ebikessf's 2k thermal sensor?
Re: ebikessf's 2k thermal sensor?
Postby amberwolf » Wed May 16, 2012 1:35 am
Easy way to tell if the bearing was damaged is to spin it with your finger thru it. If turning the outer race it feels grindy it's probably done. If you flick it, it really ought to spin freely by itself at least several rotations if it's a *good* bearing, but many cheap ones stop after you remove the drive source, even when they are new. :/
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby 999zip999 » Wed May 16, 2012 2:25 am
Open up my new - used H hub and it has a defect in side cover as a casting hole. Shitty metal. Plus one bearing is shot and both axle seals. Bearing ez but seals ?
Sorry for jumping thread.
999zip999
Postby GCinDC » Wed May 16, 2012 8:18 am
amberwolf wrote:Easy way to tell if the bearing was damaged is to spin it with your finger thru it. If turning the outer race it feels grindy it's probably done. If you flick it, it really ought to spin freely by itself at least several rotations if it's a *good* bearing, but many cheap ones stop after you remove the drive source, even when they are new. :/
yeah, we're getting OT here, but outer race definitely not grindy. looks like a quality bearing to me. i didn't do the flick test, but i doubt it spins like that. feels very smooth, which i figure means well lubed. how can it spin if it's thoroughly lubed? w/o a bigger wheel around it, that is... stamped JAPAN, not china, for what that's worth..
i'm very happy with the quality of the motor so far. definitely some improvements over last years batch, from what i can tell. the wiring hole is better. and there's a green urethane covering of some sort protecting windings from stator/lamination edge. i don't recall that w/ last one.
Joe Perez wrote:the whole chicken / duck / goose concept virtually became a meme within the forum community. And at the suggestion of a user at MiataTurbo.net, I decided to adopt a poultry theme for my avatars, as both an inside joke and a persistent jab.
hilarious. i love it. thanks for the story! your giant chicken looks like he means business. not to be toyed with! :lol:
anyway, i decided to replace my thermistor with an LM35, jumping the hall + inside the motor. more details to come on my build thread.
and this is how i will probably wire it on the outside, fwiw:
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby GCinDC » Thu May 17, 2012 1:00 am
fyi
GCinDC
1 GW
1 GW
Postby auraslip » Fri May 25, 2012 1:10 am
I have a question about the HK sensor. After reinstalling the motor the temp sensor shows 164c. It's like it's shorted, but it shows no shorts with a DMM. Could the LM35 be shorted when it powers up?
The white sensor wire (not the ground or V+) was broken at the connector so it's possible it could of shorted out on something.
auraslip
1.21 GW
1.21 GW
Postby Joe Perez » Fri May 25, 2012 1:46 am
I'm not entirely clear on what you're using for a temp display, however I encountered a similar problem when first connecting an LM35 to the beta version of the new CycleAnalyst 3.
In the CA, there is some voltage bleeding from the throttle input line into the temp sense line due to the way they designed the A/D multiplexer. It was originally designed for use with a NTC thermocouple (which is inherently a current sink) so they never noticed this, but the LM35 can't sink current to ground, so it became a problem. I was seeing indicated temps of around 100 degrees any time I applied throttle.
The solution was relatively simple. I placed a 390 ohm resistor between the LM35's output and ground, which was sufficient to sink the relatively small amount of leakage current and yet not so low as to exceed the LM35's current-source capability. The value does not have to be exactly 390 ohms, but it needs to be close. The LM35 can only source 10ma, so you can't go much lower than 300 ohms without distorting the reading, and yet significantly higher values (eg 1k) weren't enough to drain the leakage current. 390 simply happens to be a common value that I had lying around in my big pile-o-resistors (anything in the 330-470 ohm neighborhood would probably suffice- try to stick to the lower end of that range.)
Give this a shot and see if it fixes the problem.
The concept of "average" requires that 50% of the population be below it.
Joe Perez
Postby auraslip » Fri May 25, 2012 1:49 am
I'm sure that explanation will be extremely helpful to someone using the new CA.
I'm using the hkvt though - http://www.hobbyking.com/hobbyking/stor ... oduct=9744
I've tried another unit, so it's not the unit that's bad. It's like the lm35 itself is bad. PITA because they're only a buck, but I have to wait and pay for shipping.
When turned on the white wire is showing 13.07v and the red wire is showing 10.30v - so it's not a dead short. Very weird.
auraslip
1.21 GW
1.21 GW
Postby GCinDC » Fri May 25, 2012 4:09 am
Flip the connector.
GCinDC
1 GW
1 GW
Postby auraslip » Fri May 25, 2012 4:58 am
Flipped the red and the white connectors and it did the same thing. Bugging the heck out of me.
Does anyone know which lm35 I should order since mouser has 43 of them?
http://www.mouser.com/Sensors/Temperatu ... 35&FS=True
auraslip
1.21 GW
1.21 GW
Postby Joe Perez » Fri May 25, 2012 8:38 am
auraslip wrote:I'm using the hkvt though - http://www.hobbyking.com/hobbyking/stor ... oduct=9744
I understand, I'm just not familiar with that device or its wiring, and I can't find a manual or any other kind of documentation on it anywhere. So I'm wondering whether, internally, it's applying a pullup to the line and expecting ground conduction.
Is there someplace I can see the instruction manual for that device?
Electrically, they all mostly do the same thing. They have slightly different tolerance specs, mostly. And we're still in the transition era in which leaded and lead-free devices are both available, so that accounts for some of the duplication.
This one has +/- 1.5° accuracy, in the most compact footprint, without any unnecessary bells and whistles:http://www.mouser.com/ProductDetail/National-Semiconductor-TI/LM35DZ/?qs=QbsRYf82W3EsDJ6nROSwPSCIPq9l3%252b1KfAEJj0kZY5g%3d
Joe Perez
Postby amberwolf » Fri May 25, 2012 1:41 pm
And many of those listings are for large multiple quantities, if you look in the Quantity column. Like whole tape-reels of them in some cases. :)
amberwolf
Postby GCinDC » Fri May 25, 2012 2:15 pm
guess mine is just an lm35dz:
GCinDC
1 GW
1 GW
Postby Joe Perez » Fri May 25, 2012 3:26 pm
amberwolf wrote:And many of those listings are for large multiple quantities, if you look in the Quantity column. Like whole tape-reels of them in some cases. :)
And in different packaging for the different quantities, to fit different automated production machines. So you might have one part which can be purchased:
Loose in a bag
Stacked end-to-end in a plastic tube
Stacked side-by-side in a plastic tube
Taped onto a reel
Taped onto a reel upside-down
(etc)
But long story short, typically the first half the part number describe the part itself, the next few characters are things like tolerance, mil-spec, lead-free status, etc., and then a couple of characters to describe the packaging that the part comes in. For most DIY purposes, only the first half really matters.
Joe Perez
Postby mvly » Mon Jul 30, 2012 4:25 pm
So anyone able to get this to work with off the shelf LCD display?
mvly
Postby Stryker16 » Tue Aug 14, 2012 10:53 pm
mvly wrote:So anyone able to get this to work with off the shelf LCD display?
I have a hard time relating Celsius degrees to Fahrenheit. So I compromised and went with an analog meter and then printed out a new scale onto a label and presto...
photo (7) by jakevogt16, on Flickr
Stryker16
Postby mvly » Tue Sep 04, 2012 4:08 pm
I finally got this working. It wasn't easy, but it works.
viewtopic.php?f=3&t=43442
Temperature gauges look fine to me. Now to see if I should shrink and make it much better.
mvly
Previous
Return to E-Bike Technical
Users browsing this forum: docnjoj and 12 guests
