oddjones
Another weeks solid work on this bike and I'm still baffled
So, I've wired my 2 36v batteries up in serial and connected everything up to the controller -
I have a couple of obvious problems ...
Firstly the batteries - I've charged them both fully and one is giving out 40V, the other is giving out 22.8V, when I connect them in serial I get 57.6V through the new PING BMSes
The batteries have been sat in my garage for over a year now in a mixed state of charge/discharge - my newer battery didn't show as charging when I connected it to the charger (the LED stayed green) - my older battery (the one which is now giving out 22.8V) took charge overnight.
Secondly the Cycle Analyst - the first time I connected it showed "The cycle analyst version 2.0" on the display for less than a second then the screen went blank - the backlight remains on but that's all I have - if I turn it on now I just get the backlight
I've wired up the various components as follows :
3 speed switch (as supplied by Geoff57) : orange-orange, brown-brown, yellow-yellow
e-brake: not connected (open) as I presume the only way to know which is the right way to wire it is to try it! - I have got the reed switch mounted and operating, I've just not connected it.
speed sensor - not connected (open)
throttle plugs connected as designed by Geoff57
I wired phase and hall as per recommended settings for infineon-bafang (I've got a 5A fuse inline with the battery) and got nothing at all.
I then went through the whole spreadsheet of possible hall/phase settings and got nothing at all - I had my meter inline with the negative feed from the battery and got an unswerving 0.01A through all the testing positions.
So I'm stuck again! is my 57.6V tripping the LVC on the controller? If so how do I get my batteries back to fitness?
Is the lack of an e-brake connection stopping the controller from working?
