I want a fast e-bike. Who knows a good e-bike kit for me
what is the best e-bike kit??
d8veh wrote:Not enough information. They're nearly all good. It just depends what you want to do with them.
You need to say:How fast you want to go
How far you want to go
How hilly it is where you ride
Your weight
Your budget
Any legal constraints where you live
What sort of bike you want to fit it to.
Your electrical ability.
The faster you want to go, the more it's going to cost.
Your weight
Your budget
dogman wrote:There are kits for pretty fast. Pretty much all the 36v kits can be run on 48v, and get above 25mph, some even hit 30 mph.
There is no kit for FAST. At least not with battery anyway. 40 mph club and above generally means buying a fairly robust motor often a direct drive model, then doing your own fabrication to build a torque plate so the motor doesn't just fly off the bike at a touch of the throttle. The motor is run on a larger controller using 3000w or more, at 72v or more. Batteries are often lipo from HK, because nothing else has a better discharge rate.
But if all you want is the 30 mph club, The cellman kit with the fastest winding, and one of his 48v batteries gets you there nicely.
If you run two of those hk 6s batteries, that's only a 44v battery, not 48. So you'd be just a tad slower. Personally, I'd prefer the 8t motor myself, because it climbs a hill better. Since I have hills where I live, I'd rather have good hill climbing an 25 mph, than a motor that is slower on the hills.
As the others said, much depends on what you need. And once above 30 mph, you are illegal in most of the world. The flip side of that, is cops ignore you in much of the world anyway.
parmenps wrote:which batteries you would use for the mac 500 or 1000 w
parmenps wrote:how am I connect these batteries: http://www.hobbyking.com/hobbyking/stor ... duct=19716
on the mac 500w
what do I have to buy for it![]()
Thanks for your help
Users browsing this forum: acn49, Google [Bot], henni001, trietje and 8 guests
