Smoker wrote:Is it possible to charge let's say a 12V battery or use a 12v capacitor and directly connect an invertor for 120vac?
Smoker wrote:Electric lawn mower sounds cool. I have some 1/2hp 120vac motors lying around. Would these be good canidates for an electric push lawnmower? How did you get the blade on the output shaft?
Thanks
billvon wrote:>How about a brushed ebike hub motor? could I connect directly to a 12v battery and charge it?
Yes.
>how would I keep it from spinning with 12v hooked up?
You wouldn't. If it spins slower than base speed it takes power. If it spins faster than base speed it becomes a generator. Arrange gearing so you can spin it faster than base speed.
How about using a diode so the battery can be recharged by the motor, but not spin the motor?
Users browsing this forum: Obiwan007 and 10 guests
