:oops: Fixed EB 218 Over volted now no 5volt
Re: Xlyte blown components but still working...now it is not
Postby Jeremy Harris » Thu May 17, 2012 11:14 am
They are the low voltage cut off sense resistors, so if they are disconnected the controller thinks that the battery is disconnected/flat and it then shuts down. The big power resistor is in parallel with the other two, so losing one still allows the controller to power up, although maybe with some problems if the voltage drop across the remaining two resistors is too big, such that the 12 V regulator drops out.
I doubt the SMD resistors overheated because of the current they are carrying, they probably got cooked by the hot power supply dropper resistor on top of them. If you're running at a high voltage those dropper resistors can get pretty hot.
Jeremy Harris
Postby NeilP » Thu May 17, 2012 12:50 pm
Umm interesting, but can't be correct, that is if you mean the SMD resistors are Low voltage cut off resistors, because the controller was working fine exactly as you see it pictured there with RS13 lifted off the board.
The three of them are in series making up a 3k string, the LHS of the string common to the LHS of the power resistors, RHS off to...I think a SMD diode.
It would make sense what you say about the heating of the power resistors, the RHS in the pic, under the board where the power resistors are connected, the solder bead did look like it had melted and flowed.
This is the second time that RS13 SMD has popped off the board.
The previous time, i only noticed it at the last minute as it was on my bench.
previously the controller had stopped working it was the 5 volt reg side not starting up. If i fed in 5v externally from another battery (3xAA NiMh) with ground common, the controller would work. remove the external 5v feed and it would continue to work, continue to produce 5v. it just needed a 5v kick from outside to get it started. Not sure what I did to fix it, I removed the transistor int eh area, along with a small FET or voltage reg, can't remember now. Tested them with meter and they were all fine so re installed them, and controller worked. guess it must just have been solder melting again.
I thought it was caused by a flash from forgetting to use a pre charge resistor, but maybe you are right, maybe those power resistors are getting that hot...but would have expeced them to be a bit more blackened r charrred if they were.
Anyway, I repaired it and it worked. Was about to re instal into the case, when I noticed the SMD RS13 on the bench. So the controller works fine with that line totally disconnected.
I have been running it at nearly 100volts, without a power resistor mod which I think may have been necessary from reading I have done since, so maybe this time I have finally cooked it.
Wonder if it is the MCU this time
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
Re: EB32218 Over volted now no 5volt
Postby NeilP » Fri May 18, 2012 2:36 am
I had forgotten about this thread, so started a new one>>bugger.
180mm disks
100V 20Ah LiPo
NeilP
Postby amberwolf » Fri May 18, 2012 3:18 am
NeilP wrote:I had forgotten about this thread, so started a new one>>bugger.
I can merge the new one into this one if you like.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby NeilP » Fri May 18, 2012 3:31 am
Yes, good idea, thanks, go for it
Cheers
180mm disks
100V 20Ah LiPo
NeilP
Postby Jeremy Harris » Fri May 18, 2012 3:50 am
I've just checked an older 18 FET board I have here in front of me, and it is correct. The resistors marked RS11, RS12 and RS13 are in series and are the upper part of a potential divider that feeds the LVC circuit. My guess is that when the resistor came off there was a solder splash or something underneath it that maintained continuity. This may have pushed the sense voltage at the ucontroller over the edge, too, ultimately causing damage such that the LVC isn't now working (although that's just a speculation).
Have you got the right value of power resistors for the voltage you're running at? They need to be changed for different battery pack voltages, which is one of the nuisance "features" of these Xiechang boards. Having the wrong value or power rating resistors there could cause the overheating problem. My 48 V (60 V max) 18 FET board has three 1k5 power resistors in parallel, giving 500R in total.
Jeremy Harris
Postby NeilP » Fri May 18, 2012 4:24 am
Morning Jeremy
Yes, the Solder splash is the only likely expalantion if it happened once , but to have it happen twice, and get a solder splash to create a short across the pads where the SMD was...umm..unless a splash some where else and it is still there.
But that can't be right either. I have measured each of the SMD's and they are correct, and the series resistance of them is correct too, if there was sshort somewhere, those figures woudl not be correct.
As for the correct power resistors.... :oops: no, I never changed them for 100volts, but I have only used it for short distances at 100 volts and it has always worked so far.
AM down in workshop now, and fired it up with 75 volts.
Good 5 volt at throttle output,
Cruies control warning light comes on when power is applied to the board, and Cruise locks on when the throttle is opend and Cruise is activated.
Cruise knocks out too, when the e-brake line is shorted to earth. so all that side is working. Just motor does not turn
So this points to something else gone..but what woudl that be where do I look next?
180mm disks
100V 20Ah LiPo
NeilP
Postby NeilP » Fri May 18, 2012 5:16 am
Well found something
Thought this transistor was part of the 12v reg circuit, and it seemed to be working.
Could be my fault here,a case of poor soldering the first time I worked on it.
It was loose with little solder on it. But it has been like this for ages and was working.
Removed it now to resolder but a piece of track has lifted. May have to fit it elsewhere and run jumpers to it. but at the moment can not trace the tracks accurately
Yes legs are supposed to be twisted
A1013 Y-J40
Can't find exact data sheet for it to determine pin out.
http://www.alldatasheet.com/datasheet-p ... 1013Y.html in different package?
Does that piece of lifted track go on to the RH SMD resistor just behind the lifted track?
The middle pin? does it go to the Left hand pad of the Rhresistor just behind? cant see a trace from it on other side of the board
180mm disks
100V 20Ah LiPo
NeilP
Postby NeilP » Fri May 18, 2012 11:59 am
Really sorry to do this guys..totally wrong..but I am getting so frustrated with this .
BUMP
I have a spare, do not need it but it is just bugging me that I cant fix it by myself
180mm disks
100V 20Ah LiPo
NeilP
Postby docnjoj » Fri May 18, 2012 3:09 pm
Hey Neil! Does this help?
viewtopic.php?f=2&t=10312&start=0
otherdoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby NeilP » Fri May 18, 2012 9:48 pm
Nice one, thanks
If this works, I may try the copper heat sink wire trick round the power resistor legs too
Alternatively there is a mod to add an LM317 to give wide ranging input voltage
180mm disks
100V 20Ah LiPo
NeilP
Postby amberwolf » Fri May 18, 2012 10:10 pm
NeilP wrote:Yes, good idea, thanks, go for it
Cheers
Done. :)
amberwolf
Postby NeilP » Sat May 19, 2012 5:46 am
You have done the mod on this board?
umm. I have only seen details for different boards. Did you happen to work the modified addition yourself?
The mod I have seen in the Infienon Google doc from John Jenkins and Knuckles does not seem to tie in with what I can see on this board
Neil
180mm disks
100V 20Ah LiPo
NeilP
Postby NeilP » Sat May 19, 2012 11:59 am
Umm now this is odd.
Looks like I may have put the PNP transistor QS2 A1013 / MPSA93 in the wrong way around last time I repaired it. Yet it worked just fine ??
I think this after looking at Auraslips pictures, my original pic and the later one, along with the data sheets for all the A1013/MPSA93
My original pics, before I mucked with it, where you can see insulated leg, going to LH hole on board
Now after I screwed with it
After I screwed it A1013.jpg (86.68 KiB) Viewed 375 times
I seem to have put it back in as
BEC
MY F UP.jpg (8.67 KiB) Viewed 375 times
when working from auraslips pic and the data sheet
it should be like this
CBE
I am just going to have to try and sort this mess out tomorrow tracing the board with the help of the schematic and pics from auraslip and pictures of the unpoplulated board from Ed Lyen. Cheers Guys great help. But you know what that means I maybe back for more help.
180mm disks
100V 20Ah LiPo
NeilP
Postby NeilP » Sun May 20, 2012 6:59 am
Well stuck the transistor back in ...after more than three hrs ...due to a too large soldering iron tip, and an SMD resistor that just would not stay in place.
Eventually I gave in and went out in the torrential rainstorm we are having, a mile down the road to my workshop, to get a standard 1/4 resistor, and fitted it on the back of the board.
So got 5 v again now, and with that transistor fitted correctly the power resistors are not getting so hot, the only now have to drop a much lower voltage across them selves.
But still the board refuses to spin the wheel.
The only other thing I have done is to connect the regen brake jumper to a fly lead to enable/disable regen braking.
Maybe this board and MCU did not support regen and the act of shorting the BR pad to ground has fried something in the MCU, or else where.
:x
Edit. No thaty theory is wrong. I just tried it at 90 volt it works, where at 75 it will not. SO must be a LVC issue
It is not a programable board, I cant change LVC figure..so maybe the string of SMD resistors that Jeremy mentioned adjusts LVC is at fault..they have blown off twice now...
UMM
well at least it is working again...but with a much higer LVC than before..it used to cut out at about 56 volt..now
180mm disks
100V 20Ah LiPo
NeilP
:oops: Oh what a F wit I am :oops:
Postby NeilP » Sun May 20, 2012 10:01 am
:oops: :oops: :oops: Please if anyone is in the area..come and slap me big time..I have been a total muppet...... :oops:
Any one guess what I did...why did it not work with a lower battery voltage, even though Controller LVC is factory set a 56V and can not be changed via programming?
I had a Cycle Analyst connected didn't I ...yep you guessed it. CA LVC set to 82 volt :oops:
Only found this when I went in the setup to change the shunt value after soldering it
180mm disks
100V 20Ah LiPo
NeilP
Re: :oops: Fixed EB32218 Over volted now no 5volt
Postby whereswally606 » Sun May 20, 2012 10:55 am
thats pretty funny.
glad you got it working, since i think you probably have done more work than you would have liked on that board.
Buy a 400W 12Volt 32a server supply fitted to connect typical 4mm bullet plugs £25.30 to the UK, will ship WW. IM me for details
Ebikes: Scott Ransom & Magie Pie 48V limno2,Norco Team Race & Hub motor 12s4p lico zippy 40C
Norco Savage to receive an 80/100 motor with opticals Not halls Thanks Burtie.
Car: Honda Insight gen 1 hybrid
whereswally606
Postby NeilP » Sun May 20, 2012 11:00 am
Well more opportunity to screw it up again tomorrow. I stopped while I was ahead today :lol:
Still need to fit it back in the case yet.
Looks like regen braking does not work on this board at all. With BR to grnd or not, no difference, no braking effects on overrun or brake lever action. Power cuts on brake action, but no regen seen on CA, or braking of wheel either
180mm disks
100V 20Ah LiPo
NeilP
Postby NeilP » Tue May 22, 2012 9:29 am
Well it is working
but still not regen...well now quite, I saw regen once, at a lower battery voltage, added a parallel pot across R12 to bring the HVC up...to allow regen at higher voltage. But now nothing no regen at any voltage, even seem to have 'disabled' the LVC
Standard LVC was 56 volts..now I can run down to 30 volts no problem
What have I screwed this time?
180mm disks
100V 20Ah LiPo
NeilP
Previous
Return to E-Bike Technical
Who is online
Users browsing this forum: No registered users and 15 guests
