Using EagleTree's MicroPower eLogger as a bike computer...
Postby GGoodrum » Mon Nov 19, 2007 12:32 pm
deecanio wrote:Hi Guys,
Gary, can't wait to see the townie in action - are you swapping the kit straight over from your folder? that would be an awesome setup!!!!
cheers
D
No, it is a separate setup. The folder has a 5303 "Racer", and the Townie's is a 5304 "Cruiser". Each now has a 4840 controller that Bob Mcree modified by replacing the stock FETs with 100V 4110s, and for both, he "adjusted" the current limiter upwards, so that both will allow over 85A. The folder has two 10s4p a123 packs in series, each with embedded LVC boards conncted to the controller's brake inhibit lines. The Townie has bag on the rack in back with four big sub-packs, two that are 6s6p and two setup as 4s6p. Each 6s6p and 4s6p pair are connected in series, and have a 10-cell LVC board connected. Each of these 6s6p/4s6p combos are then connected in series so the total setup is 20s6p, or 66V/13.8Ah.
Yesterday I went on a ride that totaled about 15 miles. For the first 10 miles, or so, I was taking it pretty easy, as my 24-yearold niece was riding with me (on my "other" folder, the one in my current avatar...). I used 5.34 Ah in 10.12 miles, which is 528 mAh/mile. It used 336 Wh, which is a respectable (well, for me anyway... :)) 33.2 Wh/mile. Later, I did a speed run home. I don't know how many Ah/Wh I used on that yet, but I hit 48 MPH, and I was blasting up and down every hill. :D I didn't get the new MicroLogger on Saturday, so I didn't video this ride. If it comes today, I will do another video.
I think the limit on the second controller is a bit less than it is on the 20" folding bike. Instead of 5500W peaks, I was seeing around 4800-5000W, which is still gobs more than I'll need. The Townie, having better tires and more weight, didn't "burn rubber", like the folder, but I think the acceleration is actually a bit better.
-- Gary
GGoodrum
Postby mace1934 » Sun Dec 09, 2007 6:01 pm
Gary,
Are there any new micro logger developments?
Larry
mace1934
Postby GGoodrum » Sun Dec 09, 2007 8:39 pm
mace1934 wrote:Gary,
Larry
Yes, actually...
After blowing up several units, connecting them to my 20s6p a123 setup, due to the arc/surge blowing the regulator chip that powers the unit, we decided to step back, and take another look. They couldn't really go to a bigger regulator, without a board re-design, and there was no room to add any big caps.
What we are looking at now is to use the same case and display that is used for the Seagull downlink system, and put a new board in there. There will be a small remote sensor that can go back with the pack/controller that connects to the main unit with a small serial cable. there will also be a a small 4-wire cable that will go down to the motor that has a plug adapter that will go in between the DIN plugs for the hall sensors. This will provide an input to the unit for figuring out motor rpm/bike speed, and will also be used to supply power for the unit (it doesn't need much...).
The Seagull box is not much bigger than a WattsUp unit, and it will come with a way to mount it to the handlebars.
I should get the prototype in a few weeks, just after the first of the year. In the meantime, I'm going to continue my testing with aV3 unit, but only connected to half the pack. You can scale the voltage input in the software, as a setup function. Anyway, I should have a new replacement tomorrow, or Tuesday. I just recently upgraded my setup to run a 24s6p a123 configuration, so I'm hoping to do a new video this week, with the overlays. Also, they have fixed the car user inteface on the PC application, so the replays will have an analog speddometer instead of just a digital readout.
-- Gary
GGoodrum
Postby mace1934 » Mon Dec 10, 2007 8:45 pm
Thanks. Looks like a real winner in the making!
I've been noticing a problem lately: different (intact) DeWalt packs discharging at significantly different rates - up to 2 fold. I use 2S3P PACKS, with 2 eloggers on 2 of them and a Whattmeter (WM) on a third (it would be nice to have 6 eloggers).
Here are data from two recent charges, using an elogger or WM on each (numbers are Ah to charge, same pack order):
1.33, 1.53, 0.79, 0.88, 1.29, 1.60
1.32, 1.14, 1.12, 0.72, 1.23, 1.36
A graph follows, showing packs 7 and 9 (third and fifth in the above line-up) being charged in succession by 2 series-connected 60 W photovoltaic panels.
Thinking that the DeWalt BMS' might be part of the problem, I'm going to remove the cell clusters and make up packs without BMS, but, following your procedure, I'll keep the cell taps assemblies. I plan to make just one cell tap harness, to use on each pack during cell voltage measurements and balancing.
Thanks again for sharing.
Larry
Charging 2 DeWalt battery packs in succession by 2 series-connected 60W photovoltaic panels. Volts, cumulative mAh, amps.
mace1934
Postby GGoodrum » Tue Dec 11, 2007 11:03 am
mace1934 wrote:Thanks. Looks like a real winner in the making!
Larry
I think either you have a couple of flaky BMS units, or maybe a loose connection in the wiring harness? How are they connected, three packs connected in parallel first, and then in series, or do you simply have three two pack series strings with their outputs then paralleled together?
-- Gary
GGoodrum
Postby mace1934 » Tue Dec 11, 2007 1:27 pm
I can't locate any bad connections, but the recognition of this problem has spurred me to take the time to do it right, and get the cells out from under the limitations of the DeWalt BMSs, whether they are at fault or not.
Larry
mace1934
Postby mace1934 » Tue Dec 11, 2007 1:33 pm
During rides, the packs are series-connected in pairs, the pairs connected in parallel. L.
mace1934
Re: Using EagleTree's MicroPower eLogger as a bike computer.
Postby jumpjack » Wed May 30, 2012 2:12 am
Would it be safe to use EagleTree V4 on an ebike with 60V/1500W brushless motor?
http://www.eagletreesystems.com/micropower/micro.htm
jumpjack
1 W
1 W
Previous
Return to E-Bike Technical
Who is online
Users browsing this forum: EdwardNY, slayer, zerogee and 10 guests
