okmate wrote:whats wrong with this site i just wrote a whole paragraph but everytime i click submit it wants me to login then i lose what i wrote
its really bugging me ?
knoxie wrote:yes this sounds like hall sensors for sure, yes you can check the hall sensors, test between the black wire which is the ground wire, so put your black test lead on there, set your meter to DC volts, spin the motor and test between the yellow, green and blue wires you should see pulses up to 5V from each one, if you dont then one of the hall sensors might have failed, it can also be the connection to the hall sensors so check them as well.
knoxie wrote:no that doesnt look like halls then, check the connections from the hall sensors to the controller, red and black should be 5V and the others should pulse when you power the wheel.
Users browsing this forum: hillzofvalp, j3tch1u, Orrim943, Wummi and 7 guests
