Doctorbass
Like i already discussed few times on the E-S, A dyno project would be something i want to do!!
that will allow me to do many IN LAB performances tests.
I announce you that the project has began!!
It have 2 rolls of 8 inch diameter made of pure steel and they are linked using a timing belt and 2 pulley. all will be hold with a strong steel base and good quality bearing.
It also have a coupler to put a generator on it for higher power tests.
It will be inertia dyno type for low power and generator type for higher power. I might also add an auxiliary large flywheel to it.
It's tonybike that is building it for me following my recommendations.
The goal is to have it portable.. ( 150pounds or less :lol: ) and to also allo scooter dyno test.
The mecanic is easy to do but i still dont found any afordable electronic interface and program to match with...
Here is some pics:
Here is some pics:
