What voltage should a 24v controller shut off at?
Postby Geebee » Wed Oct 17, 2007 5:56 am
My Tonxing controller shuts off power at a bit above 23.5v and it is annoying the cr.p out of me because it means I can only pull 3~4 ah out of the 18 ah pack as after that pulling 13.6 amps on long hills sags the voltage too low.
Geebee
Postby Ypedal » Wed Oct 17, 2007 6:22 am
20 v should be the right setting. but 24's gonna be a problem.. can you add an extra 6v booster pack to keep things going ?
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby Freddyflatfoot » Wed Oct 17, 2007 8:25 am
GeeBee,
My 24 volt controller shuts off at 21.5 volts.
Cutoff should be at, or higher than the lowest per cell voltage, but 23.5 seems way too high! (i.e. 1.75v per cell for SLA's = 21.0 volts)
My pack often sags to mid 22's, and does go lower as the capacity gets lower.
Rob
Rob
Current setup, 250 watt/24 volt chain drive setup on Jamis MTB, 24 volt, 10 AHr Yesa LiFePO4 pack. 15A controller. (increased to 20A, currently dismantled) (motor sold)
Home built recumbent trike, 350 watt, brushless, geared, hub motor, 36v/10AHr 'Duct Tape' LiFePo4
Freddyflatfoot
Postby dirty_d » Wed Oct 17, 2007 10:53 am
my 48V controller shuts off at 31V i think, that ridiculous, by the time my batteries are 47V i can barely move.
dirty_d
Postby Ypedal » Wed Oct 17, 2007 11:08 am
NIcad/NImh = 1v per cell
SLA = 10-11v per cell under load
so
24v pack = 20v cutoff
36v pack = 30v cutoff
48v pack = 40v cutoff
:wink:
Edit to add :
Many " 48v controllers " are simply 36v units run at higher voltage, so the LVC ( low voltage cutoff ) will still be set for a 36v pack.
You really want to avoid draining ANY battery pack to the cutoff point tho. no matter what chemistry, it's always best to keep a certain percent buffer.
Ypedal
Return to E-Bike Technical
Who is online
Users browsing this forum: guting and 10 guests
