same material that makes no sense. Anybody had this problem? if so, let me know. Anybody replaced the buttons with some other kind connector?
Matt 916-730-5601 or matt@bradylawus.com.
