Anyone who can help me with this?
It gives error code: # ¤ ¤ ¤¤ ¤¤¤¤ ¤ ¤ ¤¤ ¤¤¤¤ ¤ ¤ # In
the manual it says that # ¤¤ ¤¤¤¤ # is throttle problem. I measured throttle between 5V+ and signal wire. It is 4 volts. If i twist the throttle, the voltage will fall. So is this a 3 wire pot, or a hall active throttle?
