chris22104
- Joined
- Jan 26, 2010
- Messages
- 38
OK, I have two brake levers with the cruise cancel feature /connectors. My Lyen controller has only one matching connector. To eliminate some of the wiring going from the front to the back, I want to tie the one into the other up front, and have just the one cable/connector coming back to the speed controller. But I want both levers to be able to cancel the cruise. I should wire them in series so when touched, either lever would break the signal, correct? (NOT wired in parallel, right?) Circuit-wise, basically, one big loop. Please confirm!
Thanks guys!
Chris
Thanks guys!
Chris
