I have a Crystalyte 35A analog 36-72V controller that I would like to add the direct-plugin Cycleanalyst connector to. eBikesSF sells the controllers with this connector already installed, but my controller doesn't have it. I was hoping someone could post a photo or description of where to solder the CA connections on the controller PCB.
B.t.w. eBikesSF has a good info page on the controller but it is lacking this info.
http://ebikessf.com/technical/crystalyte-35a-controller-connectors
A related question: 6pin Molex or 5 pin inline connectors are common for the halls, but don't fit through the rear axle nut. I was curious if the 5 pin mini-XLR is small enough to fit through? I don;t have one to test myself. (I find it annoying to have to cut the hall connector to e.g. add an axle mounted trailer hitch, or try experiment with new torque arms.)
Background: The other 30A 6FET Clyte controller I had on my bike died in a downpour a few days ago. Blew battery fuses and shorted phase wires on motor so bike was next to impossible to roll, let alone bike... So I have to get this 12 FET 35A controller into service, and was hoping to add the CA connector so I can keep using my CA.
