to what? U have to build it yourself. TNC sells the 1020'sxyster wrote:Can you provide link(s)?
Toorbough ULL-Zeveigh wrote:I thought there were safety hazards to motorizing both wheels without some kind of closed loop feedback to monitor wheelslip or some such.
Matt Gruber wrote:safe
so why did u decide against dual 1020's?
Toorbough ULL-Zeveigh wrote:After having wiped out twice on the hard pack with churned up iceing sugar on top[...]
safe wrote:Toorbough ULL-Zeveigh wrote:I thought there were safety hazards to motorizing both wheels without some kind of closed loop feedback to monitor wheelslip or some such.
I was thinking of a "Twin" motor configuration so that the motors were physically connected before the chain going to the rear wheel. The advantage is that you can find motors that run at lower rpms and that makes gearing easier.
But the idea of "Twin" Hub motors is good too.
Any time you can get the "Efficiency Peak" and the "Power Peak" to be the same (which means a pretty low current limit on the controller) then that "spreads the joy" of improved efficiency across the entire powerband.
It's better to have two hub motors running at half the amps than one hub motor that is overamped. It's just overall BETTER.... (there is NEVER a case when overamping bets oversizing... oversizing always wins)
But the added weight might be annoying... however, if you got two small, light weight and high efficiency hub motors that might be really good... (it would even improve the weight issues that people have with these 5304's that weigh in at 25 lbs)
Users browsing this forum: Lory and 8 guests
